| » Water Supply Valve |
Model Number: GSH22JST Brand: GE Age: 1 - 5 years
Is there a screen on the water supply inlet of the water supply valve that may get clogged and prevent water flow after the solinoid is activated? My outdoor water meter was replaced by the utility company and immediately thereafter the water dispenser in the refrigerator door and the icemaker ceased working. I suspect that dirt entered the system during the change out of the meter and migrated to the water supply valve and clogged or caused a failure of the valve?
Hi.
The water valve installed in your fridge is not serviceable. Disconnect the water line from the inlet valve to check if there is water pressure coming to the fridge. Be carefull not to flood the house. Check if there is a 120VAC at the water valve solenoid when the lever is pressed. Please, post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. Last edited by Simon / APP Team : 05-18-2012 at 01:06 PM. |
| Display Modes | |
| broken supply line to the water inlet valve | mrsrjb | Refrigerator & Freezer Repair | 1 | 03-29-2012 03:23 AM |
| GE Profile leaking water for cold water supply into drum when not in use | venicebeachvillas | Washer Repair | 4 | 12-08-2011 06:06 AM |
| Water leaking out of refigerator that is not connected to a water supply | leekyfridge | Refrigerator & Freezer Repair | 1 | 12-05-2011 08:02 PM |
| Water supply | cemcclemens24 | Refrigerator & Freezer Repair | 3 | 01-26-2011 02:41 PM |
| no water supply | tkhighlander | Refrigerator & Freezer Repair | 1 | 08-10-2008 10:18 PM |
