Fridge Not staying cold :(
Brand: Kitchen Aid Age: 1 - 5 years
Im unclear on the part number for this i cant seem to find a tag? maybe i need to look harder or someone can tell me where they are located.The fridge has a bottom freezer with pull out and french style front doors.It is a counter depth fridge and all stainless.It has a digital gauge inside to set temps.It no longer holds the proper temps.I talked to some tech off of craigslist and i ended up pulling off the back panel and found to me what looked like a relay.I pulled it out and replugged it back in and it started to work again and get up to temp but not long after it didnt hold temp again.Should i be looking to replace the relay or is that not the root of the problem...the tech told me its usually a compressor working to hard to so go out...any help would be appreciated.-Kyle
Ads By Google
