| » whirlpool sidekick refrigerator not cooling |
Model Number: EL7ATRRMQ08 Brand: Whirlpool Age: 5 - 10 years
My whirlpool refigerator stopped cooling completely after I turned the temperature control down a little. The fan continues to run and the compressor has a low hum to it but never seems to get going. I tested the starter relay and its working so what should I try now? Got compressor running but still not cooling. Any ideas?
Ads By Google Related Models Last edited by hogo : 06-05-2012 at 04:55 PM. Reason: was able to verify compressor status |
Hi.
Remove the rear cover and check how the evaporator coils are covered with frost if covered at all. Please, post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Quote:
There's nothing on the coils and never was when it stopped cooling. The compressor stays on as does the fan. What doesn't make sense is the problem started when the fridge temperature dial was adjusted. |
Thanks for your response, there's no ice, just a mystery. The temperature went from cold to not cooling at all when I turned the temperature dial/adjustment down a bit.
Hi.
It is a mystery. Most likely it's a sealed system problem. Before calling the pro check if compressor gets 120v. Thank you. Simon.
__________________
If the overload relay is faulty would the compressor run but not cool?
No.The compressor would not run with bad starting components. If it's getting less than 108v it would not work properly.
Simon.
__________________
You are welcome.
Simon.
__________________
| Display Modes | |
| whirlpool refrigerator not cooling | dinoking | Refrigerator & Freezer Repair | 1 | 05-04-2011 02:30 AM |
| Replacing exterior panel on Whirlpool Sidekick freezer | maryharry | Refrigerator & Freezer Repair | 0 | 03-05-2011 09:05 AM |
| Whirlpool Sidekick | dwhitford1 | Refrigerator & Freezer Repair | 0 | 10-06-2010 04:47 PM |
| Whirlpool Refrigerator not cooling | Carol K | Refrigerator & Freezer Repair | 2 | 05-05-2009 10:08 AM |
| Whirlpool refrigerator not cooling | rasterscreen | Refrigerator & Freezer Repair | 3 | 01-06-2009 07:26 AM |
