The refrigerator and freezer work good for about a day then it
will stop cooling for about a day start cooling and freezing again
Groups: APP Team
Hi.
You need to give us more info to work with. When it stop cooling do you hear any fan motors or compressor running?
Thank you. Post the results.
Simon.
Simon. The fan and the compressor are running when it is not cooling
Groups: APP Team
Hi.
Based on the info you provided most likely the problem is with the "sealed system". To fix that you will need a pro.
Thank you.
Simon.
