Discuss
Refrigerator Thermostat Help
 in
Refrigerator & Freezer Repair
Hi, I'm trying to replace my refrigerator's thermostat. My refrigerator is a top and bottom Admiral. Can you please advise
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Refrigerator Thermostat Help
  #1 (permalink)
Old 09-11-2009, 12:19 PM
Junior Member
benofjoy is on a distinguished road
Default Refrigerator Thermostat Help
Model Number: HMG191400   Brand: Admiral   Age: 5 - 10 years
Can you please advise if the male connector on my thermostat (Item 1 in picture 2) should connect to B or C (picture 1)?
Likewise, should the female connector on my thermostat (Item 2 in picture2) be connected to A or D (picture 1)?
Picture1: http://refrigeratorthermo.shutterfly.com/27
Picture2: http://refrigeratorthermo.shutterfly.com/28
Thank you very much
Ads By Google
Related Models
General Electric HMV24CEWABB Gas range
General Electric HMV24CEWAN Gas range
General Electric HMV24CEWEBB Gas range
General Electric HMV24CEWEN Gas range
Maytag HN41240P Gas Water Heater
Maytag HN41240PCAN Gas Water Heater
Maytag HN41240X Gas Water Heater
Maytag HN41240XCAN Gas Water Heater
Maytag HN41250P Gas Water Heater
Maytag HN41250PCAN Gas Water Heater
Maytag HN41250Q Gas Water Heater
Maytag HN41250QCAN Gas Water Heater
Maytag HN41250V Gas Water Heater
Maytag HN41250VCAN Gas Water Heater
Maytag HN41250VCANZ Gas Water Heater
Maytag HN41250VZ Gas Water Heater
Maytag HN41250X Gas Water Heater
Maytag HN41250XCAN Gas Water Heater
Maytag HN41275P Gas Water Heater
Maytag HN41275PCANZ Gas Water Heater
Maytag HN41275PZ Gas Water Heater
Maytag HN41275Q Gas Water Heater
Maytag HN41275QCAN Gas Water Heater
Maytag HN4830T971 Gas Water Heater
Maytag HN4840S971 Gas Water Heater
Maytag HN4840T971 Gas Water Heater
Maytag HN4850T971 Gas Water Heater
Maytag HN4875S980 Gas Water Heater
Maytag HN4930T Gas Water Heater
Maytag HN4930TCAN Gas Water Heater
Maytag HN4940S Gas Water Heater
Maytag HN4940SCAN Gas Water Heater
Maytag HN4940T Gas Water Heater
Maytag HN4940TCAN Gas Water Heater
Maytag HN4950S Gas Water Heater
Maytag HN4950SCAN Gas Water Heater
Maytag HN4950T Gas Water Heater
Maytag HN4950TCAN Gas Water Heater
Maytag HN4975S Gas Water Heater
Maytag HN4975SCAN Gas Water Heater
Maytag HN4X40P980 Gas Water Heater
Maytag HN4X40P980CGA Gas Water Heater
Maytag HN4X40X960 Gas Water Heater
Maytag HN4X40X960CGA Gas Water Heater
Maytag HN4X50P980 Gas Water Heater
Maytag HN4X50Q960 Gas Water Heater
Maytag HN4X50Q960CGA Gas Water Heater
Maytag HN4X50V980 Gas Water Heater
Maytag HN4X50X960 Gas Water Heater
Maytag HN4X50X960CGA Gas Water Heater
Maytag HN51240P Gas Water Heater
Maytag HN51240PCAN Gas Water Heater
Maytag HN51240X Gas Water Heater
Maytag HN51240XCAN Gas Water Heater
Maytag HN51250P Gas Water Heater
Maytag HN51250PCAN Gas Water Heater
Maytag HN51250Q Gas Water Heater
Maytag HN51250QCAN Gas Water Heater
Maytag HN51250V Gas Water Heater
Maytag HN51250VCAN Gas Water Heater
Maytag HN51250VCANZ Gas Water Heater
Maytag HN51250VZ Gas Water Heater
Maytag HN51250X Gas Water Heater
Maytag HN51250XCAN Gas Water Heater
Maytag HN51275P Gas Water Heater
Maytag HN51275PCANZ Gas Water Heater
Maytag HN51275PZ Gas Water Heater
Maytag HN51275Q Gas Water Heater
Maytag HN51275QCAN Gas Water Heater
Maytag HN5830T971 Gas Water Heater
Maytag HN5840S971 Gas Water Heater
Maytag HN5840T971 Gas Water Heater
Maytag HN5850T971 Gas Water Heater
Maytag HN5875S980 Gas Water Heater
Maytag HN5930T Gas Water Heater
Maytag HN5930TCAN Gas Water Heater
Maytag HN5940S Gas Water Heater
Maytag HN5940SCAN Gas Water Heater
Maytag HN5940T Gas Water Heater
Maytag HN5940TCAN Gas Water Heater
Maytag HN5950S Gas Water Heater
Maytag HN5950SCAN Gas Water Heater
Maytag HN5950T Gas Water Heater
Maytag HN5950TCAN Gas Water Heater
Maytag HN5975S Gas Water Heater
Maytag HN5975SCAN Gas Water Heater
Maytag HN5X40P980 Gas Water Heater
Maytag HN5X40X960 Gas Water Heater
Maytag HN5X40X960CGA Gas Water Heater
Maytag HN5X50P980 Gas Water Heater
Maytag HN5X50Q960 Gas Water Heater
Maytag HN5X50Q960CGA Gas Water Heater
Maytag HN5X50V980 Gas Water Heater
Maytag HN5X50X960 Gas Water Heater
Maytag HN5X50X960CGA Gas Water Heater
Thermador HNI42YS
Thermador HNI48YS
Thermador HNI54YS
General Electric HNSR3110H0WW Washer
Thermador HNW36YS
Thermador HNW42YS
Thermador HNW48YS
Maytag HP41240P Gas Water Heater
Maytag HP41240PCAN Gas Water Heater
Maytag HP41240X Gas Water Heater
Maytag HP41240XCAN Gas Water Heater
Maytag HP41250P Gas Water Heater
Maytag HP41250PCAN Gas Water Heater
Maytag HP41250Q Gas Water Heater
Maytag HP41250QCAN Gas Water Heater
Maytag HP41250X Gas Water Heater
Maytag HP41250XCAN Gas Water Heater
Maytag HP41275P Gas Water Heater
Maytag HP41275PCANZ Gas Water Heater
Maytag HP41275PZ Gas Water Heater
Maytag HP41275Q Gas Water Heater
Maytag HP41275QCAN Gas Water Heater
Maytag HP4830T980 Gas Water Heater
Maytag HP4840S980 Gas Water Heater
Maytag HP4840T980 Gas Water Heater
  #2 (permalink)
Old 09-12-2009, 07:12 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Cannot find any info on this unit, so the below is a guess. I am assuming that D and A go to the defrost heater.
Looks like CD are too short to fit together so I would say that it should between them.
Be sure to tape the one side that will not have an insulating sheath up tightly.
Might also be a good idea to give it a coating of silicone sealant once you confirm the unit is operating correctly. I would also twist tie it or use a zip tie to hold it up where it is less likely to get ice or water.
In any case the defrost thermostat will do it's job as long as it is wired in series with the heater.
__________________
  #3 (permalink)
Old 09-12-2009, 08:29 AM
Junior Member
Default
Hi Denman,
You mean A and B should be connected together. The thermostat should go between C and D. Correct?
Thank you
  #4 (permalink)
Old 09-12-2009, 09:17 AM
Senior Expert
APP Volunteer
Default
Yes that is where I would put it.
__________________
  #5 (permalink)
Old 09-12-2009, 08:02 PM
Member
Eddie365 is on a distinguished road
Default
Connect A-B
Connect Defrost T-stat between C-D and then Clip it into the coil that is on the right.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Need freezer thermostat control for Frigidare Refrigerator janappo Refrigerator & Freezer Repair 3 01-26-2010 01:29 AM
How to remove refrigerator thermostat panel rtmadbeach Refrigerator & Freezer Repair 0 09-02-2009 07:49 AM
Refrigerator thermostat Mark Matthews Refrigerator & Freezer Repair 3 08-14-2009 02:18 AM
Whirlpool Refrigerator Thermostat keeps failing DUKETEX Refrigerator & Freezer Repair 0 01-10-2009 09:11 AM
bought new thermostat and heater thermostat and now won't heat at all mgilbert6 Dryer Repair 0 09-07-2008 09:58 AM
