Discuss
Frigidaire stainless side by side NOT WORKING
 in
Refrigerator & Freezer Repair
So I picked up a free Frigidaire stainless side by side and A comparable fridge to the one I have
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Frigidaire stainless side by side NOT WORKING
  #1 (permalink)
Old 06-10-2012, 07:46 AM
Junior Member
rydholm11211 is on a distinguished road
Question Frigidaire stainless side by side NOT WORKING
Brand: Frigidaire   Age: 1 - 5 years
So I picked up a free Frigidaire stainless side by side and A comparable fridge to the one I have would cost about $1200. Its funny because when I got the fridge the guy said he payed someone to come look at and the tech person told him that the compressor was out and that it would cost $600 to fix, So the guy decided to give the fridge away. So I decided I would try to fix it, So I ordered a compressor kit off ******** for the fridge which cost $80. The kit came with some electrical pieces that go on the back of the compressor, so I put these on the old compressor and after that I plugged the fridge in and the compressor turned on, before when I fist got it, it would not turn on. So I let it sit over night but it did not get cold at all! So I called around and someone said even if the compressor is running it still could be bad, But Im wondering if there is a leak in the system? But if I do fix the refrigeration I would the the tech person would have a way of checking the pressure of the system to make sure there is no leaks? So what do you think?
  #2 (permalink)
Old 06-10-2012, 09:37 AM
Member.
letsride2389 is on a distinguished road
Default ok
He would come in with a meter to check for leaks and also he would add freon to the system with a compound manifold and check to make sure that the suction line is building up a frost pattern. if there is a leak however he would have to suck it down to a vacume with his gauges first than he would have to solder up some new tubing and vacume once more to take out any air that might have snuck back in than re add his freon once more.
  #3 (permalink)
Old 06-10-2012, 09:38 AM
Member.
Default ok
Dont forget he would also replace the drier also.
  #4 (permalink)
Old 06-10-2012, 10:05 AM
Junior Member
Default What is a drier
What is a drier
  #5 (permalink)
Old 06-10-2012, 10:22 AM
Member.
Default ok
Connected beteween the cap tube and the discharge line on the high side by the condenser fan area. Sucks up moisture with tiny like rock beads inside of it.
  #6 (permalink)
Old 06-10-2012, 10:27 AM
Member.
Default ok
The pressure on the high side is between 140 and 160 psi and when it makes its way through the discharge line and the cap tube and heat exchanger it will drop in pressure on low side through the suction line to 0-10 psi and the heat exchanger will take the heat from the captube and use it to dissipate any liquid you may still have in your line so that only vapor go's in the compressor no liquid
  #7 (permalink)
Old 06-11-2012, 04:14 AM
Senior Expert
APP Volunteer
richappy is a splendid one to behold
Default
If the compressor is vibrating and getting warm, but not cooling, the system is very low on refrigerant.
Generally, you cannot just change compressor parts without verifying they will not damage the compressor!
If the compressor now is not vibrating, you probably blew out the start winding.
Seem like your original problem was a refrigerant leak which usually damages the compressor.
__________________
  #8 (permalink)
Old 06-11-2012, 02:41 PM
Member.
Default wtf
Explain how you test your compressor to see if its bad or not? Also what parts are you talking about that he may need for the compressor?
  #9 (permalink)
Old 06-12-2012, 01:09 AM
Senior Expert
APP Volunteer
Default
Impossible to test without the compressor running.
__________________
  #10 (permalink)
Old 06-12-2012, 02:06 AM
Senior Expert
APP Volunteer
Default
Ignore Letsride, he is confusing the issue, check to see if the compressor is vibrating and warm,post results
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
frigidaire side by side water dispenser not working eshe33 Refrigerator & Freezer Repair 9 04-29-2015 08:21 AM
my side by side refrigerator side stoped working need fix Plasteak Refrigerator & Freezer Repair 1 10-17-2011 03:55 AM
Frigidaire Side x side ice maker not working haueyman Refrigerator & Freezer Repair 0 08-10-2011 10:08 AM
Frigidaire Side by Side Water dispenser not working eckzlnt Refrigerator & Freezer Repair 0 07-06-2010 06:09 PM
Frigidaire side by side refrigerator freezer working refrigerator not cold enough SSOWDERS Refrigerator & Freezer Repair 1 09-19-2009 09:00 AM
