Discuss
Ice maker will not draw water but water in door works normally
 in
Refrigerator & Freezer Repair
Ice maker will not draw water but water in door works normally Whirlpool Model ED25QFXHT02 Number on ice maker 106
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Ice maker will not draw water but water in door works normally
  #1 (permalink)
Old 01-23-2008, 10:24 AM
Junior Member
kg1okc is on a distinguished road
Default Ice maker will not draw water but water in door works normally
Model Number: ED25QFXHT02   Brand: Whirlpool   Age: 1 - 5 years
Number on ice maker 106 626636
Can manually fill ice maker with water and it will freeze and eject normally.
Switched wires at inlet valve and water will fill ice maker by pressing door water dispenser, so fill tube is not frozen and valve works to pump water to either ice maker or door dispenser, switched back and door water dispenser works normally again.
Changed complete ice maker unit with same 106 626636 model from Kenmore refrigerator but still will not draw water, both units will freeze and eject ice normally after manual water fill. The older ice maker from the Kenmore refrigerator was working normally and new only a couple months before water supply was disconnected from that refrigerator.
Tested inline fuse in wiring connection which was good, but I knew that since both units will eject ice normally after manual fill.
What am I missing? I don't think it is the ice maker because both work normally after water is delivered. I don't think it is the valve or a frozen tube because I can switch the wires and pump water to the ice maker by the door water dispenser switch. Is there another part I have overlooked?
Ads By Google
Related Models
Whirlpool ED25QFXHT02
Whirlpool ED25QFXHW00
Whirlpool ED25QFXHW01
Whirlpool ED25QFXHW02
Whirlpool ED25RFXFB00
Whirlpool ED25RFXFB01
Whirlpool ED25RFXFB02
Whirlpool ED25RFXFB03
Whirlpool ED25RFXFN00
Whirlpool ED25RFXFN01
Whirlpool ED25RFXFN02
Whirlpool ED25RFXFN03
Whirlpool ED25RFXFW00
Whirlpool ED25RFXFW01
Whirlpool ED25RFXFW02
Whirlpool ED25RFXFW03
Whirlpool ED25RQXFN00
Whirlpool ED25RQXFN01
Whirlpool ED25RQXFN02
Whirlpool ED25RQXFW00
Whirlpool ED25RQXFW01
Whirlpool ED25RQXFW02
Whirlpool ED25RQXWW00
Whirlpool ED25RQXWW02
Whirlpool ED25RQXXW00
Whirlpool ED25RQXYW00
Whirlpool ED25RQXYW01
Whirlpool ED25RQXYW02
Whirlpool ED25SM1LWR0
Whirlpool ED25SM1LWR1
Whirlpool ED25SMXLWR0
Whirlpool ED25SMXLWR1
Whirlpool ED25SMXLWR2
Whirlpool ED25SMXRWR0
Whirlpool ED25SMXRWR2
Whirlpool ED25TEXHN00
Whirlpool ED25TEXHN01
Whirlpool ED25TEXHN02
Whirlpool ED25TEXHN03
Whirlpool ED25TEXHT02
Whirlpool ED25TEXHT03
Whirlpool ED25TEXHW00
Whirlpool ED25TEXHW01
Whirlpool ED25TEXHW02
Whirlpool ED25TEXHW03
Whirlpool ED25TQXEN00
Whirlpool ED25TQXEN01
Whirlpool ED25TQXEW00
Whirlpool ED25TQXEW01
Whirlpool ED25TQXFN00
Whirlpool ED25TQXFN01
Whirlpool ED25TQXFN02
Whirlpool ED25TQXFN03
Whirlpool ED25TQXFW00
Whirlpool ED25TQXFW01
Whirlpool ED25TQXFW02
Whirlpool ED25TQXFW03
Whirlpool ED25TQXGN00
Whirlpool ED25TQXGW00
Whirlpool ED25TWXDN00
Whirlpool ED25TWXDN01
Whirlpool ED25TWXDW00
Whirlpool ED25TWXDW01
Whirlpool ED25UEXHT00
Whirlpool ED25UEXHT01
Whirlpool ED25UEXHW00
Whirlpool ED25UEXHW01
Whirlpool ED25UQXGN00
Whirlpool ED25UQXGN01
Whirlpool ED25UQXGW00
Whirlpool ED25UQXGW01
Whirlpool ED25VFXHT00
Whirlpool ED25VFXHT01
Whirlpool ED25VFXHT02
Whirlpool ED25VFXHW00
Whirlpool ED25VFXHW01
Whirlpool ED25VFXHW02
Whirlpool ED25YQXAN00
Whirlpool ED25YQXAW00
Whirlpool ED26MK1LWR0
Whirlpool ED26MK1LWR1
Whirlpool ED26MKXLWR0
Whirlpool ED26MKXRWR0
Whirlpool ED26MM1LWR0
Whirlpool ED26MM1LWR1
Whirlpool ED26MMXLWR0
Whirlpool ED26MMXRWR0
Whirlpool ED26MMXRWR2
Whirlpool ED26MMXRWR3
Whirlpool ED26MMXRWR4
Whirlpool ED26SSXLWR0
Whirlpool ED26SSXLWR1
Whirlpool ED26SSXMWR1
Whirlpool ED26SSXRWR0
Whirlpool ED27DQXAB03
Whirlpool ED27DQXAB04
Whirlpool ED27DQXAB05
Whirlpool ED27DQXAN02
Whirlpool ED27DQXAN03
Whirlpool ED27DQXAN04
Whirlpool ED27DQXAN05
Whirlpool ED27DQXAW02
Whirlpool ED27DQXAW03
Whirlpool ED27DQXAW04
Whirlpool ED27DQXAW05
Whirlpool ED27DQXBB00
Whirlpool ED27DQXBB01
Whirlpool ED27DQXBB02
Whirlpool ED27DQXBN00
Whirlpool ED27DQXBN01
Whirlpool ED27DQXBN02
Whirlpool ED27DQXBW00
Whirlpool ED27DQXBW01
Whirlpool ED27DQXBW02
Whirlpool ED27DQXDB00
Whirlpool ED27DQXDB01
Whirlpool ED27DQXDB02
Whirlpool ED27DQXDB03
Whirlpool ED27DQXDB04
Whirlpool ED27DQXDN00
  #2 (permalink)
Old 01-23-2008, 04:04 PM
Junior Member
kmh1972 is on a distinguished road
Default
We are having the same issue with our Kenmore. I am going to try what you did on ours tonight and se if we have the same results. i also posted a thread today with similar problem I can see water in the ice supply sube up to the top but for some reason it will not pump the water into the maker.
  #3 (permalink)
Old 01-26-2008, 02:48 PM
Junior Member
hperalta64 is on a distinguished road
Default
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
  #4 (permalink)
Old 01-26-2008, 02:57 PM
Junior Member
Default ice maker not working
Kenmore refrigerator an ice maker not making ice. Water in door is fine. What do i check to find out what is the matter oith ice maker
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Water works/ No water to ice maker cyncityaz@hotmail.com Refrigerator & Freezer Repair 3 11-01-2009 04:15 PM
GE - No water to door - but ice maker works SterlingGray Refrigerator & Freezer Repair 1 08-24-2009 07:08 PM
water not getting to hose from pump but water dispencer works not ice maker sharbrat Refrigerator & Freezer Repair 0 07-29-2009 10:38 AM
no water to ice maker but i have water at glass filler in door johnelm@tds.net Refrigerator & Freezer Repair 6 07-25-2009 04:49 PM
Water to door dispnsr-No water to ice maker ffizzino Refrigerator & Freezer Repair 1 04-15-2009 03:07 PM
