| » I NEED HELP whith rifrigerrator |
Model Number: MFI 2568 AEW Brand: Maytag Age: 1 - 5 years
Hello my is name joel I have 06 maytag refrigerator. My maytag is acting up. the control pannel lights are blinking and the ice dispenser is flapping. I replace the main circuit pannel and flapping stoped. but now the pannel is flashing a code PEO 000 and it dose not let me program anthing on control pannel. what should i do now?
Here is the tech sheet
http://www.servicematters.com/docs/w...2012827965.pdf Perhaps all it needs is setting up.
__________________
Quote:
i did as you suggest but the pannel still blinks with PE on the freezer side and 0000 on the refridgerator side and will not let us prograhm at all. what do you think now? thank you for your time. joel |
Here is a service manual
http://www.servicematters.com/maytag...s/16026312.pdf Here is an earlier tech sheet http://www.servicematters.com/maytag...s/16026830.pdf PE does indicate that you are stuck in programming mode. I would disconnect/reconnect the keypad perhaps it is just a bad connection. Try to run the diagnostics. Since you cannot program the unit it could be that the keypad is toast. Cannot find info on how to definitively diagnose the keypad so it is a guess. There is always a possibility that you have a received a bad control board. Hopefully someone else will jump in with additional help.
__________________
| Display Modes | |
