Discuss
Freezer/Refigerator Cooling Issues
 in
Refrigerator & Freezer Repair
Hello! I have a 1991 (model year) Kenmore 21'' refrigerator that has just started to not cool properly. The freezer
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Freezer/Refigerator Cooling Issues
  #1 (permalink)
Old 05-07-2012, 08:08 AM
Junior Member
jimbolina is on a distinguished road
Default Freezer/Refigerator Cooling Issues
Model Number: 363.9701513   Brand: Kenmore   Age: More than 10 years
Hello!
The freezer is cold - but does not freeze the contents. The refrigerator section below, seems to stay cool, but I can't get it to go below 55 degrees. I've throughly vacuumed the condenser coils underneath, set the thermostat inside the fridge on a cooler setting, and it still doesn't get any cooler.
Where do I begin to troubleshoot?
Thanks!
Jim
Ads By Google
Related Models
Kenmore 3631401190 DISHWASHER
Kenmore 3631401191 DISHWASHER
Kenmore 3631401590 DISHWASHER
Kenmore 3631401591 DISHWASHER
Kenmore 3631401592 DISHWASHER
Kenmore 3631401890 DISHWASHER
Kenmore 3631401891 DISHWASHER
Kenmore 3631401892 DISHWASHER
Kenmore 3631402190 DISHWASHER
Kenmore 3631402191 KENMORE DISHWASHER
Kenmore 3631402192 DISHWASHER
Kenmore 3631402590 DISHWASHER
Kenmore 3631402591 DISHWASHER
Kenmore 3631402592 DISHWASHER
Kenmore 3631402890 DISHWASHER
Kenmore 3631402891 KENMORE DISHWASHER
Kenmore 3631402892 DISHWASHER
Kenmore 36314031000 DISHWASHER
Kenmore 36314031001 DISHWASHER
Kenmore 36314032000 DISHWASHER
Kenmore 36314032001 DISHWASHER
Kenmore 36314038000 DISHWASHER
Kenmore 36314038001 DISHWASHER
Kenmore 36314039000 DISHWASHER
Kenmore 36314039001 DISHWASHER
Kenmore 3631404193 DISHWASHER
Kenmore 3631404194 DISHWASHER
Kenmore 3631404196 DISHWASHER
Kenmore 3631404197 DISHWASHER
Kenmore 3631404593 DISHWASHER
Kenmore 3631404594 DISHWASHER
Kenmore 3631404595 DISHWASHER
Kenmore 3631404596 DISHWASHER
Kenmore 3631404597 DISHWASHER
Kenmore 3631404893 DISHWASHER
Kenmore 3631404894 DISHWASHER
Kenmore 3631404895 DISHWASHER
Kenmore 3631404896 DISHWASHER
Kenmore 3631404897 DISHWASHER
Kenmore 36314051690 DISHWASHER
Kenmore 36314051691 DISHWASHER
Kenmore 36314061790 AUTOMATIC DISHWASHER
Kenmore 36314061791 DISHWASHER
Kenmore 36314071790 AUTOMATIC DISHWASHER
Kenmore 36314071791 DISHWASHER
Kenmore 36314071792 DISHWASHER
Kenmore 36314071793 DISHWASHER
Kenmore 36314071794 DISHWASHER
Kenmore 36314072790 AUTOMATIC DISHWASHER
Kenmore 36314072791 DISHWASHER
Kenmore 36314072792 DISHWASHER
Kenmore 36314072793 DISHWASHER
Kenmore 36314072794 DISHWASHER
Kenmore 36314072795 DISHWASHER
Kenmore 36314074790 AUTOMATIC DISHWASHER
Kenmore 36314074791 DISHWASHER
Kenmore 36314074792 DISHWASHER
Kenmore 36314074793 DISHWASHER
Kenmore 36314074794 DISHWASHER
Kenmore 36314075790 AUTOMATIC DISHWASHER
Kenmore 36314075791 DISHWASHER
Kenmore 36314075792 DISHWASHER
Kenmore 36314075793 DISHWASHER
Kenmore 36314075794 DISHWASHER
Kenmore 36314081990 DISHWASHER
General Electric 36314081991 DISHWASHER
Kenmore 36314081992 DISHWASHER
Kenmore 36314081993 DISHWASHER
Kenmore 36314081994 DISHWASHER
Kenmore 3631410690 DISHWASHER
Kenmore 3631410691 DISHWASHER
Kenmore 3631410692 DISHWASHER
Kenmore 3631410693 DISHWASHER
Kenmore 3631410694 DISHWASHER
Kenmore 3631411690 DISHWASHER
Kenmore 3631411691 KENMORE DISHWASHER
Kenmore 3631411692 DISHWASHER
Kenmore 36314141690 DISHWASHER
Kenmore 3631414593 DISHWASHER
Kenmore 3631414594 DISHWASHER
Kenmore 3631414595 DISHWASHER
Kenmore 3631414596 DISHWASHER
Kenmore 3631414597 DISHWASHER
Kenmore 3631414598 DISHWASHER
Kenmore 3631414691 DISHWASHER
Kenmore 36314151000 DISHWASHER
Kenmore 36314152000 DISHWASHER
Kenmore 36314158000 DISHWASHER
Kenmore 36314159000 DISHWASHER
Kenmore 36314171790 AUTOMATIC DISHWASHER
Kenmore 36314171791 DISHWASHER
Kenmore 36314171792 DISHWASHER
Kenmore 36314172790 AUTOMATIC DISHWASHER
Kenmore 36314172791 DISHWASHER
Kenmore 36314172792 DISHWASHER
Kenmore 36314174790 AUTOMATIC DISHWASHER
Kenmore 36314174791 DISHWASHER
Kenmore 36314175790 AUTOMATIC DISHWASHER
Kenmore 36314175791 DISHWASHER
Kenmore 36314181200 DISHWASHER
Kenmore 36314181202 DISHWASHER
Kenmore 36314191990 DISHWASHER
Kenmore 36314191991 DISHWASHER
Kenmore 36314191992 DISHWASHER
Kenmore 36314191993 DISHWASHER
Kenmore 36314192990 DISHWASHER
Kenmore 36314192991 DISHWASHER
Kenmore 36314192992 DISHWASHER
Kenmore 36314192993 DISHWASHER
Kenmore 36314194990 DISHWASHER
Kenmore 36314194991 DISHWASHER
Kenmore 36314194992 DISHWASHER
Kenmore 36314194993 DISHWASHER
Kenmore 36314195990 DISHWASHER
Kenmore 36314195991 DISHWASHER
Kenmore 36314195992 DISHWASHER
Kenmore 36314195993 DISHWASHER
Kenmore 36314231100 DISHWASHER
Kenmore 36314232100 DISHWASHER
Kenmore 36314234100 DISHWASHER
  #2 (permalink)
Old 05-07-2012, 11:42 AM
Senior Expert
APP Volunteer
denman is a glorious beacon of light
Default
First determine if the compressor is running all the time.
You can usually hear it, also you should be able to feel it vibrating and it should be warm.
Check that the condenser/compressor fan is running whenever the compressor is running.
Check that the evaporator/freezer fan is running.
If compressor cycles it may be a thermostat problem.
If all the above are running then remove the cover inside the freezer so you can inspect the evaporator coils.
If partially frosted you may have a sealed system problem.
If iced/frosted over to the point where the fan cannot pull air through them you have a defrost problem.
__________________
  #3 (permalink)
Old 05-07-2012, 12:04 PM
Junior Member
Default
Thanks for the reply, denman.
Yes, I believe the compressor is running. Constantly, actually. There is indeed a very slight vibration when you place your hand against the side of the fridge.
How do I check those fans you mentioned? I'm not sure where to look to see if they are indeed working.
Take care,
Jim
  #4 (permalink)
Old 05-08-2012, 01:49 AM
Senior Expert
APP Volunteer
Default
The condenser fan is down by the compressor.
The evaporator fan is in the freezer on/behind the back wall.
__________________
  #5 (permalink)
Old 05-08-2012, 03:51 AM
Junior Member
Default
Thanks denman.
Yes, both fans are running. The compressor appears to be running for long periods, pretty much as it always has. I turned up both thermostats (the one for the freezer and the fridge) to their max settings, and the temp in the freezer is staying at 28 degrees, while the fridge seems to hover around 55 to 60 degrees.
Does that help in your diagnosis?
Thanks,
Jim
  #6 (permalink)
Old 05-08-2012, 05:00 AM
Senior Expert
APP Volunteer
Default
Were the condenser coils under the unit by the compressor and the vents front (kick plate) and rear clean?
"appears to be running" is not good enough, you have to be sure.
If the compressor is cycling on/off but the freezer does not reach set point temperature then the thermostat could be the problem. The unit thinks it has reached the set point but in reality has not.
I would also check that the doors seal are OK. Unit does reach set point but quickly rises again due to air leakage.
But if the compressor is running all the time then the unit is trying to reach set point but cannot for some reason. This can be a sealed system problem or a defrost problem.
Note: the compressor and fans will shut off during a defrost cycle. I could not find a spec on your timer but usually this is every 8 hours or so for approximately half an hour.
It is the freezer temperature that counts here as the fresh food gets all it's cooling from the freezer. The freezer should be 0 to 5 degrees F.
It may take it 24 hours to get down to that temperature.
__________________
  #7 (permalink)
Old 05-08-2012, 05:15 AM
Junior Member
Default
Yes, the condenser coils are clean - in fact, I thoroughly vacuumed them, using a small diameter tube I configured onto my vacuum to allow me to really get in and under there to clean.
The fans are indeed running properly.
Your comment about a sealed system problem intrigues me. I (assume you are referring to the freon?). My worry there is, is it cost-effective to get that compressor/freon unit professionally serviced, or will I be throwing good money at a 21 year old problem. Don't get me wrong, in many ways older appliances seem to be better constructed than newer ones, and if that's the case here, I'd much rather put some money into fixing this one than going out and buying a new version of the same thing.
If it is a defrost problem, what can I focus on to see if that is it? That sounds very inexpensive to repair!
I sat those lower temps early, last night, so they have had reasonable time to get where they need to be. The freezer is 28 degrees, and the fridge is 55 degrees. Does that tell us anything?
Thanks,
Jim
  #8 (permalink)
Old 05-08-2012, 06:11 AM
Senior Expert
APP Volunteer
Default
The freezer temperature tells us that it is not getting cold enough but everything depends on the why.
A sealed system or a defrost problem will cause the compressor to run all the time that is why it is very important to determine this.
Especially when a sealed system usually means replacing the fridge.
A sealed system problem requires a pro and is an expensive repair so it usually makes more sense to put those dollars towards a new unit.
If the compressor is running all the time, remove the cover from inside the freezer so you can inspect the evaporator coils.
If they only have frost in one area (usually where the freon enters the coils) then you probably have a sealed system problem. Be sure that the compressor has run for at least a couple hours. If you do this test shortly after a defrost cycle you will come up with the wrong diagnosis.
If they are iced/frosted over to the point where the evaporator fan cannot pull air through them then you have a defrost problem.
__________________
  #9 (permalink)
Old 05-08-2012, 08:42 AM
Junior Member
Default
denman - thanks!
I will soon pull the compressor cover in the freezer and see what we have.
I'm working on the dryer as well(!) and going out to get another one, as this one is beyond help, at least cost-effectively.
Anyway, once I get that dryer purchased and installed today, I'll focus on the fridge and give you an update later tonight...
Thanks so much for helping me.
Jim
  #10 (permalink)
Old 05-08-2012, 07:43 PM
Junior Member
Default
deman,
I pulled the back cover in the freezer section this evening, and there was a VERY heavy frosting/icing on the bottom half of the coils. There was also some frosting/ice on the outside of the cover that required chipping away before I could remove the shield.
You stated earlier that frosted coils indicates a sealed-system problem. Does that refer to the freon system, and if so, is that something only a professional can accomplish, and more importantly, is it expensive?
Thanks again,
Jim
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Refigerator and freezer not cooling Cascade Bob Refrigerator & Freezer Repair 1 02-26-2012 10:49 AM
Whirlpool refigerator not cooling Moores Refrigerator & Freezer Repair 9 09-09-2010 02:17 PM
Roper cooling issues after freezer overload jshalosky Refrigerator & Freezer Repair 1 05-28-2010 03:36 AM
freezer cooling issues mindraven Refrigerator & Freezer Repair 5 07-25-2009 02:42 PM
