Discuss
beyond help
 in
Refrigerator & Freezer Repair
it started with no lites to control board, changed hv board to restore. added code 1720 to reset. found that
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » beyond help
  #1 (permalink)
Old 05-28-2012, 07:13 PM
Junior Member
8594 is on a distinguished road
Default beyond help
Model Number: mfi2269vea1   Brand: Whirlpool   Age: 1 - 5 years
it started with no lites to control board, changed hv board to restore. added code 1720 to reset. found that the compressor start relay rattled so i replaced it. now it appears to run but not cool. checked winding s of compressor with resistances of r to c 4.2 ohms,s to c 7.4 ohms, and r to s 12.5 ohms. not resistance to case on all contact points. compressor when on does not get hot. condensor,evapoator,and ice maker fans run. evaporator coils do not get cold and the defrost is not hot. from control panel i entered the service code check list,code 101 off,102 runs, 112 and 113 runs 0.0-7.75-12volts,121 -131 toggle,141 temp 79,142 temp 75, 144 temp 86,and 145 temp 75,151-152-153-163-164-165-167-168-171-172-175-182-193 toggle. 182 lites blink.192 off. no changes from default 201-202-203-211-212-213. used 221 to set to default.did not enter service tests, i did record readings.301 ---,308-309 0.0,311 to 317 25.5,318-3119 0.0,321 ---,328-329 0.0, 331 ---,338-339 0.0,341 to 347 ---,348 349 0.0, 351 ---,358 0,359 na,401 na, 501 on. what do think is the fix?
Ads By Google
Related Models
Maytag MFI2568AEB Ref - Bottom Mounts
Maytag MFI2568AEB12 Refrigerator
Maytag MFI2568AEQ Ref - Bottom Mounts
Maytag MFI2568AEQ12 Refrigerator
Maytag MFI2568AES Frigidaire/refrigerator
Maytag MFI2568AES12 Refrigerator
Maytag MFI2568AEW Ref - Bottom Mounts
Maytag MFI2568AEW12 Refrigerator
Maytag MFR18MCAAS Washer - Top Loading
Maytag MFR18MCAVS Washer - Top Loading
Maytag MFR18PCAAS Washer - Top Loading
Maytag MFR18PCAVS Washer - Top Loading
Maytag MFR18PDAAS Washer - Horizontal Axis
Maytag MFR18PDAVS Washer - Horizontal Axis
Maytag MFR18PDCWS Washer - Horizontal Axis
Maytag MFR25MCATS Washer - Horizontal Axis
Maytag MFR25MCAVS Washer - Horizontal Axis
Maytag MFR25PCATS Washer - Horizontal Axis
Maytag MFR25PCAVS Washer - Horizontal Axis
Maytag MFR25PDATS Washer - Horizontal Axis
Maytag MFR25PDAVS Washer - Horizontal Axis
Maytag MFR25PDCWS Washer - Horizontal Axis
Maytag MFR30PDCTS 29" Gas Dryer
Maytag MFR30PNCTS Washer - Horizontal Axis
Maytag MFR35MCATS Washer - Horizontal Axis
Maytag MFR35MCAVS Washer - Horizontal Axis
Maytag MFR35MNATS Washer - Top Loading
Maytag MFR35MNAVS Washer - Top Loading
Maytag MFR35PCATS Washer - Horizontal Axis
Maytag MFR35PCAVS Washer - Horizontal Axis
Maytag MFR35PDATS Washer - Horizontal Axis
Maytag MFR35PDAVS Washer - Horizontal Axis
Maytag MFR35PNAVS Washer - Horizontal Axis
Maytag MFR35PNBVS Washer - Top Loading
Maytag MFR40PDCTS Washer - Horizontal Axis
Maytag MFR40PNCTS Washer - Horizontal Axis
Maytag MFR50MCATS Washer - Top Loading
Maytag MFR50MCAVS Washer - Top Loading
Maytag MFR50MNAVS Washer - Top Loading
Maytag MFR50PCATS Washer - Top Loading
Maytag MFR50PCAVS Washer - Top Loading
Maytag MFR50PDATS Washer - Horizontal Axis
Maytag MFR50PDAVS Washer - Horizontal Axis
Maytag MFR50PDCTS Washer - Horizontal Axis
Maytag MFR50PNAVS Washer - Top Loading
Maytag MFR50PNBVS Washer - Top Loading
Maytag MFR60PDCTS Washer - Horizontal Axis
Maytag MFR60PNCTS Washer - Horizontal Axis
Maytag MFR80PCAVS Washer - Top Loading
Maytag MFR80PDAVS Washer - Top Loading
Maytag MFR80PDCTS Washer - Horizontal Axis
Maytag MFR80PNCTS Washer - Horizontal Axis
Maytag MFS100PAVS Washer - Horizontal Axis
Maytag MFS100PFVS Washer - Horizontal Axis
Maytag MFS125PAVS Washer - Horizontal Axis
Maytag MFS125PFVS Washer - Horizontal Axis
Maytag MFS25PNAVS Washer - Top Loading
Maytag MFS25PNFTS Washer - Horizontal Axis
Maytag MFS35PNAVS Washer - Top Loading
Maytag MFS35PNDVS Washer - Top Loading
Maytag MFS35PNFTS Washer - Horizontal Axis
Maytag MFS50PNAVS Washer - Top Loading
Maytag MFS50PNDVS Washer - Top Loading
Maytag MFS50PNFVS Washer - Horizontal Axis
Maytag MFS75PNAVS Washer - Top Loading
Maytag MFS80PNAVS Washer - Top Loading
Maytag MFS80PNDVS Washer - Top Loading
Maytag MFS80PNFVS Washer - Horizontal Axis
Maytag MFS90PNAVS Washer - Horizontal Axis
Frigidaire MFU05M3AW0 Frg(v1) / Upright Freezer
Frigidaire MFU05M3AW1 Frg(v0) / Upright Freezer
Frigidaire MFU07M3AW0 Frg(v1) / Upright Freezer
Frigidaire MFU07M3AW1 Frg(v0) / Upright Freezer
Frigidaire MFU09M2AW0 Tap(v7) / Upright Freezer
Frigidaire MFU09M2AW1 Tap(v8) / Upright Freezer
Frigidaire MFU09M2BW0 Tap(v4) / Upright Freezer
Frigidaire MFU09M2BW1 Frg(v1) / Upright Freezer
Frigidaire MFU09M2BW2 Frg(v0) / Upright Freezer
Frigidaire MFU09M2BW3 Frg(v0) / Upright Freezer
Frigidaire MFU09M2BW4 Frg(v0) / Freezer
Frigidaire MFU09M2GW0 Frg(v0)
Frigidaire MFU09M2GW2 Frg(v0) / Freezer
Frigidaire MFU09M2GW3 Frg(v0) / Freezer
Frigidaire MFU09M2GW4 Frg(v0) / Freezer
Frigidaire MFU09M2GW5 Frg/freezer
Frigidaire MFU09M2GW6 Frigidaire/freezer
Frigidaire MFU12M0BW0 Tap(v4) / Upright Freezer
Frigidaire MFU12M0BW1 Frg(v1) / Upright Freezer
Frigidaire MFU12M0BW2 Frg(v0) / Upright Freezer
Frigidaire MFU12M0BW3 Frg(v0) / Upright Freezer
Frigidaire MFU12M0BW4 Frg(v0) / Freezer
Frigidaire MFU12M0GW0 Frg(v0)
Uni MFU12M0GW2 Frigidaire/freezer
Frigidaire MFU12M2AW0 Tap(v10) / Upright Freezer
Frigidaire MFU12M2AW1 Tap(v11) / Upright Freezer
Frigidaire MFU12M2AW2 Tap(v12) / Upright Freezer
Frigidaire MFU12M2BW0 Tap(v4) / Upright Freezer
Frigidaire MFU12M2BW1 Frg(v1) / Upright Freezer
Frigidaire MFU12M2BW2 Frg(v0) / Upright Freezer
Frigidaire MFU12M2BW3 Frg(v0) / Upright Freezer
Frigidaire MFU12M2BW4 Frg(v0) / Freezer
Frigidaire MFU12M2GW0 Frg(v0)
Frigidaire MFU12M2GW1 Frigidaire/freezer
Frigidaire MFU12M2GW2 Frigidaire/freezer
Frigidaire MFU14D2FW0 Frg(v0) / Freezer
Frigidaire MFU14D2FW1 Frg(v0) / Freezer
Frigidaire MFU14D2GW0 Frg(v0)
Frigidaire MFU14F1EW0 Frg(v0) / Upright Freezer
Frigidaire MFU14F1EW1 Frg(v0) / Upright Freezer
Frigidaire MFU14F1EW2 Frg(v0) / Freezer
Frigidaire MFU14F1GW0 Frg(v0)
Frigidaire MFU14F1GW1 Frg(v1)
Frigidaire MFU14F1GW2 Frg(v2)
Frigidaire MFU14F3BW0 Frg(v1) / Upright Freezer
Frigidaire MFU14F3BW1 Frg(v1) / Upright Freezer
Frigidaire MFU14F3BW2 Wwh(v0) / Freezer
Frigidaire MFU14F3BW3 Frg(v0) / Upright Freezer
Frigidaire MFU14F3BW4 Frg(v0) / Upright Freezer
Frigidaire MFU14F3BW5 Frg(v0) / Upright Freezer
Frigidaire MFU14F3BW6 Frg(v1) / Freezer
  #2 (permalink)
Old 05-29-2012, 03:56 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
The compressor should get hot and vibrate. If not, you might have a shorted compressor that took out the hv board. Simple, low voltage ohm checks will not determine status. Get a meter and check for voltage to the compressor.
__________________
  #3 (permalink)
Old 05-29-2012, 04:17 PM
Junior Member
Default beyond help
richappy,
using a fluke 83 volt ohm meter and a fluke 33 amp meter i see 123.8 volts accross the black and white wires going to the start relay .o7 amps induced in wire. the compressor feels warmer than 98.6 but not to hot to keep your hand on the compressor and you can here the compressor kick in when apping power.
  #4 (permalink)
Old 05-30-2012, 04:14 AM
Senior Expert
APP Volunteer
Default
Remove the start device, I assume similar to the AP4433935 item and check ohms between the common compressor pin, usually on top and either device input pin, one should read zero ohms, if not, your compressor blew open the internal overload device.
__________________
  #5 (permalink)
Old 05-30-2012, 12:15 PM
Junior Member
Default beyond help
as in my post the winding resistance to common was 4.2 ohms to run and 7.4 ohms to start and 12.5 ohms from start to run. if i had no resistance then a winding would be open and i would not hear the compressor running.
  #6 (permalink)
Old 05-30-2012, 02:59 PM
Senior Expert
APP Volunteer
Default
I wanted you to check the start device, not the compressor!
__________________
  #7 (permalink)
Old 06-01-2012, 01:05 PM
Junior Member
Default beyond help
oh, sorry, i have replaced both the relay and cap. unless it was bad from the supplier. i will check it.
  #8 (permalink)
Old 06-04-2012, 04:53 PM
Junior Member
Default beyondhelp
hello richappy.
well i put a second new ptc on compressor with no help. went and put a line tap on the low pressor side to check if there was any coolant. nope -40 inhg reading. added a little r134a to system and it started to get cold and compressor is really hot now. i now read -10 inhg. at 77 dec room temp. what pressure should i read? no clue? compressor is a EMBRACO EGX70HLC
i am also pulling 2 amps of current when set to fast cool-6/33. controls set to 0-38dec frezzer/ fridg. what do think?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
