Discuss
Kenmore Model #36378562895 WATER DRIP FROM PLATE UNDER SETTING DIAL IN FRIDGE
 in
Refrigerator & Freezer Repair
We began noticing water dripping from a metal plate with holes in it, which is under the dial that sets
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Kenmore Model #36378562895 WATER DRIP FROM PLATE UNDER SETTING DIAL IN FRIDGE
  #1 (permalink)
Old 06-03-2012, 06:27 PM
Junior Member
ecandme is on a distinguished road
Unhappy Kenmore Model #36378562895 WATER DRIP FROM PLATE UNDER SETTING DIAL IN FRIDGE
Model Number: 36378562895   Brand: Kenmore   Age: More than 10 years
We began noticing water dripping from a metal plate with holes in it, which is under the dial that sets the coolness temperature inside the fridge. The water runs down the backside of the fridge and pools in the bottom underneath the two large crisper drawers. It gets so full that the water then overflows and runs out the right side of the refrigerator door. We're finding the water running and pooling onto our floor.
We've taken the entire refrigerator apart and cleaned out the long black, hooked drain tube, but again we're finding water pooling and running out to the floor.
Today also we noticed condensation on the freezer walls and the back wall of the freezer felt room temperature to the touch. We un plugged the fridge and then replugged and turned it back on. Now the freezer wall is cold again.
Could the fan motor be going out? what would cause the water to drip and run down the back side in the refrigerator part of the unit?
The water is ruining our hardwood flooring by causing it to buckle from the constant moisture.
Any help would be GREATLY appreciated!
Ads By Google
Related Models
Kenmore 36378562895 REFRIGERATOR
Kenmore 36378562896 REFRIGERATOR
Kenmore 36378567893 REFRIGERATOR
Kenmore 36378567894 REFRIGERATOR
Kenmore 36378567895 REFRIGERATOR
Kenmore 36378567896 REFRIGERATOR
Kenmore 36378592892 REFRIGERATOR
Kenmore 36378592893 REFRIGERATOR
Kenmore 36378592894 REFRIGERATOR
Kenmore 36378592895 REFRIGERATOR
Kenmore 36378592896 REFRIGERATOR
Kenmore 36379262990 REFRIGERATOR
Kenmore 36379265990 REFRIGERATOR
Kenmore 36379267990 REFRIGERATOR
Kenmore 36379282990 REFRIGERATOR
Kenmore 36379287990 REFRIGERATOR
Kenmore 36379562890 REFRIGERATOR
Kenmore 36379562990 REFRIGERATOR
Kenmore 36379567890 REFRIGERATOR
Kenmore 36379567990 REFRIGERATOR
Kenmore 36379962990 REFRIGERATOR
Kenmore 36379962991 REFRIGERATOR
Kenmore 36379965990 REFRIGERATOR
Kenmore 36379965991 REFRIGERATOR
Kenmore 36379967990 REFRIGERATOR
Kenmore 36379967991 REFRIGERATOR
Kenmore 3638335 ICEMAKER KIT
Kenmore 3638339 ICEMAKER KIT
Kenmore 3638390 ICEMAKER KIT
Kenmore 3638400486 REFRIGERATOR
Kenmore 3638400487 REFRIGERATOR
Kenmore 3638400488 REFRIGERATOR
Kenmore 3638480610 Top-Mount
Kenmore 3638480611 REFRIGERATOR
Kenmore 3638480660 REFRIGERATOR
Kenmore 3638480680 Top-Mount
Kenmore 3638480681 REFRIGERATOR
Kenmore 3638500410 REFRIGERATOR
Kenmore 3638500411 REFRIGERATOR
Kenmore 3638500412 REFRIGERATOR
Kenmore 3638500414 REFRIGERATOR
Kenmore 3638500415 REFRIGERATOR
Kenmore 3638500416 REFRIGERATOR
Kenmore 3638500417 REFRIGERATOR
Kenmore 3638500418 REFRIGERATOR
Kenmore 3638500480 REFRIGERATOR
Kenmore 3638500481 REFRIGERATOR
Kenmore 3638500482 REFRIGERATOR
Kenmore 3638500484 REFRIGERATOR
Kenmore 3638500485 REFRIGERATOR
Kenmore 3638500486 REFRIGERATOR
Kenmore 3638500487 REFRIGERATOR
Kenmore 3638500488 REFRIGERATOR
Kenmore 3638500510 REFRIGERATOR
Kenmore 3638500511 REFRIGERATOR
Kenmore 3638500512 REFRIGERATOR
Kenmore 3638500514 REFRIGERATOR
Kenmore 3638500515 REFRIGERATOR
Kenmore 3638500516 REFRIGERATOR
Kenmore 3638500517 REFRIGERATOR
Kenmore 3638500518 REFRIGERATOR
Kenmore 3638500580 REFRIGERATOR
Kenmore 3638500581 REFRIGERATOR
Kenmore 3638500582 REFRIGERATOR
Kenmore 3638500584 REFRIGERATOR
Kenmore 3638500585 REFRIGERATOR
Kenmore 3638500586 REFRIGERATOR
Kenmore 3638500587 REFRIGERATOR
Kenmore 3638500588 REFRIGERATOR
Kenmore 3638502510 REFRIGERATOR
Kenmore 3638502512 REFRIGERATOR
Kenmore 3638502513 REFRIGERATOR
Kenmore 3638502514 REFRIGERATOR
Kenmore 3638502517 REFRIGERATOR
Kenmore 3638502518 REFRIGERATOR
Kenmore 3638502580 REFRIGERATOR
Kenmore 3638502582 REFRIGERATOR
Kenmore 3638502583 REFRIGERATOR
Kenmore 3638502584 REFRIGERATOR
Kenmore 3638502587 REFRIGERATOR
Kenmore 3638502588 REFRIGERATOR
Kenmore 3638580611 REFRIGERATOR
Kenmore 3638580660 REFRIGERATOR
Kenmore 3638580681 REFRIGERATOR
Kenmore 3638587711 REFRIGERATOR
Kenmore 3638587781 REFRIGERATOR
Kenmore 3638587811 REFRIGERATOR
Kenmore 3638604411 REFRIGERATOR
Kenmore 3638604412 REFRIGERATOR
Kenmore 3638604481 REFRIGERATOR
Kenmore 3638604482 REFRIGERATOR
Kenmore 3638604611 REFRIGERATOR
Kenmore 3638604612 REFRIGERATOR
Kenmore 3638604681 REFRIGERATOR
Kenmore 3638604682 REFRIGERATOR
Kenmore 3638654412 REFRIGERATOR
Kenmore 3638654482 REFRIGERATOR
Kenmore 3638655611 REFRIGERATOR
Kenmore 3638655612 REFRIGERATOR
Kenmore 3638655681 REFRIGERATOR
Kenmore 3638655682 REFRIGERATOR
Kenmore 3638691511 REFRIGERATOR
Kenmore 3638691512 REFRIGERATOR
Kenmore 3638691514 REFRIGERATOR
Kenmore 3638691516 REFRIGERATOR
Kenmore 3638691581 REFRIGERATOR
Kenmore 3638691582 REFRIGERATOR
Kenmore 3638691584 REFRIGERATOR
Kenmore 3638691586 REFRIGERATOR
Kenmore 3638692711 REFRIGERATOR
Kenmore 3638692712 REFRIGERATOR
Kenmore 3638692714 REFRIGERATOR
Kenmore 3638692781 REFRIGERATOR
Kenmore 3638692782 REFRIGERATOR
Kenmore 3638692784 REFRIGERATOR
Kenmore 3638695611 REFRIGERATOR
Kenmore 3638695612 REFRIGERATOR
Kenmore 3638695681 REFRIGERATOR
Kenmore 3638695682 REFRIGERATOR
Kenmore 3638698512 REFRIGERATOR
  #2 (permalink)
Old 06-04-2012, 08:55 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Sounds like the problem is a frozen drain in the freezer. Remove the ice maker (if there is one) and the rear panel in the freezer. The drain hole is located under the evaporator coils. You can defrost it using a hair dryer. Run a cup of hot water through the drain to make sure it is clean.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Setting dial problem kittyn Washer Repair 2 02-17-2012 02:19 AM
Kenmore Fridge freezing food even at lowest setting Atoussa Refrigerator & Freezer Repair 3 01-10-2012 06:18 AM
GE Dial Sticks in Plate Warmer Position cdehrlich Dishwasher Repair 0 09-05-2010 09:56 AM
No heat and setting dial does not turn TOG1 Dryer Repair 4 07-06-2009 09:33 PM
kenmore oven not heating to dial setting kings113 Oven Repair (including Ranges and Cooktops) 0 12-14-2008 06:17 PM
