| » Sub Zero doorseals are hot to the touch |
Model Number: 637 Brand: Sub Zero Age: 5 - 10 years
The door seals on the refrigerator and the freezer of my Sub Sero side-by side are hot to the touch. Is this a problem? How can I fix?
I cannot find any info on this unit.
Often a hot frame is that the condenser coils under the unit are dirty. Even a dirty condenser fan can cause this. Also check the vents at the front and back of the unit are clean. Also check that the condenser/compressor fan is running when the compressor is running. Make sure the unit has some room behind it.
__________________
Not that I know of butI have no tech info on this units.
Some units do have a switch often called an Eco or PowerSaver or something like that switch. It turns a heater in the seal frame area on/off. Take a look at the units control console. Though it usually just warms the frame up to prevent condensation if the relative humidity is high. The only ones I have seen are low wattage and do not have a thermostat.
__________________
| Display Modes | |
| Hot to touch | mbentley | Refrigerator & Freezer Repair | 0 | 05-30-2011 01:45 PM |
| touch pad | dbtdude | Dishwasher Repair | 1 | 04-06-2011 05:29 AM |
| Touch Pad | PCOVEY | Oven Repair (including Ranges and Cooktops) | 2 | 03-10-2010 02:22 PM |
| Touch Pad | Thomas DeGroat | Washer Repair | 1 | 12-20-2009 09:43 AM |
| Touch pad ? | maxflied | Oven Repair (including Ranges and Cooktops) | 5 | 07-14-2008 06:41 PM |
