| » GE refrig leak |
Model Number: TBX18MAXKRWW Brand: GE Age: More than 10 years
The GE refrigerator (top freezer, no icemaker) is getting water under the crisper bins. After reading up, I figured it might be a clogged drain tube. After removing the cover on the lower back, I saw the drain pan was completely dry. I also noticed that the cover itself was stained and warped from water, and there was a small amount of water flowing down the back of the fridge from where the drain tube attaches to the back (part 315 on the diagram). I snaked a wire up the drain tube, up to the trap-like part at the top of the tube. I then took out the evaporator cover on the back wall of the freezer and could see the drain hole through two small cut-outs. There didn't seem to be any ice or debris around the hole, but I squirted a bunch of hot water in. I stopped when I noticed that a lot of the water was running down the back of the fridge. After reassembling and turning on the fridge, water was also dripping from the control dials near the top of the fresh food compartment, so the drain tube is probably still clogged.
I taped a sponge to the back of the refrigerator to catch the water on the back. I'd appreciate any advice on how to proceed now. Thanks a lot. Ads By Google Related Models |
For anyone else with this problem, the "trap" at the top of the drain tube on the back of the refrigerator was full of gunk. I removed the long tube from the trap then tried to snake out the trap with a straw but couldn't get far enough with that. It turns out the trap simply pulls out, so after I got it off I took it to the sink and ran water through it, then reassembled. Everything is working OK again.
| Display Modes | |
| Maytag Refrig water leak/ice build up at ice maker | joekarenleonard@aol.com | Refrigerator & Freezer Repair | 0 | 09-05-2011 11:09 PM |
| Samsung Refrig/freezer -refrig warmed up | RonOllie | Refrigerator & Freezer Repair | 0 | 07-20-2011 09:22 AM |
| Refrig/Freezer - Refrig ok - freezer not working | orgullodemexico | Refrigerator & Freezer Repair | 1 | 07-14-2010 09:39 AM |
| Side By Side Refrig-Refrig not cold enough | jdhaeger | Refrigerator & Freezer Repair | 0 | 01-31-2009 08:32 PM |
| My refrig. keeps cutting off. One day both freezer and refrig works then it doesnt | winde1203 | Refrigerator & Freezer Repair | 1 | 10-30-2008 12:44 PM |
