Discuss
whirlpool freezer won't defrost
 in
Refrigerator & Freezer Repair
Freezer stopped defrosting on me. I have changed the timer and thermostat out in the refrigerator section as it was
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » whirlpool freezer won't defrost
  #1 (permalink)
Old 06-24-2012, 01:12 PM
Junior Member
JEschCO is on a distinguished road
Default whirlpool freezer won't defrost
Model Number: ER8YHMXSL00   Brand: Whirlpool   Age: 1 - 5 years
Freezer stopped defrosting on me. I have changed the timer and thermostat out in the refrigerator section as it was making a clicking sound and getting hung up, but that did not help with the defrost problem in the freezer. Already had to defrost it a few times and is making me nuts. Is my next step to replace the defrost thermostat? Also, how do I replace that in the harness? Or should I just buy a new harness? Would a new harness already have the defrost thermostat attached? Looking for the least expensive route, if I can tackle it. Appreciate any advice! Thanks!
Ads By Google
Related Models
Whirlpool ER8YHMXSL00 Refrigerator
Whirlpool ER8YHMXSL01 Refrigerator
Whirlpool ER8YHMXSQ00 Refrigerator
Gaggenau ER918-010
Gaggenau ER919-010
Whirlpool ER9FHKXTB00 Refrigerator
Whirlpool ER9FHKXTQ00 Refrigerator
Whirlpool ER9FHKXTS00 Refrigerator
Whirlpool ER9SHKXKQ00
Whirlpool ER9SHKXKQ01
Whirlpool ER9SHKXKQ02
Amana ERC10ADD Commercial Microwaves
Amana ERC10APB Commercial Microwaves
Amana ERC10D Commercial Microwaves
Amana ERC10PB Commercial Microwaves
Amana ERC7D Commercial Microwaves
General Electric ERS2022DABB Refrigerator
General Electric ERS2022DACC Refrigerator
General Electric ERS2022DAWW Refrigerator
General Electric ERS2026DABB Refrigerator
General Electric ERS2026DACC Refrigerator
General Electric ERS2026DAWW Refrigerator
Maytag ERSW22A Ref - SXS/I&W
Maytag ERSW24A Ref - SXS/I&W
Maytag ERSW24B Ref - SXS/I&W
General Electric ERT2018DARAA Refrigerator
General Electric ERT2018DARBB Refrigerator
General Electric ERT2018DARCC Refrigerator
General Electric ERT2018DARWW Refrigerator
General Electric ERT2018DBRAA Refrigerator
General Electric ERT2018DBRBB Refrigerator
General Electric ERT2018DBRCC Refrigerator
General Electric ERT2018DBRWW Refrigerator
General Electric ERT2021DARAA Refrigerator
General Electric ERT2021DARBB Refrigerator
General Electric ERT2021DARCC Refrigerator
General Electric ERT2021DARWW Refrigerator
Amana ES-108-2R Room Air Conditioner
Amana ES-108-2S Room Air Conditioner
Amana ES-11-2AMR Room Air Conditioner
Amana ES-11-2MR Room Air Conditioner
Amana ES-12-2MR Room Air Conditioner
Amana ES-7-2MR Room Air Conditioner
Amana ES-9-2MR Room Air Conditioner
Amana ES106-2HL Room Air Conditioner
Amana ES108-2EK Room Air Conditioner
Amana ES1082HL Room Air Conditioner
Amana ES1093HER Room Air Conditioner
Amana ES1093HES Room Air Conditioner
Amana ES11-2AMS Room Air Conditioner
Amana ES1123A Room Air Conditioner
Amana ES1123HER Room Air Conditioner
Amana ES1123HES Room Air Conditioner
Amana ES1123R Room Air Conditioner
Amana ES12-2MS Room Air Conditioner
Amana ES122MA Room Air Conditioner
Amana ES122ML Room Air Conditioner
Amana ES122MN Room Air Conditioner
Amana ES122MR Room Air Conditioner
Frigidaire ES2000P1 Wwh(v1) / Electric Air Cleaner
Amana ES2132MK Room Air Conditioner
Amana ES2133HEL Room Air Conditioner
Amana ES216D-3MS Room Air Conditioner
Amana ES216D3MR Room Air Conditioner
Amana ES218-3SPT Room Air Conditioner
Amana ES2183A Room Air Conditioner
Amana ES2183HEL Room Air Conditioner
Amana ES2183HER Room Air Conditioner
Amana ES2183HES Room Air Conditioner
Amana ES2183ML Room Air Conditioner
Amana ES2183R Room Air Conditioner
Amana ES2183S Room Air Conditioner
Amana ES2183SPHEL Room Air Conditioner
Amana ES2183SPL Room Air Conditioner
Amana ES2183SPM Room Air Conditioner
Amana ES218D3ML Room Air Conditioner
Amana ES218D3MT Room Air Conditioner
Amana ES2213S Room Air Conditioner
Whirlpool ES2FHAXSA00 Refrigerator
Whirlpool ES2FHAXSA01 Refrigerator
Whirlpool ES2FHAXSA02 Refrigerator
Whirlpool ES2FHAXSB00 Refrigerator
Whirlpool ES2FHAXSB01 Refrigerator
Whirlpool ES2FHAXSB02 Refrigerator
Whirlpool ES2FHAXSL01 Refrigerator
Whirlpool ES2FHAXSL02 Refrigerator
Whirlpool ES2FHAXSQ00 Refrigerator
Whirlpool ES2FHAXSQ01 Refrigerator
Whirlpool ES2FHAXSQ02 Refrigerator
Whirlpool ES5FHAXSA00 Refrigerator
Whirlpool ES5FHAXSA01 Refrigerator
Whirlpool ES5FHAXSB00 Refrigerator
  #2 (permalink)
Old 06-25-2012, 02:19 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for Whirlpool ER8YHMXSL00 REFRIGERATOR | AppliancePartsPros.com
I am not a big fan of plug & chug so I would do the following.
First remove the evaporator cover in the freezer so you can see the coils.
Do not let them de-ice.
If yes.
Manually force a defrost cycle, see the tech sheet. When the fans and compressor turn off, you are in defrost.
I never trust replacement parts 100%. Spent too much time when I first started going in circles only to find that the part I replaced was no good. If possible it is always a good idea to check a part before installing it or at least after it is installed.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer needs replacing, re: it is never getting into a defrost cycle.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element from the wiring and measure it for continuity, usually around 30 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are it is timer but could be a gad wire or connector..
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
See the defrost thermostat (Item 32 in section 4).
Unplug the unit and cut the wires going to the old thermostat.
Be sure to leave yourself enough wire.
Now connect in the new thermostat using a couple wire nuts.
Keep the wires away from the heater.
Also attach/zip tie them so that the open ends of the wire nuts face down, keeps water out of them.
Some people also like putting some calking in the iopen ends as an extra precaution.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Replaced Defrost bulb and Defrost Sensor....Temps in freezer around 6 degrees mnmtwi Refrigerator & Freezer Repair 3 10-17-2011 08:46 AM
Whirlpool Freezer Model EV201NXMQ02 intermittently defrosts freezer contents. Defrost NeedToKnow2000 Refrigerator & Freezer Repair 0 05-29-2011 10:17 AM
freezer does not defrost j.kirkland Refrigerator & Freezer Repair 3 05-26-2011 02:06 PM
Finding replacement defrost timer for Whirlpool refrigerator/freezer Len Kanter Refrigerator & Freezer Repair 3 05-06-2010 02:17 PM
I still have froze in the freezer after changing defrost timer & bi-metal defrost matteson Refrigerator & Freezer Repair 0 12-29-2009 06:25 PM
