Ice maker fills with water,but won't dump ice.The arm for full ice bucket is down under the unit. I tried a new ice maker with the same results. I checked for continuity on wires.If I cycle the ice maker,manually, it dumps the ice, fills with water,& freezes, just won't dump.The water valves work.I have turned it off for 15 sec.then on to reset the ice maker and waited over night with no results. any ideas ?
