Discuss
Fridge/freezer will not turn on, lights only.
 in
Refrigerator & Freezer Repair
Amana fridge/freezer BG21V1W. The in-law said the freezer stopped freezing but fridge worked(????). Got it to my house, plugged it
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Fridge/freezer will not turn on, lights only.
  #1 (permalink)
Old 06-02-2012, 10:35 AM
Junior Member
spanky8993 is on a distinguished road
Default Fridge/freezer will not turn on, lights only.
Model Number: BG21V1w   Brand: Amana   Age: 5 - 10 years
Amana fridge/freezer BG21V1W. The in-law said the freezer stopped freezing but fridge worked(????). Got it to my house, plugged it in, the lights come on and that is it. No fan, no compressor. Turned dials, nothing.
Ads By Google
Related Models
Amana BG21V1W REF - BOTTOM MOUNTS
Amana BG21VC REF - BOTTOM MOUNTS
Amana BG21VL REF - BOTTOM MOUNTS
Amana BG21VW REF - BOTTOM MOUNTS
 BG8000ER Air Conditioner
Frigidaire BGBD2432KB0 DISHWASHER
Frigidaire BGBD2432KF0 DISHWASHER
Frigidaire BGBD2432KW0 DISHWASHER
Roper BGC430WB0 Range (gas)*
Frigidaire BGEF3032KBA ELECTRIC RANGE
Frigidaire BGEF3032KBB ELECTRIC RANGE
Frigidaire BGEF3032KBC ELECTRIC RANGE
Frigidaire BGEF3032KWA ELECTRIC RANGE
Frigidaire BGEF3032KWB ELECTRIC RANGE
Frigidaire BGEF3032KWC ELECTRIC RANGE
Frigidaire BGEF3042KFA ELECTRIC RANGE
Frigidaire BGEF3042KFB ELECTRIC RANGE
Frigidaire BGEF3042KFC ELECTRIC RANGE
Frigidaire BGEF3042KFD ELECTRIC RANGE
Frigidaire BGEF3044KFA ELECTRIC RANGE
Frigidaire BGEF3044KFB ELECTRIC RANGE
Maytag BGFIM18E5 UNDERCOUNTER BUILT IN ICE MAKER
Frigidaire BGGF3031KBA GAS RANGE
Frigidaire BGGF3031KBB GAS RANGE
Frigidaire BGGF3031KBC GAS RANGE
Frigidaire BGGF3031KBD GAS RANGE
Frigidaire BGGF3031KBE GAS RANGE
Frigidaire BGGF3031KBF GAS RANGE
Frigidaire BGGF3031KBG GAS RANGE
Frigidaire BGGF3031KBH GAS RANGE
Frigidaire BGGF3031KWA GAS RANGE
Frigidaire BGGF3031KWB GAS RANGE
Frigidaire BGGF3031KWC GAS RANGE
Frigidaire BGGF3031KWD GAS RANGE
Frigidaire BGGF3031KWE GAS RANGE
Frigidaire BGGF3031KWF GAS RANGE
Frigidaire BGGF3031KWG GAS RANGE
Frigidaire BGGF3031KWH GAS RANGE
Frigidaire BGGF3041KFA GAS RANGE
Frigidaire BGGF3041KFB GAS RANGE
Frigidaire BGGF3041KFC GAS RANGE
Frigidaire BGGF3041KFD GAS RANGE
Frigidaire BGGF3041KFE GAS RANGE
Frigidaire BGGF3042KFA GAS RANGE
Frigidaire BGGF3042KFB GAS RANGE
Frigidaire BGGF3042KFC GAS RANGE
Frigidaire BGGF3042KFD GAS RANGE
Frigidaire BGGF3042KFE GAS RANGE
Frigidaire BGGF3042KFF GAS RANGE
Frigidaire BGGF3042KFG GAS RANGE
Frigidaire BGGF3042KFH GAS RANGE
Frigidaire BGGF3042KFJ GAS RANGE
Frigidaire BGGF3042KFK GAS RANGE
Frigidaire BGGF3042KFM GAS RANGE
Frigidaire BGGF3042KFN GAS RANGE
Frigidaire BGHD2433KB0 DISHWASHER
Frigidaire BGHD2433KB1 DISHWASHER
Frigidaire BGHD2433KF0 DISHWASHER
Frigidaire BGHD2433KF1 DISHWASHER
Frigidaire BGHD2433KW0 DISHWASHER
Frigidaire BGHD2433KW1 DISHWASHER
Frigidaire BGHS2634KE0 REFRIGERATOR
Frigidaire BGHS2634KE1 REFRIGERATOR
Frigidaire BGHS2634KE2 REFRIGERATOR
Frigidaire BGHS2634KP0 REFRIGERATOR
Frigidaire BGHS2634KP1 REFRIGERATOR
Frigidaire BGHS2634KP2 REFRIGERATOR
Frigidaire BGHS2644KF0 REFRIGERATOR
Frigidaire BGHS2644KF1 REFRIGERATOR
Frigidaire BGHS2644KF2 REFRIGERATOR
Roper BGP430WB0 Range (gas)*
Roper BGS470WB0 Range (gas)*
Amana BH20S5L REF - BOTTOM MOUNTS
Amana BH20S5W REF - BOTTOM MOUNTS
Amana BH20TL REF - BOTTOM MOUNTS
Amana BH20TW REF - BOTTOM MOUNTS
Whirlpool BHAC0500BS0 AIR CONDITIONER
Whirlpool BHAC0500BS1 AIR CONDITIONER
Whirlpool BHAC0500FS0 AIR CONDITIONERS
Whirlpool BHAC0500FS1 AIR CONDITIONER
Whirlpool BHAC0500XS0 Air-conditioner/heat pump
Whirlpool BHAC0500XS1 Air-conditioner/heat pump
Whirlpool BHAC0500XS2 Air-conditioner/heat pump
Whirlpool BHAC0500XS4 Air-conditioner/heat pump
Whirlpool BHAC0500XS5 AIR CONDITIONER
Whirlpool BHAC0600BS0 AIR CONDITIONER
Whirlpool BHAC0600XS1 Air-conditioner/heat pump
Whirlpool BHAC0700BS0 AIR CONDITIONER
Whirlpool BHAC0700FS0 AIR CONDITIONER
Whirlpool BHAC0700XS0 Air-conditioner/heat pump
Whirlpool BHAC0830AS0 AIR CONDITIONER
Whirlpool BHAC0830AS1 AIR CONDITIONER
Whirlpool BHAC0830XS0 AIR CONDITIONER
Whirlpool BHAC1000BS0 AIR CONDITIONER
Whirlpool BHAC1000FS0 AIR CONDITIONER
Whirlpool BHAC1000XS0 Air-conditioner/heat pump
Whirlpool BHAC1000XS1 Air-conditioner/heat pump
Whirlpool BHAC1000XS2 Air-conditioner/heat pump
Whirlpool BHAC1000XS3 AIR CONDITIONER
Whirlpool BHAC1200BS0 AIR CONDITIONERS
Whirlpool BHAC1200FS0 AIRCONDITIONER
Whirlpool BHAC1200XS0 Air-conditioner/heat pump
Whirlpool BHAC1200XS1 Air-conditioner/heat pump
Whirlpool BHAC1230AS0 Air-conditioner/heat pump
Whirlpool BHAC1230AS1 AIR CONDITIONER
Whirlpool BHAC1230XS0 AIR CONDITIONER
Whirlpool BHAC1250XS0 Air-conditioner/heat pump
Whirlpool BHAC1400BS0 AIR CONDITIONER
Whirlpool BHAC1400BS1 AIR CONDITIONER
Whirlpool BHAC1400FS0 AIR CONDITIONER
Whirlpool BHAC1400XS0 Air-conditioner/heat pump
  #2 (permalink)
Old 06-03-2012, 06:12 AM
Senior Expert
APP Volunteer
denman is a glorious beacon of light
Default
Replacement parts for BG21V1W models | AppliancePartsPros.com
I could not find any tech info on this unit.
How long have you waited?
Could be you are in a defrost cycle, this will take about half an hour to complete.
If you waited longer than an hour then try turning the defrost timer (Item 342 in Section 9) cam. There is usually a hole in the cover to let you do this without taking things apart.
If it fires up I would replace the defrost timer.
If the above does nothing it does not totally eliminate the timer as the problem re: it's contacts may be toast.
I do not know if the main thermostat is 2 wire or 3 wire.
If 2 wire unplug the unit and one wire to the thermostat and measure it with a meter. Should be 0 ohms.
An alternative would be to short the wires together and then give it a try.
Be sure they cannot short to anything else.
If you click on a part's picture a new page will open with more info on that part.
The above is not really possible because the fresh food gets all it's cooling from the freezer so if the freezer does not work at all the fresh food will also not work but there may be a time delay between the two.
__________________
  #3 (permalink)
Old 06-05-2012, 06:13 AM
Junior Member
Default
I did turn the defrost timer and the fridge came on. It's been a couple of days and it's barely cool in the fridge so there is a no cooling issue now. No time to try anything else yet.
  #4 (permalink)
Old 06-05-2012, 10:07 AM
Senior Expert
APP Volunteer
Default
If the compressor is running all the time, remove the cover inside the freezer so you can inspect the coils. If they only have frost in one area (usually where the freon enters) or no frost, then you have a sealed system problem and this will be an expensive repair as you need a pro.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Amana fridge bottom freezer warm; lights, freezer fan works sdjacksfan Refrigerator & Freezer Repair 1 03-06-2012 02:08 PM
Lights are on, but Fridge and Freezer not cooling jsherlock Refrigerator & Freezer Repair 0 05-29-2011 01:54 PM
fridge and freezer will cool only after turn of and back on hellmanjeffrey@yahoo.com Refrigerator & Freezer Repair 11 04-15-2009 04:03 PM
Fridge lights do not work. Freezer does Eddie Alvarez Refrigerator & Freezer Repair 1 03-01-2009 05:52 PM
freezer and fridge lights do not work cat416 Refrigerator & Freezer Repair 1 10-16-2007 11:35 AM
