Discuss
Updated Whirlpool Relay with Extra Connections
 in
Refrigerator & Freezer Repair
Greetings - Was VERY pleased that my part arrived almost within 24 hrs from ordering online so none of my
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Updated Whirlpool Relay with Extra Connections
  #1 (permalink)
Old 05-04-2012, 01:52 PM
Junior Member
PTherriault is on a distinguished road
Default Updated Whirlpool Relay with Extra Connections
Model Number: EHD261MMCR1   Brand: Whirlpool   Age: More than 10 years
Greetings - Was VERY pleased that my part arrived almost within 24 hrs from ordering online so none of my food may spoil !!! Ordered replacement relay for original part# 548071 and received your replacement part# AP2979571. My original had 1 red wire going to it (directly to the start terminal) and from that a thin bare wire wound around the external shaft of the relay over to the run terminal. I want to make sure that I now use terminals 1 and 3 and provide them BOTH with the same red wire that comes from my overload device. The serial number for the fridge is S12941259.
Thanx for such great service - Paul
Ads By Google
Related Models
Whirlpool EHD261MMWR1
Whirlpool EHD261MMWR2
Whirlpool EHD261SSWR0
Whirlpool EHD261SSWR1
Whirlpool EHD262MKWR0
Amana EHD267 Range - Electric Std Delaware
Amana EHD312 Range - Std Mwave Ele
Amana EHD335 Range - S/c S/i Ddraft Ele
Amana EHD340 Range - S/c S/i Ddraft Gas
Amana EHD341 Range - S/c S/i Ddraft Gas
Amana EHD342 Range - Std Mwave Ele
Amana EHD344 Range - Std Mwave Ele
Amana EHD345 Range - S/c S/i Ddraft Ele
Amana EHD346 Range - Std Mwave Ele
Amana EHD363 Range - S/c S/i Ddraft Ele
Amana EHD379 Range - Std Mwave Ele
Amana EHD395 Range - S/c S/i Ddraft Gas
Amana EHD397 Range - S/c S/i Ddraft Ele
Amana EHF30002L Range - Std Mwave Ele
Amana EHF30002W Range - Std Mwave Ele
Whirlpool EHH060FN1
Whirlpool EHH060FN2
Whirlpool EHH060FN5
Whirlpool EHH090FN0
Whirlpool EHH150CW2
Whirlpool EHH150FW2
Whirlpool EHH180FW0
Whirlpool EHH180FW2
Whirlpool EHH230FW0
Whirlpool EHH270FW0
Whirlpool EHL090FXRQ00 Chest Freezer
Whirlpool EHL151FXRQ00 Chest Freezer
Amana EHN3302W Range - Electric Std Delaware
Amana EHN3402W Range - Electric Std Delaware
Amana EHN3402W,L Range - S/c S/i Ddraft Gas
Amana EHN3412L Range - Electric Std Delaware
Amana EHN3412W Range - Electric Std Delaware
Amana EHN3802L Range - Electric Std Delaware
Amana EHN3802W Range - Electric Std Delaware
Amana EHN3802W,L Range - S/c S/i Ddraft Gas
Amana EHN3892L Range - Electric Std Delaware
Amana EHN3892W,L Range - S/c S/i Ddraft Gas
Amana EHN3892WW Range - Electric Std Delaware
Amana EHS-OF Range - S/c S/i Ddraft Gas
Amana EHS112 Range - Electric Std Delaware
Amana EHS267 Range - Electric Std Delaware
Amana EHS2672L Range - Electric Std Delaware
Amana EHS2672W Range - Electric Std Delaware
Amana EHS305 Range - Electric Std Delaware
Amana EHS312 Range - Electric Std Delaware
Amana EHS335 Range - Electric Std Delaware
Amana EHS340 Range - S/c S/i Ddraft Gas
Amana EHS341 Range - Electric Std Delaware
Amana EHS342 Range - Std Mwave Ele
Amana EHS342-OF Range - S/c S/i Ddraft Gas
Amana EHS343 Range - Electric Std Delaware
Amana EHS344 Range - Std Mwave Ele
Amana EHS344-OF Range - S/c S/i Ddraft Gas
Amana EHS345 Range - Std Mwave Ele
Amana EHS345-OF Range - S/c S/i Ddraft Gas
Amana EHS346 Range - Std Mwave Ele
Amana EHS346-OF Range - S/c S/i Ddraft Gas
Amana EHS360 Range - Std Mwave Ele
Amana EHS360-OF Range - S/c S/i Ddraft Gas
Amana EHT-344 Range - S/c S/i Ddraft Gas
Amana EHT-345 Range - S/c S/i Ddraft Gas
Amana EHT-346 Range - S/c S/i Ddraft Gas
Amana EHT-360 Range - S/c S/i Ddraft Gas
Whirlpool EHT121DTWR0
Whirlpool EHT121PTWR0
Whirlpool EHT122DTWR0
Whirlpool EHT141AKWR0
Whirlpool EHT141DTWR0
Whirlpool EHT141DTWR1
Whirlpool EHT141JKWL1
Whirlpool EHT141JKWR0
Whirlpool EHT141JKWR1
Whirlpool EHT141PKWR0
Whirlpool EHT141XKWR0
Whirlpool EHT161AKWR0
Whirlpool EHT161AKWR1
Whirlpool EHT161JKWL0
Whirlpool EHT161JKWR0
Whirlpool EHT161JMWL2
Whirlpool EHT161JMWR0
Whirlpool EHT161JMWR1
Whirlpool EHT161JMWR2
Whirlpool EHT161JTWR0
Whirlpool EHT161JTWR1
Whirlpool EHT171HKWR0
Whirlpool EHT171HKWR1
Whirlpool EHT171HKWR2
Whirlpool EHT171HKWR3
Whirlpool EHT171HKWR4
Whirlpool EHT171MKWR0
Whirlpool EHT171MKWR2
Whirlpool EHT171MKWR3
Whirlpool EHT171MKWR4
Whirlpool EHT171MMWR0
Whirlpool EHT171MMWR1
Whirlpool EHT171MMWR2
Whirlpool EHT171MMWR3
Whirlpool EHT171PKWR2
Whirlpool EHT171PKWR3
Whirlpool EHT171PKWR4
Whirlpool EHT171PKWR5
Whirlpool EHT171SKWR0
Whirlpool EHT171SKWR1
Whirlpool EHT171TKWL4
Whirlpool EHT171TKWR0
Whirlpool EHT171TKWR1
  #2 (permalink)
Old 05-04-2012, 03:05 PM
Junior Member
Default
I have it installed with 1 and 3 wired directly from the red wire from the overload relay - just waiting for your response to plug in the fridge. I am concerned the new relay does not have the feature of that thin wound wire going to the run terminal of the compressor and may do damage to it.
Thanx Again - Paul
Last edited by PTherriault : 05-05-2012 at 03:12 AM. Reason: Concern for compressor damage
  #3 (permalink)
Old 05-05-2012, 05:41 PM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
Check your model #. Be carefull and do not plug in the fridg, if the start device is wired wrong, you will burn out the compressor.
__________________
  #4 (permalink)
Old 05-06-2012, 01:47 AM
Junior Member
Default
Model number above is correct per the faceplate. Part number is also correct on the damaged relay. Still waiting before I plug it in.
  #5 (permalink)
Old 05-06-2012, 02:51 AM
Senior Expert
APP Volunteer
Default
Trace where the red wire goes, it probably goes to the run capacitor which is wired between the left and right black plastic ptc device terminals.
If you made a diagram which wires whent where, then just plug them into the new start device. If you failed to note the wiring, then notify us for wiring info.
__________________
  #6 (permalink)
Old 05-06-2012, 04:52 AM
Junior Member
Default
The thick red wire comes from the fridge (through the thermostat and is shared by the evaporator fan and the condenser fan according to the wiring diagram found in the unit) directly into the cover into the overload. It leaves the overload on a smaller red wire through a female connector to the run terminal on the start relay. Permanently soldered to the male run relay terminal (and the only terminal on the damaged original part) is a very thin wire that is wound around an external shaft and then it's soldered to the tab for the start terminal. The damaged relay is crispy from being overheated and all contacts have continuity so it's tough to trace anything from that. If I read the schematic for the internals of the relay that outside coil of wire may be what energized/tripped the relay? If that's correct does both terminals of the compressor get 110v to start it until the coil pulls off the 110v from the start terminal and the other terminal lets it run until the thermostat is satisfied? In that case maybe the new relay has the switching inside (maybe solid state and not mechanical?) and wiring to 1 and 3 is OK. I just need to check before plugging it in.
Thanx Again - Paul
  #7 (permalink)
Old 05-06-2012, 05:56 AM
Senior Expert
APP Volunteer
Default
I have never seen a thin, enameled red wire stuck in a compressor terminal unless it's a coil wound around a old style, mechanical start relay. From your description of the wiring, the thin, red wire is shorting the power wires between the overload and start device!
If you have a ohm meter, hold the ptc device with the tab up and the input spade terminals facing you. Measure the resistance from either input terminal to either round, compressor terminal. One input terminal will measure short to one output terminal and 5 to 10 ohms to the other output terminal.This terminal gets the fridg power wire, the other input terminal gets only the run capacitor wire and no other wire. The other run capacitor wire goes to the other input ptc spade terminal.
The other power lead goes to the klixon overload device.
__________________
  #8 (permalink)
Old 05-06-2012, 06:54 AM
Junior Member
RefrigWH is on a distinguished road
Default Denman
I guess I didn't wait long enough. It started up. seems fine so far. Thanks.
  #9 (permalink)
Old 05-06-2012, 08:29 AM
Junior Member
Default
Not sure where that last post came from but I DID NOT plug it in.
OK - The thin wire wound around the external shaft (with a black plastic winged piece) of the old part MAY have been red enameled but when found it is now blackened bare wire. I suspect you may be correct in that it is a mechanical relay with the windings used to pull the contacts off the start position leaving just the run contact live to the compressor.
On the second part of your post I am unsure about what you mean. 1st are you asking me to measure the old or new part or the actual compressor pins? Before I ordered this part I checked the resistance of the compressor pins - 2.2 ohms & 5.8 ohms to the top pin and 7.9 ohms between the bottom ones so I figured the compressor is good.
The old part had only 1 spade lug (at least for connecting purposes unless no remains are found for any other possibilities) and that was directly connected to a standard coated red wire from the overload relay. This is what prompted this discussion because the new directions on the new part has only options for 2 and 3 wire connections.
I do not know of any run capacitor wires unless they vanished and I see nowhere for them to connect to the old relay.
I will add also that the schematic only shows that 1 wire to the start relay from the overload. The only other wire is the neutral that was connected directly to the top pin of the compressor.
If you want me to measure the new part or the interaction between the new part and the compressor pins, I will need to pull the fridge forward and open it back up.
Thanx Again - Paul
  #10 (permalink)
Old 05-06-2012, 09:37 AM
Junior Member
Default
Want to see a photo of my old relay?
http://www.********.com/itm/WHIRLPOO...em58920a c3a4
All the red wire coating is burned off and now not as neatly wound. The only connector is that one on the lower left that shows the winding wire that is attached to the solder tab on the other side for the run pin on the compressor. No other wires found except the white going directly to the top compressor pin. The part is shown upside down and marked with the word "TOP" and "M" (Motor or run) underneath. It (as well as the new part) can only be installed one way otherwise the white neutral wire won't fit on the compressor.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
whirlpool extra care system stops at rinse cycle mattyjohn Washer Repair 5 12-09-2011 03:54 PM
Need Help Whirlpool Heavy Duty Extra Large Cap. Plus chachi0805 Washer Repair 2 02-11-2011 11:13 AM
Need help replacing updated Whirlpool condenser control unit paulstan Refrigerator & Freezer Repair 1 03-31-2010 03:10 PM
how do i test the updated maytag ADT mmaloskey Refrigerator & Freezer Repair 0 02-09-2010 01:56 PM
Compressor Connections (Relay/Overload Protector) SouthWest Refrigerator & Freezer Repair 0 12-27-2009 05:02 PM
