This is a RCA side by side. the water for the ice maker runs continuously. we lifted the bar and it still ran, so we turned the water off to it under the sink.
Here are your parts Replacement parts for MSX22GRBA WW models | AppliancePartsPros.comTurn the water back on. Check that it is still running continuously. Then unplug the fridge. If the water keeps running you need a new water valve (Item 800 in Section 5). If the water stops I would say you need a new ice maker (Item 820 in Section 2). |
THIS FORUM IS DEAD!!!!!!! |
