| » Ice build up in bottom of freezer, water leaks out door |
Model Number: FRS26ZRG Brand: Frigidaire Age: 5 - 10 years
Had the problem of ice building up on the bottom of the freezer and leaking out the freezer door. Took the back panel off and used a hair dryer to melt the ice and clear the drain hole. within 2 days I notice the ice build up is back. What could be causing the drain hole to keep freezing up? If it were the defrost timer or heater element not working, the ice on the coils wouldn't melt and drain to the bottom of the freezer, right?
Quote:
Thanks for the response, ThatGuy. I did remove the back and clear the drain hole with a hairdryer, put a flexible rod down to verify it being clear. One day later the ice is back. It has to be defrosting or the water wouldn't be draining and freezing in the bottom of the compartment? Wonder what would make the drain hole keep freezing up? Thanks again!
I'd say you still have something plugging up the drain. Try pouring water into it and sucking it out with a shopvac, or blowing it out with compressed air. That water should drain out before the Refrig. starts back up after defrosting. If it doesn't it will freeze in the tube. I usually see mold growing down in the elbow, that's why I said to use hot water.
| Display Modes | |
| Whirlpool french door freezer leaks from the bottom | geniustff | Refrigerator & Freezer Repair | 1 | 03-26-2012 03:37 PM |
| Ice Build-up in fridge on top freezer on Bottom | Raymo01 | Refrigerator & Freezer Repair | 2 | 12-18-2011 09:52 PM |
| Ice build up on bottom of freezer side | leonet99 | Refrigerator & Freezer Repair | 1 | 11-19-2008 12:16 PM |
| Whirlpool Freezer with ice build up @ bottom | indelible5 | Refrigerator & Freezer Repair | 6 | 10-20-2008 10:34 AM |
| ice build up in the bottom of the freezer | lauder | Refrigerator & Freezer Repair | 1 | 08-22-2007 07:53 PM |
