Discuss
Maytag Refridgerator not making ice
 in
Refrigerator & Freezer Repair
My Maytag does not make ice. I replaced the water inlet (there are two of them and I think I
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Maytag Refridgerator not making ice
  #1 (permalink)
Old 06-11-2012, 11:32 AM
Junior Member
Markd30 is on a distinguished road
Default Maytag Refridgerator not making ice
Model Number: Mzd2766GE   Brand: Maytag   Age: 5 - 10 years
My Maytag does not make ice. I replaced the water inlet (there are two of them and I think I replaced the one that has a line for the ice maker and water dispenser not the one that connects to the water supply line) about 4 months ago. The water lines runs on the back of the fridge and it does not look to be frozen, The water in the door flows freely, the ice maker seems cold but I have not seen it run through a cycle with the wire moving up and down or even hear it making any noise. Can you tell me what to replace? There is no water in the ice cube maker, I've taken it out and looked so no water is getting there.
Related Models
Maytag MZD2766GEB REF - SXS/I&W
Maytag MZD2766GEQ REF - SXS/I&W
Maytag MZD2766GES REF - SXS/I&W
Maytag MZD2766GEW REF - SXS/I&W
Maytag MZD2768GEB REF - SXS/I&W
Maytag MZD2768GEQ REF - SXS/I&W
Maytag MZD2768GEW REF - SXS/I&W
Whirlpool N N ELECTRIC RANGES AND OVENS
Norge N1100PAW RANGE- F/S STD GAS
Norge N1100PRA RANGE- F/S STD GAS
Norge N1100PRA-L RANGE-F/S CONT CLEAN GAS
Norge N1100PRW RANGE- F/S STD GAS
Norge N1100PRW-L RANGE-F/S CONT CLEAN GAS
Norge N1500PRA RANGE- F/S STD ELE
Norge N1500PRW RANGE- F/S STD ELE
Norge N31100PAA RANGE- F/S STD GAS
Norge N31100PAW RANGE- F/S STD GAS
Norge N3110KRA RANGE- F/S STD GAS
Norge N3110KRW RANGE- F/S STD GAS
Norge N3110PPA RANGE- F/S STD GAS
Norge N3110PPW RANGE- F/S STD GAS
Norge N3110PRA RANGE- F/S STD GAS
Norge N3110PRW RANGE- F/S STD GAS
Norge N31111XAA RANGE- F/S STD GAS
Norge N31111XAW RANGE- F/S STD GAS
Norge N31115WAV RANGE- F/S STD GAS
Norge N31115XAA RANGE- F/S STD GAS
Norge N31115XAW RANGE- F/S STD GAS
Norge N3120SPA RANGE- F/S STD GAS
Norge N3120SPN RANGE- F/S STD GAS
Norge N3120SPW RANGE- F/S STD GAS
Norge N3120SRA RANGE- F/S STD GAS
Norge N3120SRW RANGE- F/S STD GAS
Norge N3121XPA RANGE- F/S STD GAS
Norge N3121XPW RANGE- F/S STD GAS
Norge N3121XRA RANGE- F/S STD GAS
Norge N3121XRW RANGE- F/S STD GAS
Norge N3121XTA RANGE- F/S STD GAS
Norge N3121XTW RANGE- F/S STD GAS
Norge N3137XRA RANGE- F/S STD GAS
Norge N3137XRW RANGE- F/S STD GAS
Roper N3157*0 Ranges, Electric*
Roper N3157*1 Ranges, Electric*
Roper N3157W0 Ranges, Electric*
Roper N3157W1 Ranges, Electric*
Norge N3177VUV RANGE- F/S STD GAS
Norge N3177XRA RANGE- F/S STD GAS
Norge N3177XRW RANGE- F/S STD GAS
Norge N3177XUA RANGE- F/S STD GAS
Norge N3177XUW RANGE- F/S STD GAS
Roper N3257*0 Ranges, Electric*
Roper N3257*1 Ranges, Electric*
Roper N3257W0 Ranges, Electric*
Roper N3257W1 Ranges, Electric*
Roper N3357*0 Ranges, Electric*
Roper N3357W0 Ranges, Electric*
Norge N3422PRA RANGE- S/C F/S GAS
Norge N3422PRW RANGE- S/C F/S GAS
Norge N3438SRA RANGE- S/C F/S GAS
Norge N3438SRW RANGE- S/C F/S GAS
Norge N3438VRV RANGE- S/C F/S GAS
Roper N3457*0 Ranges, Electric*
Roper N3457W0 Ranges, Electric*
Norge N3472SRA RANGE- S/C F/S GAS
Norge N3472SRW RANGE- S/C F/S GAS
Norge N3478VRV RANGE- S/C F/S GAS
Norge N3478VVV RANGE- S/C F/S GAS
Norge N3478XRA RANGE- S/C F/S GAS
Norge N3478XRW RANGE- S/C F/S GAS
Norge N3478XVA RANGE- S/C F/S GAS
Norge N3478XVW RANGE- S/C F/S GAS
Norge N3510KRA RANGE- F/S STD ELE
Norge N3510KRW RANGE- F/S STD ELE
Norge N3510PPA RANGE- F/S STD ELE
Norge N3510PPW RANGE- F/S STD ELE
Norge N3510PRA RANGE- F/S STD ELE
Norge N3510PRW RANGE- F/S STD ELE
Norge N3520SPA RANGE- F/S STD ELE
Norge N3520SPN RANGE- F/S STD ELE
Norge N3520SPW RANGE- F/S STD ELE
Norge N3520SRA RANGE- F/S STD ELE
Norge N3520SRW RANGE- F/S STD ELE
Norge N3521XPA RANGE- F/S STD ELE
Norge N3521XPW RANGE- F/S STD ELE
Norge N3521XRA RANGE- F/S STD ELE
Norge N3521XRW RANGE- F/S STD ELE
Norge N3832XRA RANGE- S/C F/S ELE
Norge N3832XRW RANGE- S/C F/S ELE
Norge N3875XRA RANGE- S/C F/S ELE
Norge N3875XRW RANGE- S/C F/S ELE
Norge N3878VRV RANGE- S/C F/S ELE
Norge N3878VVD RANGE- S/C F/S ELE
Norge N3878VVV RANGE- S/C F/S ELE
Norge N3878XRA RANGE- S/C F/S ELE
Norge N3878XRW RANGE- S/C F/S ELE
Norge N3878XVA RANGE- S/C F/S ELE
Norge N3878XVW RANGE- S/C F/S ELE
Magic Chef N40C-3-X9 MWAVE- CNTRTP / STAND ALONE
Norge N4231WRA RANGE-F/S CONT CLEAN GAS
Norge N4231WRW RANGE-F/S CONT CLEAN GAS
Norge N4251WTA RANGE- F/S STD GAS
Norge N4251WTW RANGE- F/S STD GAS
Roper N9157*0 Ranges, Electric*
Roper N9157*1 Ranges, Electric*
Roper N9157L0 Ranges, Electric*
Roper N9157L1 Ranges, Electric*
Roper N9157X0 Ranges, Electric*
Roper N9257*0 Ranges, Electric*
Roper N9257*1 Ranges, Electric*
Roper N9257*2 Ranges, Electric*
Roper N9257L1 Ranges, Electric*
Roper N9257L2 Ranges, Electric*
Roper N9257X0 Ranges, Electric*
Roper N9257X1 Ranges, Electric*
Roper N9357*0 Ranges, Electric*
Roper N9357*2 ELECTRIC RANGE
Roper N9357*3 Ranges, Electric*
Roper N9357L0 Ranges, Electric*
Roper N9357L2 ELECTRIC RANGE
Roper N9357L3 Ranges, Electric*
  #2 (permalink)
Old 06-11-2012, 03:50 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi
Switch around water valves solenoid plugs at both valves and press the water lever at the fountain(doors are closed).
If the ice maker fills up - replace the ice maker.
Check for frozen water inlet tube inside the freezer. If the tube is frozen replace the water valve Part number: 61005626
The ice maker Part number: D7824706Q
Here are the breakdown diagrams and Replacement parts for Maytag MZD2766GEB REF - SXS/I&W | AppliancePartsPros.com
Thank you. Post the results.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
refridgerator making buzzing noise vonvalen Refrigerator & Freezer Repair 1 03-22-2012 11:49 AM
refridgerator making ice but not dispensing water jd61497 Refrigerator & Freezer Repair 3 12-06-2011 06:27 AM
Refridgerator/Freezer ice maker not making solid ice cubes work2do Refrigerator & Freezer Repair 0 05-31-2010 03:20 PM
Refridgerator nor dispensing water or making ice gerardo Refrigerator & Freezer Repair 2 03-28-2009 08:43 AM
Refridgerator making noises Ronald1 Refrigerator & Freezer Repair 3 11-26-2007 11:51 AM
