Discuss
Kitchenaid control panel 8201673 instal
 in
Refrigerator & Freezer Repair
[IMG]http://img12.********************.us/img12/5208/img1340medium.jpg[/IMG] [IMG]http://img842.********************.us/img842/5208/img1340medium.jpg[/IMG] [IMG]http://img88.********************.us/img88/8710/img1341medium.jpg[/IMG] [IMG]http://img848.********************.us/img848/9646/stickerfu.png[/IMG] [IMG]http://img17.********************.us/img17/7152/paneld.png[/IMG] [IMG]http://img820.********************.us/img820/9447/img1330mediumd.jpg[/IMG] [IMG]http://img823.********************.us/img823/7404/img1329medium.jpg[/IMG] [IMG]http://img84.********************.us/img84/9315/img1333medium.jpg[/IMG] [IMG]http://img407.********************.us/img407/1097/img1339medium.jpg[/IMG] I was having issues with the my fridge getting too warm.
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Kitchenaid control panel 8201673 instal
  #1 (permalink)
Old 05-30-2012, 10:21 PM
Junior Member
RAJOD is on a distinguished road
Smile Kitchenaid control panel 8201673 instal
Model Number: KSR s25PNLK00   Brand: Kitchen Aid   Age: 1 - 5 years
I was having issues with the my fridge getting too warm. It was in the defroster, it was icing up every 3 weeks and I had to manually defrost. I check the two thermistors and heating element. I hope its the control panel. This is how I removed it.
I had no directions so was not as easy as I thought. I hope this makes the install easier for someone.
How to remove the control module.
1. Unplug the refrigerator
2. Use a 1/4 socket driver to remove 4 screws holding plastic cover in place.
3. There is a thin plastic cover (not pictured) that covers the green board. Its held on with 3 Phillips screws. Remove it to get to the board.
4. The red circles on the picture are plugs you need to unplug to get the unit out. I had to use a screwdriver to pry some of the connectors loose like the ones on the light and the button for the light.. All the plastic connectors to the circuit board have a tab that you must press in order to unplug. Don’t just pull unless you have pressed the tab or it will never come out.
5. Once its out peel the push button covering off. The part that has the push buttons and temp control. Its just a thin sticker. I was able to use my fingernail to start it then it peeled off like a piece of tape.
6. The control board has to be slid out towards you like in the pictures. Use a flat blade screwdriver to pop it free. Just be careful and it will pop out.
7. The new control board will be flat. You have to bend it at a 45 degree. Can use the edge of the counter but I just did it free handed. It bent much easier than I expected. You will here the green board crack as there are areas on it that will break off when you bend it. Its suppose to do that.
8. Once you get the board out slide the new one in and snap it in place.
9. Put the included (from Appliance Pros) kitchenaid sticker over the front.
10. Replug in all the connections (I had someone hold it which made it much easier to plug it all back in and screw in place.
11. Cross fingers that it all works when you plug it back in.
So far so good with mine.
Ads By Google
Related Models
Whirlpool KSRA22CNBL00 Refrigerator
Whirlpool KSRA22CNBL01 Refrigerator
Whirlpool KSRA22CNBL02 Refrigerator
Whirlpool KSRA22CNBT00 Refrigerator
Whirlpool KSRA22CNBT01 Refrigerator
Whirlpool KSRA22CNBT02 Refrigerator
Whirlpool KSRA22CNSS00 Refrigerator
Whirlpool KSRA22CNSS01 Refrigerator
Whirlpool KSRA22CNSS02 Refrigerator
Whirlpool KSRA22CNWH00 Refrigerator
Whirlpool KSRA22CNWH01 Refrigerator
Whirlpool KSRA22CNWH02 Refrigerator
Whirlpool KSRA22FKBL00 Refrigerator
Whirlpool KSRA22FKBL01 Refrigerator
Whirlpool KSRA22FKBT00 Refrigerator
Whirlpool KSRA22FKBT01 Refrigerator
Whirlpool KSRA22FKSS00 Refrigerator
Whirlpool KSRA22FKSS01 Refrigerator
Whirlpool KSRA22FKWH00 Refrigerator
Whirlpool KSRA22FKWH01 Refrigerator
Whirlpool KSRA22ILBL00 Refrigerator
Whirlpool KSRA22ILBL01 Refrigerator
Whirlpool KSRA22ILBL02 Refrigerator
Whirlpool KSRA22ILBL03 Refrigerator
Whirlpool KSRA22ILBL13 Refrigerator
Whirlpool KSRA22ILBT00 Refrigerator
Whirlpool KSRA22ILBT01 Refrigerator
Whirlpool KSRA22ILBT02 Refrigerator
Whirlpool KSRA22ILBT03 Refrigerator
Whirlpool KSRA22ILBT13 Refrigerator
Whirlpool KSRA22ILSS00 Refrigerator
Whirlpool KSRA22ILSS01 Refrigerator
Whirlpool KSRA22ILSS02 Refrigerator
Whirlpool KSRA22ILSS03 Refrigerator
Whirlpool KSRA22ILSS13 Refrigerator
Whirlpool KSRA22ILWH00 Refrigerator
Whirlpool KSRA22ILWH01 Refrigerator
Whirlpool KSRA22ILWH02 Refrigerator
Whirlpool KSRA22ILWH03 Refrigerator
Whirlpool KSRA22ILWH13 Refrigerator
Whirlpool KSRA22KKBL00
Whirlpool KSRA22KKBL01
Whirlpool KSRA22KKBL02 Refrigerator
Whirlpool KSRA22KKBT00
Whirlpool KSRA22KKBT01
Whirlpool KSRA22KKBT02 Refrigerator
Whirlpool KSRA22KKSS00
Whirlpool KSRA22KKSS01
Whirlpool KSRA22KKSS02 Refrigerator
Whirlpool KSRA22KKWH00
Whirlpool KSRA22KKWH01
Whirlpool KSRA22KKWH02 Refrigerator
Whirlpool KSRA22KNSS00 Refrigerator
Whirlpool KSRA22KNSS01 Refrigerator
Whirlpool KSRA25CNBL00 Refrigerator
Whirlpool KSRA25CNBL01 Refrigerator
Whirlpool KSRA25CNBL02 Refrigerator
Whirlpool KSRA25CNBT00 Refrigerator
Whirlpool KSRA25CNBT01 Refrigerator
Whirlpool KSRA25CNBT02 Refrigerator
Whirlpool KSRA25CNBU00 Refrigerator
Whirlpool KSRA25CNBU01 Refrigerator
Whirlpool KSRA25CNLK00 Refrigerator
Whirlpool KSRA25CNLK01 Refrigerator
Whirlpool KSRA25CNSS00 Refrigerator
Whirlpool KSRA25CNSS01 Refrigerator
Whirlpool KSRA25CNSS02 Refrigerator
Whirlpool KSRA25CNWH00 Refrigerator
Whirlpool KSRA25CNWH01 Refrigerator
Whirlpool KSRA25CNWH02 Refrigerator
Whirlpool KSRA25FKBL00
Whirlpool KSRA25FKBL01 Refrigerator
Whirlpool KSRA25FKBT00
Whirlpool KSRA25FKBT01 Refrigerator
Whirlpool KSRA25FKSS00
Whirlpool KSRA25FKSS01 Refrigerator
Whirlpool KSRA25FKWH00
Whirlpool KSRA25FKWH01 Refrigerator
Whirlpool KSRA25ILBL00 Refrigerator
Whirlpool KSRA25ILBL01 Refrigerator
Whirlpool KSRA25ILBL03
Whirlpool KSRA25ILBL13 Refrigerator
Whirlpool KSRA25ILBT00 Refrigerator
Whirlpool KSRA25ILBT01 Refrigerator
Whirlpool KSRA25ILBT03
Whirlpool KSRA25ILBT13 Refrigerator
Whirlpool KSRA25ILBU03
Whirlpool KSRA25ILBU13 Refrigerator
Whirlpool KSRA25ILSS00 Refrigerator
Whirlpool KSRA25ILSS01 Refrigerator
Whirlpool KSRA25ILSS03
Whirlpool KSRA25ILSS13 Refrigerator
Whirlpool KSRA25ILWH00 Refrigerator
Whirlpool KSRA25ILWH01 Refrigerator
Whirlpool KSRA25ILWH03
Whirlpool KSRA25ILWH13 Refrigerator
Whirlpool KSRA25KKBL00
Whirlpool KSRA25KKBL01
Whirlpool KSRA25KKBL02 Refrigerator
Whirlpool KSRA25KKBL12 Refrigerator
Whirlpool KSRA25KKBT00
Whirlpool KSRA25KKBT01
Whirlpool KSRA25KKBT02 Refrigerator
Whirlpool KSRA25KKBT12 Refrigerator
Whirlpool KSRA25KKSS00
Whirlpool KSRA25KKSS01
Whirlpool KSRA25KKSS02 Refrigerator
Whirlpool KSRA25KKSS12 Refrigerator
Whirlpool KSRA25KKWH00
Whirlpool KSRA25KKWH01
Whirlpool KSRA25KKWH02 Refrigerator
Whirlpool KSRA25KKWH12 Refrigerator
Whirlpool KSRA25KNSS00 Refrigerator
Whirlpool KSRA25KNSS01 Refrigerator
Whirlpool KSRA25PNBL00 Refrigerator
Whirlpool KSRA25PNBT00 Refrigerator
Whirlpool KSRA25PNLK00 Refrigerator
Whirlpool KSRA25PNSS00 Refrigerator
Whirlpool KSRA25PNWH00 Refrigerator
Whirlpool KSRB22DWAL02
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kitchenaid Dw: Need New Control Panel? chipLAT8706 Dishwasher Repair 6 11-08-2010 08:45 AM
Kitchenaid control panel disassembly John Chang Dishwasher Repair 0 06-30-2010 12:38 PM
Kitchenaid Control Panel Replacement spadehead Dishwasher Repair 0 04-10-2010 09:08 AM
kitchenaid control panel losal5 Dishwasher Repair 3 11-13-2009 01:59 AM
Kitchenaid Dishwasher control panel gkrish Dishwasher Repair 1 08-19-2009 01:57 PM
