Discuss
1939 GE refrigerator starts, runs, stops, won't get cold enough
 in
Refrigerator & Freezer Repair
Greetings. I have had this refrigerator for about four years now, and replaced all of the wiring, It has worked
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » 1939 GE refrigerator starts, runs, stops, won't get cold enough
  #1 (permalink)
Old 06-13-2012, 04:10 AM
Junior Member
three-nuts is on a distinguished road
Default 1939 GE refrigerator starts, runs, stops, won't get cold enough
Brand: GE   Age: More than 10 years
Greetings. I have had this refrigerator for about four years now, and replaced all of the wiring, It has worked flawlessly. I keep it in my garage. Last weekend the door was left ajar in 90-degree heat, possibly for several hours. After removing all of the ice from the freezer elements & restarting, it would not cool below 51-degrees. I turned it off (via the thermostat) overnight, and restarted it. The compresser starts (quietly), then runs for ten seconds, during which time the freezer elements chill; then it stops, and then the cycle repeats about three minutes later. I suspect a relay problem. I'll try to find a model number later. This is a flattop unit.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
refrigerator runs alot but is cold Ken1957 Refrigerator & Freezer Repair 0 06-28-2010 10:19 AM
Refrigerator starts and stops chander Refrigerator & Freezer Repair 1 06-19-2010 12:08 PM
Kenmore Gas Dryer runs and stops but starts right up every time i push button gdel64 Dryer Repair 0 05-19-2010 08:28 PM
Refrigerator runs a long time then stops for only 5 minutes Sam94 Refrigerator & Freezer Repair 2 05-15-2010 02:02 PM
Starts to pump during wash then shuts down, starts, stops real quidk sirgalagit Dishwasher Repair 1 10-03-2007 08:23 PM
