| » 3.5 cu freezer |
Hi.
Most likely it's bad thermostat (cold control). To check lightly knock on the controls knob with screw driver's butt, or to be more scientific you can check the continuity between two thermostat contacts. If no continuity - replace the thermostat. The thermostat Part number: WPF24B-L Good luck. Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Thank you for the information. but where is the thermostat?
shanshan Quote:
On the freezer's side at the bottom look for the round knob where the control panel with the light is.
Thank you. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. Last edited by Simon / APP Team : 05-22-2012 at 01:45 PM. |
There is nothing on the side at the bottom as you described.
But i opened the cover for the panel on the side at the lower part. After the plug was put in, I heard a light "pop" sound coming from the part of the big "pot" (i am not sure if this is the condensor?), then some noise started which sounded it worked, but just after 10 seconds, the "pop" sounded again, then all noise stopped. I hope this details could provide you more information. Please guide me, i need the freezer as soon as possible. Thanks! |
Hi.
Based on information you provided this time the problem may be bad compressor or it's starting components. To check the compressor you need a multimeter and basic knowledge how to use it. With out that you can take a shot of replacing starting components. The PTC starter Part number: MCCF5/7WBX-57 The compressor protector Part number: QDH4311G/MP Here are the breakdown diagram and Replacement parts for Magic Chef MCCF5WBX CHEST FREEZER | AppliancePartsPros.com Good luck. Simon.
__________________
If it is due to compressor, it will be expensive, also it is too complicated to me to change the parts (actually it is out of stock)
shanshan Quote:
You are very welcome.
Simon.
__________________
| Display Modes | |
| Amana fridge bottom freezer warm; lights, freezer fan works | sdjacksfan | Refrigerator & Freezer Repair | 1 | 03-06-2012 02:08 PM |
| freezer working good frig not cold no frost on freezer coils | ch123 | Refrigerator & Freezer Repair | 1 | 06-13-2011 04:41 AM |
| Whirlpool Freezer Model EV201NXMQ02 intermittently defrosts freezer contents | NeedToKnow2000 | Refrigerator & Freezer Repair | 3 | 06-02-2011 02:46 AM |
| Whirlpool Freezer Model EV201NXMQ02 intermittently defrosts freezer contents. Defrost | NeedToKnow2000 | Refrigerator & Freezer Repair | 0 | 05-29-2011 10:17 AM |
| frost free refrigerator/freezer frosting over on back wall or bottom freezer | bwheeler | Refrigerator & Freezer Repair | 2 | 01-31-2011 07:16 AM |
