| » Damper Control for Maytag |
Model Number: MSD2756DEW Brand: Maytag Age: 5 - 10 years
Is Part Details - WHIRLPOOL Housing assy., auto, part number: AP4069713 the Damper Control for a Myatag MSD2756DEW? I'm trying to solve the FF compartment not getting cold enough. The evaporator coil is not freezing up. I'm getting minimal air flow out of the supply baffle so I figure I'd try replacing the damper control. Any step, by step procedure for replacing this? Ads By Google Related Models |
I would first check the air return vent on the left side of the fridg, behind the crisper drawer.
If no clog, pull out the whole control panel (you can get a view of this on this parts site) and check the damper door, may be jammed shut, it should be open at room temperature.
__________________
Quote:
type of Refrig? The way I am reading it is, the FF temp control regulates how much freezer air goes into the FF comparment. It does not control the compressor/fan operation, the freezer temp control does that. When the frig temp control calls for cooling, it opens the damper door until the temp is satisfied, correct? So nothing really happens until the freezer temp control kicks in. Would you recd. chaning the temperature contol unit since I will be taking things apart? The part is not too expensive. |
Quote:
Can somebody explain the functioning of the freezer and refrig. temp controls on auto dampering type referigs. I understand that the refrig control is used to determine for far the damper opens, but a call for cooling by the refrig temp control does not start the compressor/condensor cycle. Its a call by the freezer temp sensor that does this, correct? |
This may also help
http://www.servicematters.com/maytag...s/16010154.pdf I believe yours is the RWD5 wiring diagram
__________________
| Display Modes | |
| Damper | Johnsally | Microwave Repair | 0 | 01-07-2010 02:59 PM |
| Damper Control or Other? | albert a | Refrigerator & Freezer Repair | 0 | 09-27-2009 03:51 PM |
| Air Damper control | rlewis23606 | Refrigerator & Freezer Repair | 1 | 04-07-2009 02:17 AM |
| Maytag Refrigerator damper door | richappy | Refrigerator & Freezer Repair | 1 | 03-28-2009 03:33 PM |
| Kenmore Refrigerator - substitute for obsolete Damper Control | pstokes47 | Refrigerator & Freezer Repair | 3 | 09-16-2008 07:47 PM |
