Discuss
PTC starter substitute for 8EA4B3
 in
Refrigerator & Freezer Repair
I need your help. The PTC starter in my Kenmore refrigerator, model 795.75196400 just died. A replacement from Sears are
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » PTC starter substitute for 8EA4B3
  #1 (permalink)
Old 05-28-2012, 08:34 PM
Junior Member
spot is on a distinguished road
Default PTC starter substitute for 8EA4B3
Model Number: 795.75196400   Brand: Kenmore   Age: 5 - 10 years
I need your help.
The PTC starter in my Kenmore refrigerator, model 795.75196400 just died. A replacement from Sears are no longer available. The part is a three terminal part labeled 8EA4B3. Only two of the terminals are connected. The third is unused. According to http://rc.danfoss.com/TechnicalInfo/...4_ct31c102.pdf 8EA14C3 is a replacement. AppliancePartsPros indicates that the PTC starter LG 6748JA3001A (part AP4857702) would work for my refrigerator, and also refrigerators LG LRTB2023BS and LG LRTPC1831T. Repair Clinc confirms but AP4857702 is also unavailable.
Parts Store indicates that 6748C0004D is a substitute for 6748JA3001A which would mean that it should work for the cited LG refrigerators. This part is widely available. However I cannot find anyone saying that 6748C0004D is compatible with Kenmore 795.75196400, so I am not sure.
The main board has a 12uF, which I assume is a run capacitor. According to Whirlpool Start Relay 2262181 Part# Variants? the broken part can be replaced with GE WR07X10051.
From what I can tell any of the following would work:
  • GE WR07X10051
  • LG 6748C0004D (aka AP4439465)
  • AP4857702 (not unavailable)
  • any others?
It seems like there are lots of different mfg part numbers that use similar (if not identical) PTC starter relays. But I'm not sure.
Any ideas on which available PTC starters are compatible with a kenmore is with an EGZ 80HLP compressor?
Thank you.
Ads By Google
Related Models
Magic Chef 79F-5EXW
Magic Chef 79FA-5EVW
Magic Chef 79FA-5EXW
Magic Chef 79FK-5EVW
Magic Chef 79FK-5EXW Walloven - S/c Ele
Magic Chef 79FN-5EVW Walloven - S/c Ele
Magic Chef 79FN-5EXW Walloven - S/c Ele
Whirlpool 7CSE3A1
Whirlpool 7CSE3W1
Whirlpool 7CSE5A2
Whirlpool 7CSE5W2
Whirlpool 7DP840CWDB0
Whirlpool 7DP840CWDB1
Whirlpool 7DP840DWGX0
Whirlpool 7DP840SWKX0 Portable Dishwasher
Whirlpool 7DP840SWKX1 Portable Dishwasher
Whirlpool 7DP840SWSX0 Portable Dishwasher
Whirlpool 7DU1100XTSQ0 Undercounter Dishwasher
Whirlpool 7DU1100XTSS0 Undercounter Dishwasher
Whirlpool 7DU840CWDB0
Whirlpool 7DU840CWDB1
Whirlpool 7DU840DWGX0
Whirlpool 7DU850SWSQ0 Undercounter Dishwasher
Whirlpool 7DU900PCDB0
Whirlpool 7DU900PCDQ0
Whirlpool 7DU900PCDQ1
Whirlpool 7DU900PCDQ2
Whirlpool 7DU910PFGB0
Whirlpool 7DU912PFGQ0
Whirlpool 7DU920PWKB0 Undercounter Dishwasher
Whirlpool 7DU920PWKQ0 Undercounter Dishwasher
Whirlpool 7DU920PWKS0 Undercounter Dishwasher
Whirlpool 7ED0GTQXKQ00
Whirlpool 7ED0GTQXKQ01
Whirlpool 7ED0GTQXKQ02 Refrigerator
Whirlpool 7ED0GTQXMQ00 Refrigerator
Whirlpool 7ED20TKXDN00
Whirlpool 7ED20TKXDN01
Whirlpool 7ED20TKXDN02
Whirlpool 7ED20TQXFW00
Whirlpool 7ED20TQXFW01
Whirlpool 7ED20TQXFW02
Whirlpool 7ED20TQXFW03
Whirlpool 7ED20TQXFW04
Whirlpool 7ED20TQXFW05
Whirlpool 7ED22PQXDN00
Whirlpool 7ED22PQXDN01
Whirlpool 7ED22PQXFN00
Whirlpool 7ED22PQXFN01
Whirlpool 7ED22PQXFW00
Whirlpool 7ED22PQXFW01
Whirlpool 7ED25DQXFW00
Whirlpool 7ED25DQXFW01
Whirlpool 7ED25DQXFW02
Whirlpool 7ED25PQXDW00
Whirlpool 7ED25PQXDW01
Whirlpool 7ED25PQXDW02
Whirlpool 7ED27DQXDN00
Whirlpool 7ED27DQXDN01
Whirlpool 7ED27DQXDN02
Whirlpool 7ED27DQXDW02
Whirlpool 7ED27DQXFN00
Whirlpool 7ED27DQXFN01
Whirlpool 7ED27DQXFN02
Whirlpool 7ED27DQXFW00
Whirlpool 7ED27DQXFW01
Whirlpool 7ED27DQXFW02
Whirlpool 7ED2GTQXPL00 Refrigerator
Whirlpool 7ED2GTQXPL01 Refrigerator
Whirlpool 7ED2GTQXPQ00 Refrigerator
Whirlpool 7ED5FHEXMS00 Refrigerator
Whirlpool 7ED5FHEXRS00 Refrigerator
Whirlpool 7ED5FTGXKT00
Whirlpool 7ED5FTGXKT01
Whirlpool 7ED5FTGXKT02 Refrigerator
Whirlpool 7ED5GHGXMQ00 Refrigerator
Whirlpool 7ED7FHGXKQ00
Whirlpool 7ED7FHGXKQ01
Whirlpool 7EH050FXRQ00 Chest Freezer
Whirlpool 7ET18PKXDN00
Whirlpool 7ET18PKXDN01
Whirlpool 7ET18PKXDW00
Whirlpool 7ET18PKXFN00
Whirlpool 7ET18ZKXDN00
Whirlpool 7ET18ZKXDN01
Whirlpool 7ET18ZKXDW00
Whirlpool 7ET1FTKXRQ00 Refrigerator
Whirlpool 7ET20PKXDN00
Whirlpool 7ET20PKXDN01
Whirlpool 7ET20PKXDW00
Whirlpool 7ET21PKXFN00
Whirlpool 7ET21PKXFW00
Whirlpool 7ET21PKXGW00
Whirlpool 7ET22DMXGW00
Whirlpool 7GB8SHKXKB00
Whirlpool 7GB8SHKXKQ00
Whirlpool 7GD22DFXFW00
Whirlpool 7GD22DFXFW01
Whirlpool 7GD22DFXFW02
Whirlpool 7GD22DFXFW03
Whirlpool 7GD25DFXFW00
Whirlpool 7GD25DFXFW01
Whirlpool 7GD25DFXFW02
Whirlpool 7GD25SFXHS00
Whirlpool 7GD25SFXHS01
Whirlpool 7GD25SFXHS02
Whirlpool 7GD27DFXFT00
Whirlpool 7GD27DFXFT01
Whirlpool 7GD27DFXFT02
Whirlpool 7GD27DFXFW00
Whirlpool 7GD27DFXFW01
Whirlpool 7GD27DFXFW02
Whirlpool 7GD27DIXHB00
Whirlpool 7GD27DIXHB01
Whirlpool 7GD27DIXHS00
Whirlpool 7GD27DIXHS01
Whirlpool 7GD27DIXHT00
Whirlpool 7GD27DIXHT01
Whirlpool 7GD27DIXHW00
Whirlpool 7GD27DIXHW01
  #2 (permalink)
Old 05-29-2012, 04:07 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
Did you note which fridg wires went to which ptc device terminal? If so, I would use the GE ptc device, cheaper and much more reliable, just wire it up per the old one.
__________________
  #3 (permalink)
Old 05-30-2012, 08:29 PM
Junior Member
Default
Quote:
I noted the original wiring when I removed the original 8EA4B3 PTC. As you suggested I reused the same wiring pattern with the new GE WR07X10051 PTC. I installed it and it is working great. Thanks for the help!
For reference I noted the wiring pattern. When mounted on the compressor and looking at the PTC relay, pin 3 is on the bottom right and connected to an orange wire; pin 2 is in the bottom left connected to a blue wire.
  #4 (permalink)
Old 05-31-2012, 01:52 AM
Senior Expert
APP Volunteer
Default
Very good work, as I said before, you must wire it up the same as the old device or you will burn out the start winding. Thousands of customers use this ptc device when it is listed as a direct replacement with no problem as long as they wire it the same as the old one.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Substitute Secondary Coil benito_76 Dryer Repair 3 10-04-2010 06:24 AM
Gas Re-Igniter Substitute Part richard111 Oven Repair (including Ranges and Cooktops) 1 04-13-2009 06:23 PM
Need New Or Substitute Door End Cap WALLY WEBER Microwave Repair 0 03-19-2009 01:10 PM
Substitute magnetron tom12345 Microwave Repair 7 03-16-2009 05:29 PM
substitute lid latch? helpme1 Washer Repair 0 03-09-2009 05:09 PM
