| » air is not blowing threw vents |
Model Number: frs26h6bw2 Brand: Frigidaire Age: 1 - 5 years
no air is coming threw the vents from the freezer.
I took the back off the fan is working that blows on bottem coils.ice as built up on the coil that is in fridge vent where air is suppose to come out.. a couple of days ago off of (craigs) it was used.. Ads By Google Related Models |
Quote:
There are two fans. The one you need to check is located in the freezer compartment. You can check to see if it is running by openint the freezer and listening for it. If you don't hear it running (it does not run while unit is in defrost mode), you'll need to find out why and correct it accordingly. If you do hear it running, there may be a malfunctioning or blocked damper (that's the port where cold air is channeled into your refrigerator section.
the problem now is I got to keep smacking it to get it to work and thats not good??the fan will kick on after I hit it, but when it cools inside and
go off, when the compressor kick back on to cool again the air wont blow out into fridge once more intill I smack it, then the fan will start up and blow again..so do I need to replace it are do you think it might have a short in it |
| Display Modes | |
| Oven vents letting out too much heat?? | broseed | Oven Repair (including Ranges and Cooktops) | 1 | 01-31-2010 08:09 AM |
| oven threw the breaker, now won't work | hogcard | Oven Repair (including Ranges and Cooktops) | 3 | 10-27-2009 05:13 AM |
| frost seen inside frsh food vents | skopedia | Refrigerator & Freezer Repair | 0 | 10-24-2009 03:36 PM |
| Dryer spins and vents but no heat | cron | Dryer Repair | 5 | 09-13-2009 06:19 AM |
| Gas dryer vents to the outside a heavy gas smell | xfi_fan | Dryer Repair | 0 | 09-06-2009 07:05 PM |
