| » Refrigerator door won't close |
Model Number: CTF14CGB Brand: Hotpoint Age: More than 10 years
I just installed a refrigerator door gasket and now the door won't close. It is hinged on the right, which is sealed when closed but the left side bottom has a gap of about .75 " when the door is closed. The door gasket does not touch the inside frame of the unit until about 1/3 of the way up. Can the door be adjusted? Is there anything else I can do ?
Thanks much. Eric Ads By Google Related Models |
Few things to check.
1) Gasket should have been put in hot water for a least 10 minutes. 2) Easier if you remove the door. 3) you can adjust the door by putting washes in the hinges. 4) after you install you can put paper inside the gasket where there are any gaps. 5) You can also used a hair dryer and go around the gasket becarful not to melt the plastic. |
| Display Modes | |
| Refrigerator door will not close automatically | Dave Johnson | Refrigerator & Freezer Repair | 6 | 04-23-2010 06:35 AM |
| Refrigerator door won't close | Bro Brock | Refrigerator & Freezer Repair | 0 | 07-21-2009 01:53 PM |
| Ge Refrigerator Door Wont Close All The Way | DAN L | Refrigerator & Freezer Repair | 0 | 07-24-2008 01:43 PM |
| My Oven Door Latch Won't unlock so the door won"t close | Victorine Ravenell | Oven Repair (including Ranges and Cooktops) | 1 | 11-14-2007 10:40 AM |
| door doesn't close so seal is making contact all around door | d ahern | Refrigerator & Freezer Repair | 0 | 10-08-2007 06:44 AM |
