| » Removing CustomCool |
Model Number: PSS25SGNABS Brand: GE Age: 5 - 10 years
I beleive the damper in my CustomCool is broken, it makes the woodpecker sound when the ExpressThaw turns off. Could anybody tell me how to remove the CustomCool unit. The Service Guide I found is PUB#31-9072 01/01 does not explain how to remove this unit.
Once I free it from the freezer side will the upper cover release by the three tap and allow me to service the damper without disconnecting the wiring harness that go into the bottom of the compartment? Ads By Google Related Models |
Hi Steve,
The instructions are attached to the reply. Here are the breakdown diagrams and Replacement parts for General Electric PSS25SGNABS Refrigerator | AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Quote:
After i found the tape on the back of the cover. Everything came apart great. I took the damper apart and it has some stripped threads. Is there a way to tell that is is just the damper or is the control board faulty which caused the stripped threads? Or is this just a common issue for the damper to get worn out overtime? Thanks for you help. |
Quote:
__________________
| Display Modes | |
| Removing the inner tub | rackumsucker | Washer Repair | 1 | 01-23-2012 01:03 PM |
| Removing the Inner Tub | rackumsucker | Dishwasher Repair | 0 | 01-21-2012 09:09 AM |
| Removing the top | massey9895 | Washer Repair | 1 | 08-19-2011 05:39 PM |
| Removing GE tub nut | richappy | Washer Repair | 2 | 07-12-2010 01:39 AM |
| Removing hub | msggis | Washer Repair | 0 | 03-16-2010 09:54 AM |
