| » GE Profile side by side leaking in fornt of freezer door |
Hi.
Please provide the complete model number of the fridge. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Hi.
You are facing the task of cleaning frozen condensation drain line. It's located behind the rear cover in the freezer at the bottom. It's a bit of the challenge but YOU can do it. Use the hair dryer and hot water to defrost the drain. Best if you will be able to blow in to it,using the plastic tube. Here are the breakdown diagrams and Replacement parts for General Electric PSW26SGPASS Refrigerator | AppliancePartsPros.com Good luck. Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. Last edited by Simon / APP Team : 05-09-2012 at 03:02 PM. |
Well, I did the repair suggested above, removed the rear freezer panel and used a hair dryer and homemade funnnel/tube to direct hot air into the condensate drain. Probably kept the hair dryer on it for at least 15 minutes. Put it all back together and checked it today (3days later). I'm sorry to say the repair did not work. Any other advice? I'm about to throw this $2200 refrigerator away.
Hi.
Before closing the panel did you pour hot water into the drain to check if it's open? It doesn't matter for how long you used the blow dryer if the drain is still blocked. Simon.
__________________
Hi.
Yes there is the drip tray at the end of the drain line. If you open the rear cover at the back of the fridge you will see the drain tube. Pour a cup of hot water in to the drain and see if it comes trough. Simon.
__________________
GE mod# PSI23NGMD BB
I have the same problem and the drain line isn't plugged! There is a small pan in the freezer under the condenser lines that catches the water when the freezer goes into defrost mode. This pan has a drain hole in it that rests on top of the drain line. My leak originates here, between the drain hole and the drain line. There is no gasket or sealed connection and enough excess water escapes to run down the back inside wall of the freezer. It accumulates in the shallow recess in the bottom of the freezer. In about 4 days, the recess fills...then overflows during the next defrost cycle. Any ideas on how I can fix this??? Thanks |
Hi.
Check if the drain pan is properly aligned with the drain hole. Correct if needed. Simon.
__________________
| Display Modes | |
| GE Profile Side by Side High Temps Fridge/Freezer | Suburbangirl | Refrigerator & Freezer Repair | 0 | 03-29-2012 07:55 PM |
| GE Profile Performance Side by Side Refrig/Freezer | eviemail | Refrigerator & Freezer Repair | 1 | 01-31-2011 06:01 AM |
| GE Profile Arctica Side by Side is staying at around 20 F in the Freezer side | Lakesun | Refrigerator & Freezer Repair | 0 | 11-25-2010 10:22 AM |
| Side by side freezer low cool & leaking water | GregS | Refrigerator & Freezer Repair | 0 | 06-03-2010 06:12 AM |
| GE Profile frig leaking water under freezer side | marktwain | Refrigerator & Freezer Repair | 2 | 08-12-2009 03:59 PM |
