Register | FAQ's | New Posts | Today's Posts | Extras |
» Ice Maker Running Water Into Freezer |
![]() Model Number: RT19F9WT Brand: Gibson Age: More than 10 years
![]() Ice maker continues to leak/run water. Have older model Gibson Refrigerator Model RT19F9WT - ( Had live chat with Appliancepartspro on 6/1/12 - ordered recommended ice maker. Have installed new water line; new water valve and new icemaker ( Appliancepartspro - Parts # AP3160597 ( 5303918277)) Ice maker fills but continues to run water. Have verified water tube is in the water trough. Freezer temperature is 10 degf. ( Old water valve caused leaking in refrigerator - new water valve causes vibrating noise and increased leaking in refrigerator ) Water flow will not shut off when lifting the turn off arm. All electrical wiring from valve to ice maker appears OK. At this point we have exhausted all repair information from previous post on line. Currently have water turned off and ice maker turned off. Ice maker WILL freeze ice and will dump ( Trial with ice make filled ) ![]() Related Models |
See inside of your appliance - diagrams and part photos for virtually every model.![]() powered by AppliancePartsPros.com |
![]() Hi.
Remove the electrical plug from the water valve.If the water still coming - replace the water valve. You may have high water pressure damaging the valve. Thank you. Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
![]() Tried disconnecting the electrical power from the water valve, as suggested. Purchased a new water valve - will try that tomorrow. Appliance salesman told me they have received some bad water valves ( In fact he installed one of the bad ones and now has a claim for water damage caused by water valve not shutting off )
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Ice maker running water | taylorcj | Refrigerator & Freezer Repair | 2 | 05-21-2010 05:50 PM |
New ice maker installed but no water running to ice maker | corona32guiness | Refrigerator & Freezer Repair | 0 | 01-06-2010 05:14 PM |
Ice maker water keeps running | dave14830 | Refrigerator & Freezer Repair | 0 | 11-30-2009 01:55 PM |
Ice maker running over with water | miiller | Refrigerator & Freezer Repair | 3 | 07-08-2009 01:50 AM |
Ice maker water keeps running | jjacobs | Refrigerator & Freezer Repair | 1 | 03-04-2008 04:57 PM |
