Discuss
No power to compressor or condensor fan
 in
Refrigerator & Freezer Repair
I have a Whirlpool Mark Series that quit cooling. Checked for power to the compressor and there was none. I
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » No power to compressor or condensor fan
  #1 (permalink)
Old 06-16-2012, 11:09 PM
Junior Member
David C. is on a distinguished road
Default No power to compressor or condensor fan
Model Number: ED26MMXRNR4   Brand: Whirlpool   Age: More than 10 years
I have a Whirlpool Mark Series that quit cooling. Checked for power to the compressor and there was none. I decided to "hotwire" the compressor to eliminate any switches or wiring. The compressor still would not start so I tried a start capacitor that had values that were close to the original. The compressor (~2.5 amps) will now run and cool . The condensor fan does not have power to it, but the evaporator fan runs . If I unplug the defrost timer, the evaporator fan will not run. I have checked the thermostatic switch and it has power to it and it has continuity. The red wire that plugs into the juction block (by the water valve) does not have power at that location. It appears that the red wire is broken between the thermostat and the junction block . It anyone has a wiring diagram for the unit, I would very much appreciate it. The fridge has been running for about 3 hours with fans blowing on the condensor coils and the freezer temp is down to 6 deg. F.
David C.
Ads By Google
Related Models
Whirlpool ED26MMXRWR0
Whirlpool ED26MMXRWR2
Whirlpool ED26MMXRWR3
Whirlpool ED26MMXRWR4
Whirlpool ED26SSXLWR0
Whirlpool ED26SSXLWR1
Whirlpool ED26SSXMWR1
Whirlpool ED26SSXRWR0
Whirlpool ED27DQXAB03
Whirlpool ED27DQXAB04
Whirlpool ED27DQXAB05
Whirlpool ED27DQXAN02
Whirlpool ED27DQXAN03
Whirlpool ED27DQXAN04
Whirlpool ED27DQXAN05
Whirlpool ED27DQXAW02
Whirlpool ED27DQXAW03
Whirlpool ED27DQXAW04
Whirlpool ED27DQXAW05
Whirlpool ED27DQXBB00
Whirlpool ED27DQXBB01
Whirlpool ED27DQXBB02
Whirlpool ED27DQXBN00
Whirlpool ED27DQXBN01
Whirlpool ED27DQXBN02
Whirlpool ED27DQXBW00
Whirlpool ED27DQXBW01
Whirlpool ED27DQXBW02
Whirlpool ED27DQXDB00
Whirlpool ED27DQXDB01
Whirlpool ED27DQXDB02
Whirlpool ED27DQXDB03
Whirlpool ED27DQXDB04
Whirlpool ED27DQXDN00
Whirlpool ED27DQXDN01
Whirlpool ED27DQXDN02
Whirlpool ED27DQXDN03
Whirlpool ED27DQXDN04
Whirlpool ED27DQXDW00
Whirlpool ED27DQXDW01
Whirlpool ED27DQXDW02
Whirlpool ED27DQXDW03
Whirlpool ED27DQXDW04
Whirlpool ED27DQXWN00
Whirlpool ED27DQXWN01
Whirlpool ED27DQXWN10
Whirlpool ED27DQXWN11
Whirlpool ED27DQXWN12
Whirlpool ED27DQXWW00
Whirlpool ED27DQXWW01
Whirlpool ED27DQXWW10
Whirlpool ED27DQXWW11
Whirlpool ED27DQXWW12
Whirlpool ED27DQXXN00
Whirlpool ED27DQXXN01
Whirlpool ED27DQXXN02
Whirlpool ED27DQXXW00
Whirlpool ED27DSXDB00
Whirlpool ED27DSXDB01
Whirlpool ED27DSXDB03
Whirlpool ED27DSXDB05
Whirlpool ED27DSXDB06
Whirlpool ED27DSXDN00
Whirlpool ED27DSXDN01
Whirlpool ED27DSXDN03
Whirlpool ED27DSXDN05
Whirlpool ED27DSXDN06
Whirlpool ED27DSXDW00
Whirlpool ED27DSXDW01
Whirlpool ED27DSXDW03
Whirlpool ED27DSXDW05
Whirlpool ED27DSXDW06
Whirlpool ED27PEXHB00
Whirlpool ED27PEXHB01
Whirlpool ED27PEXHB02
Whirlpool ED27PEXHT00
Whirlpool ED27PEXHT01
Whirlpool ED27PEXHT02
Whirlpool ED27PEXHW00
Whirlpool ED27PEXHW01
Whirlpool ED27PEXHW02
Whirlpool ED27PQXEN00
Whirlpool ED27PQXEN01
Whirlpool ED27PQXEW00
Whirlpool ED27PQXEW01
Whirlpool ED27PQXFN00
Whirlpool ED27PQXFN01
Whirlpool ED27PQXFN02
Whirlpool ED27PQXFW00
Whirlpool ED27PQXFW01
Whirlpool ED27PQXFW02
Whirlpool ED27QFXHB00
Whirlpool ED27QFXHB01
Whirlpool ED27QFXHB02
Whirlpool ED27QFXHT00
Whirlpool ED27QFXHT01
Whirlpool ED27QFXHT02
Whirlpool ED27QFXHW00
Whirlpool ED27QFXHW01
Whirlpool ED27QFXHW02
Whirlpool ED27RQXWW00
Whirlpool ED27RQXWW10
Whirlpool ED27RQXWW11
Whirlpool ED27RQXXW00
Whirlpool ED27RQXXW01
Whirlpool ED27RQXXW02
Frigidaire ED287H6 Wwh(v0) / Dehumidifier
Whirlpool ED2CHGXKQ00
Whirlpool ED2CHGXKT00
Whirlpool ED2CHQXKB00
Whirlpool ED2CHQXKB01
Whirlpool ED2CHQXKB03
Whirlpool ED2CHQXKB04
Whirlpool ED2CHQXKB05 Refrigerator
Whirlpool ED2CHQXKB06 Refrigerator
Whirlpool ED2CHQXKB07 Refrigerator
Whirlpool ED2CHQXKQ00
Whirlpool ED2CHQXKQ01
Whirlpool ED2CHQXKQ03
Whirlpool ED2CHQXKQ04
  #2 (permalink)
Old 06-17-2012, 02:57 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
I cannot find any info on a RNR4 but there are parts for a RWR4 see below.
Replacement parts for ED26MMXRNR4 models | AppliancePartsPros.com
Also I cannot find a wiring diagram for either a RNR4 or a RWR4 but I was able to get one for a RWR3. It is probably very close or may be an exact match to your unit.
See the attachment.
It also has a wiring layout which should be a big help tracking down the open in the circuit.
__________________
  #3 (permalink)
Old 06-17-2012, 08:42 AM
Junior Member
Denman,
Thank you for the wiring schematic. I ran a jumper wire from the condensor motor to the terminal block, hooked up the compressor wiring as it can from the factory and everthing works. The schematic shows a "connector" between the terminal block and the evaporator motor. The "connector" is not accessible from the inside or outside. I am guessing the connector was damaged from the high amps that the compressor was pulling (~25 amps)after the start capacitor failed. I guess I get a new fridge for Fathers Day.
David C.
  #4 (permalink)
Old 06-17-2012, 09:58 AM
Senior Expert
APP Volunteer
Default
You seem to know what you are doing so why not jiggery pokery a wire.
I would take it off the main thermostat and just drill a hole out the back of the fridge. If you hit a freon line there is no loss as you are going to scrap it anyway.
__________________
  #5 (permalink)
Old 06-17-2012, 02:12 PM
Junior Member
Default
Denman,
Went and looked at fridges and no one had one in stock that the me or the wife was interested in. I drilled a hole thru the back wall and ran a wire from the evap. motor to the terminal block by the water valve. I ran the wire thru a rubber hose to protect it fron the sharp edges. At least it will buy me some time to get one we want. I hate all of the new electronics they have on them and the high dollar water filters that you have to buy. I will do an autopsy on the old fridge when I get a new one, to find out were the wire lost connection. Thanks again.
David C.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
no power to compressor james gaxiola Refrigerator & Freezer Repair 0 09-08-2011 04:08 PM
compressor continuously runs, condensor fan is not running, warm fridge Trudy12357 Refrigerator & Freezer Repair 4 08-30-2011 02:09 AM
power surge damaged power pack,replaced,compressor and condenser fan still not runnin shillion Refrigerator & Freezer Repair 0 11-16-2010 01:38 AM
Condensor fan not running. power to the 3wire plug has 11.5 vdc on 2 legs. h60mech Refrigerator & Freezer Repair 1 10-16-2010 03:35 PM
ge ref no power to compressor potis Refrigerator & Freezer Repair 0 12-16-2009 07:47 PM
