Discuss
GE fridge water filter check valve leaking
 in
Refrigerator & Freezer Repair
Hi there, I have a GE side-by-side fridge. I'm having a problem with the check valve above the MWF water
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » GE fridge water filter check valve leaking
  #1 (permalink)
Old 06-07-2012, 10:29 AM
Junior Member
pdub1970 is on a distinguished road
Default GE fridge water filter check valve leaking
Brand: GE   Age: 5 - 10 years
Hi there,
I have a GE side-by-side fridge. I'm having a problem with the check valve above the MWF water filter. Basically, when I remove the old water filter, the check valve is leaking water.
Any solutions?
Thanks.
Ads By Google
  #2 (permalink)
Old 06-07-2012, 02:25 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
Please provide the complete model number of the unit.
Thank you.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 06-11-2012, 10:34 AM
Junior Member
Default
The fridge is a GE GSS25XSRD SS
  #4 (permalink)
Old 06-11-2012, 12:36 PM
Expert
Default
Hi.
The part your should replace is a filter head and tube Part number: WR17X11618
Here are the breakdown diagrams and Replacement parts for General Electric GSS25XSRDSS Refrigerator | AppliancePartsPros.com
Thank you. Post the results.
Simon.
__________________
  #5 (permalink)
Old 06-13-2012, 07:56 AM
Junior Member
Default
Wow. Thanks Simon.
I looked at the breakdown diagram but didn't see how to install the filter head and tube. Do you have any other diagrams or manuel showing how to change that part out?
Thanks again.
  #6 (permalink)
Old 06-13-2012, 01:14 PM
Expert
Default
Hi.
Remove the water filter, pull out the cover. The base should be attached by two screws. Use common scenes.I could not find any step by step.
Thank you.
Simon.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Elite fridge - leaking from water filter housing burgerman Refrigerator & Freezer Repair 24 07-31-2011 07:38 AM
leaking water inlet valve whirlpool fridge mikethebreadman Refrigerator & Freezer Repair 0 08-22-2010 12:57 PM
Ge Fridge Water Valve Leaking Samantha_White Refrigerator & Freezer Repair 0 07-29-2009 09:55 AM
ice maker leaking under fridge at back of filter rdteros Refrigerator & Freezer Repair 3 06-09-2009 08:05 AM
icemaker/water inlet valve check rks Refrigerator & Freezer Repair 3 01-19-2008 01:19 PM
