Discuss
ice maker fill tube freezing
 in
Refrigerator & Freezer Repair
water quit coming from the door dispenser just a click and a hum, but ice still dispensed, now the ice
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » ice maker fill tube freezing
  #1 (permalink)
Old 01-23-2008, 04:05 PM
ricka ricka is offline
Junior Member
ricka is on a distinguished road
Question ice maker fill tube freezing
Model Number: tfx28pbda bb   Brand: GE   Age: 1 - 5 years
water quit coming from the door dispenser just a click and a hum, but ice still dispensed, now the ice maker fill tube is freezing up. The fan in the ice maker seems to keep running till I turn the freezer setting to almost off.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-24-2008, 03:27 PM
Gene's Avatar
Gene Gene is online now
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
The first thing I would check is the water filter (#790 on the #5 break down diagram). If the filter is more then a year old, it could be clogged causing the restriction to the water flow.
If there is frost in the ice maker water feeding tube - the water inlet valve has to be replaced.
- The part number for the water inlet valve is AP2071736
- The part number for the water filter is MWF
Here are the break down diagrams for the GE refrigerator Model TFX28PBDABB
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 01-24-2008, 07:18 PM
Junior Member
Default
hi Gene. Thanks for your response. I have since unplugged the fridge and plugged it back. I was checking he icemaker tube, when I burnt my finger on the element under the ice cube tray and now it is not frozen. I hope that the thermostat was in need of resetting and that fixed it. Everything seems to be working now, but the water dispenser in the door. So you think it is the water fill valve? I was told that it is a power module. I like your part better. It is a lot cheaper.
  #4 (permalink)
Old 01-25-2008, 07:07 AM
kawfeeman kawfeeman is offline
Senior Expert
APP Volunteer
kawfeeman is on a distinguished road
Default
the question is not or should not be price. It costs more to replace what is cheaper and then have to replace the what is correct. Listen to the PRO! I'd put odds on GENE !!!
__________________
regards
jim
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Ice Maker fill adustment??? mikekarenhuff@yahoo.com Refrigerator & Freezer Repair 0 01-05-2008 10:53 AM
ice maker freezing up coneman Refrigerator & Freezer Repair 1 12-14-2007 04:23 PM
ice maker - water freezing in tube lannym Refrigerator & Freezer Repair 1 12-01-2007 04:07 PM
Water leak on front side of ice maker after fill trentrb211 Refrigerator & Freezer Repair 0 10-22-2007 11:53 AM
Ice maker still leaking - Just replaced fill valve Adam80 Refrigerator & Freezer Repair 1 09-12-2007 08:09 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
