miraculix48
#1 Posted : Monday, June 18, 2012 4:05:14 PM(UTC)
miraculix48
I have a GE Monogram Freezer/Refrigerator side-by-side, model ZISW42EMD. Over the last few months, the dispenser took longer and longer to fill a glass of water. Now, it has stopped completely. The ice maker works fine. Any suggestions?
Simon / APP Team
#2 Posted : Monday, June 18, 2012 5:42:19 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
You will need to check two things.
First remove two screws and take off the top grill. Locate on the right side the dual water inlet valve and check if the water line is not broken.
If it's not go to the bottom toe cover and find the water line entering the freezer door. Disconnect the coupling and push the water lever. If the water comes out - the problem is frozen line inside the door. To access the water line you will have to remove the dispenser assembly from the front.
Here are the breakdown diagrams and Replacement parts for General Electric ZISW42EMB Refrigerator | AppliancePartsPros.com
Thank you. Post the results.
Simon.
miraculix48
#3 Posted : Monday, June 18, 2012 6:03:19 PM(UTC)
miraculix48
the plasic tubing running from the water inlet valve has become brittle and is broken. I guess I will have to pull the unit out from the surrounding cabinet to replace the tubing, this will be a challenge. Once I have removed the toe board, will I see where the plastic tubing connects to the line running up the door? Or is any other disassembly required? Also, my model number ends in a D, ZISW42EMD, not B and C as shown in your parts catalogue. Please advice what replacement part I need to order.
Simon / APP Team
#4 Posted : Monday, June 18, 2012 7:36:04 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Get the push on 1/4" plastic coupling and 2 feet of 1/4" tubing.
Very carefully cut the brittle part of the old tubing, install the coupling and new tubing.
With some patience and luck you can save yourself some efforts.
There is no need to get to the bottom connector.
Simon.
PS. Cover the compressor with wet rag - it will be very hot. Best - turn the unit off and cover the compressor.
miraculix48
#5 Posted : Wednesday, June 20, 2012 12:58:14 PM(UTC)
miraculix48
Unfortunately, even the very end near the inlet valve is too brittle to do anything with it. Hence, I will have to connect the new tube to the inlet valve. As you can see from the attached picture, the connection to the valve is made up of four pieces, a threaded plastic nut, a conical piece slipped on to the tubing, a T-shape piece also slipped on to the tubing and a T-shaped piece inserted into the tube. The edge of the T supposed to be sitting right against the wall of the tube disintegrated from a simple touch, but you can still see the darker shadow of the inserted part. I cannot see these parts on your parts list; would you please help identifying the part numbers. Thx!
miraculix48 attached the following image(s):
Simon / APP Team
#6 Posted : Wednesday, June 20, 2012 3:10:22 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
This separated pieces are part of the plastic nut.Take this old nut to any hardware store to get a new one.
Simon.
Water dispenser not working GE Profile PSHs6TGXBDS (Refrigerator & Freezer Repair)
by klkaylor78 2/3/2024 11:07:08 AM(UTC)
Frigidaire Refrigerator Ice Maker and Water Dispenser not working (Refrigerator & Freezer Repair)
by kehoetj 5/9/2023 3:57:44 PM(UTC)
Frigidaire ice maker and water dispenser not working (Refrigerator & Freezer Repair)
by goozpah 1/20/2023 6:39:18 AM(UTC)
Kenmore Elite 795.72489.411 water dispenser not working (Refrigerator & Freezer Repair)
by fjfagergren 5/31/2021 1:16:48 PM(UTC)
Water dispenser not working hums but no water. (Refrigerator & Freezer Repair)
by mouse51180 4/5/2019 4:44:02 PM(UTC)
Water Dispenser not working but ice maker is still working (Refrigerator & Freezer Repair)
by Bobby-Houston 1/14/2019 1:01:20 PM(UTC)
by tmeiss 8/29/2016 2:11:03 PM(UTC)
Water dispenser not working, parts replaced (Refrigerator & Freezer Repair)
by pdog 5/11/2015 4:23:01 PM(UTC)
GE Refrigerator water dispenser not working (Refrigerator & Freezer Repair)
by Jinxpalm 3/4/2015 1:26:52 PM(UTC)
Water dispenser not working with filter. Works without filter (Refrigerator & Freezer Repair)
by kathut 9/2/2014 7:25:16 AM(UTC)
by help810 8/3/2014 6:33:56 PM(UTC)
LG Frig Ice & Water dispenser not working, No Light (Refrigerator & Freezer Repair)
by LG_Frig_Dispenser_Problem 12/20/2013 4:03:40 PM(UTC)
Water dispenser not working. (Refrigerator & Freezer Repair)
by DVDA247365 11/12/2013 11:44:19 AM(UTC)
produce drawer too cold; water dispenser not working (Refrigerator & Freezer Repair)
by houseofreg 5/13/2013 5:12:15 AM(UTC)
water dispenser not working after actuator replacement (Refrigerator & Freezer Repair)
by rd27 3/13/2013 10:55:05 AM(UTC)
