Discuss
Upright Freezer
 in
Refrigerator & Freezer Repair
Our 5 yr old Kenmore freezer, upright has ice on the floor of the freezer as well as blocking the
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Upright Freezer
  #1 (permalink)
Old 01-23-2008, 07:27 PM
delongbeth delongbeth is offline
Junior Member
delongbeth is on a distinguished road
Default Upright Freezer
Model Number: 253.21421104   Brand: Kenmore   Age: 5 - 10 years
Our 5 yr old Kenmore freezer, upright has ice on the floor of the freezer as well as blocking the back drain in the wall. We defrosted it (it is a self defrosting freezer) and reset everything, but it appears ice is forming again. Any ideas? The freezer is freezing ok for the moment
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-24-2008, 10:19 AM
kawfeeman kawfeeman is offline
Senior Expert
APP Volunteer
kawfeeman is on a distinguished road
Default
can you take a turkey baster and push water through the cond drain hole ?
__________________
regards
jim
  #3 (permalink)
Old 01-24-2008, 07:28 PM
Junior Member
Default kenmore freezer
I will try this, what if water does go thru?
Quote:
  #4 (permalink)
Old 01-25-2008, 05:09 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
I use very hot water with the turkey baster to get the drain working, then I wrap a heavy gauge copper wire around the defrost heater, then down the drain. This should fix your problem.
__________________
  #5 (permalink)
Old 01-25-2008, 06:36 AM
Senior Expert
APP Volunteer
Default
just keep trying to push the water through.. start slow and work your way up the ladder slowly ...
__________________
regards
jim
  #6 (permalink)
Old 01-25-2008, 09:42 AM
Junior Member
Default Upright Freezerq
Ok, we tried this and water does go throught the drain. It appears that the defrost heater (is that a copper tubing?) is under the back of the freezer. That being the case, shoudl we wrap the copper wire around the defrost heater and UP throught the drain? We we first discovered the problem, the was a cover on the drain plug. We removed it. Was it supposed to be there?
  #7 (permalink)
Old 01-26-2008, 05:36 AM
Senior Expert
APP Volunteer
Default
You wrap the wire around the defrost heater located behind the back freezer panel, then down the drain!
__________________
  #8 (permalink)
Old 01-26-2008, 04:57 PM
Junior Member
Ok, I see, that would mean I remove the panel to do this. Correct?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Upright Freezer Compressor does not kick on Kaye Refrigerator & Freezer Repair 7 01-15-2008 10:43 AM
Upright Freezer Help cpinke15 Refrigerator & Freezer Repair 1 11-21-2007 11:29 AM
High Temperature in Upright Freezer timb Refrigerator & Freezer Repair 0 09-04-2007 11:06 AM
Gibson Upright Freezer making loud buzzing noise..... kakizie Refrigerator & Freezer Repair 0 08-02-2007 04:42 PM
loose seal used upright freezer tcarlson762 Refrigerator & Freezer Repair 1 07-25-2007 12:02 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
