Discuss
Starter problem?
 in
Refrigerator & Freezer Repair
My fridge has been dealing with the dreaded humms and then the overload clicks. At this point the fridge does
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Starter problem?
  #1 (permalink)
Old 05-03-2012, 04:09 PM
Junior Member
mmckenna1029 is on a distinguished road
Default Starter problem?
Model Number: MZD2665HEB   Brand: Maytag   Age: 5 - 10 years
My fridge has been dealing with the dreaded humms and then the overload clicks. At this point the fridge does cool at all. If I keep it plugged in it will try to turn over but then click after about 15 seconds. Every few minutes it will try again. I purchased from this site a new starter relay with capacitor but when I switch the units out nothing happens. No hum, no click with the new starter. Is it possible that I have a defective new unit? I did the continuity test on the compressor and checked each prong for shorts to the exterior and I think everything looked okay. Any thoughts would be appreciated.
Part purchased from this site was a 67005560
-Matt
Ads By Google
Related Models
Maytag MZD2665HEB REF - SXS/I&W
Maytag MZD2665HEQ REF - SXS/I&W
Maytag MZD2665HES REF - SXS/I&W
Maytag MZD2665HEW REF - SXS/I&W
Maytag MZD2666KEB REF - SXS/I&W
Maytag MZD2666KES REF - SXS/I&W
Maytag MZD2666KEW REF - SXS/I&W
Maytag MZD2667HEB REF - SXS/I&W
Maytag MZD2667HEQ REF - SXS/I&W
Maytag MZD2667HES REF - SXS/I&W
Maytag MZD2667HEW REF - SXS/I&W
Maytag MZD2669KEB REF - SXS/I&W
Maytag MZD2669KEQ REF - SXS/I&W
Maytag MZD2669KES REF - SXS/I&W
Maytag MZD2669KEW REF - SXS/I&W
Maytag MZD2752GRB REF - SXS/I&W
Maytag MZD2752GRQ REF - SXS/I&W
Maytag MZD2752GRS REF - SXS/I&W
Maytag MZD2752GRW REF - SXS/I&W
Maytag MZD2766GEB REF - SXS/I&W
Maytag MZD2766GEQ REF - SXS/I&W
Maytag MZD2766GES REF - SXS/I&W
Maytag MZD2766GEW REF - SXS/I&W
Maytag MZD2768GEB REF - SXS/I&W
Maytag MZD2768GEQ REF - SXS/I&W
Maytag MZD2768GEW REF - SXS/I&W
Whirlpool N N ELECTRIC RANGES AND OVENS
Norge N1100PAW RANGE- F/S STD GAS
Norge N1100PRA RANGE- F/S STD GAS
Norge N1100PRA-L RANGE-F/S CONT CLEAN GAS
Norge N1100PRW RANGE- F/S STD GAS
Norge N1100PRW-L RANGE-F/S CONT CLEAN GAS
Norge N1500PRA RANGE- F/S STD ELE
Norge N1500PRW RANGE- F/S STD ELE
Norge N31100PAA RANGE- F/S STD GAS
Norge N31100PAW RANGE- F/S STD GAS
Norge N3110KRA RANGE- F/S STD GAS
Norge N3110KRW RANGE- F/S STD GAS
Norge N3110PPA RANGE- F/S STD GAS
Norge N3110PPW RANGE- F/S STD GAS
Norge N3110PRA RANGE- F/S STD GAS
Norge N3110PRW RANGE- F/S STD GAS
Norge N31111XAA RANGE- F/S STD GAS
Norge N31111XAW RANGE- F/S STD GAS
Norge N31115WAV RANGE- F/S STD GAS
Norge N31115XAA RANGE- F/S STD GAS
Norge N31115XAW RANGE- F/S STD GAS
Norge N3120SPA RANGE- F/S STD GAS
Norge N3120SPN RANGE- F/S STD GAS
Norge N3120SPW RANGE- F/S STD GAS
Norge N3120SRA RANGE- F/S STD GAS
Norge N3120SRW RANGE- F/S STD GAS
Norge N3121XPA RANGE- F/S STD GAS
Norge N3121XPW RANGE- F/S STD GAS
Norge N3121XRA RANGE- F/S STD GAS
Norge N3121XRW RANGE- F/S STD GAS
Norge N3121XTA RANGE- F/S STD GAS
Norge N3121XTW RANGE- F/S STD GAS
Norge N3137XRA RANGE- F/S STD GAS
Norge N3137XRW RANGE- F/S STD GAS
Roper N3157*0 Ranges, Electric*
Roper N3157*1 Ranges, Electric*
Roper N3157W0 Ranges, Electric*
Roper N3157W1 Ranges, Electric*
Norge N3177VUV RANGE- F/S STD GAS
Norge N3177XRA RANGE- F/S STD GAS
Norge N3177XRW RANGE- F/S STD GAS
Norge N3177XUA RANGE- F/S STD GAS
Norge N3177XUW RANGE- F/S STD GAS
Roper N3257*0 Ranges, Electric*
Roper N3257*1 Ranges, Electric*
Roper N3257W0 Ranges, Electric*
Roper N3257W1 Ranges, Electric*
Roper N3357*0 Ranges, Electric*
Roper N3357W0 Ranges, Electric*
Norge N3422PRA RANGE- S/C F/S GAS
Norge N3422PRW RANGE- S/C F/S GAS
Norge N3438SRA RANGE- S/C F/S GAS
Norge N3438SRW RANGE- S/C F/S GAS
Norge N3438VRV RANGE- S/C F/S GAS
Roper N3457*0 Ranges, Electric*
Roper N3457W0 Ranges, Electric*
Norge N3472SRA RANGE- S/C F/S GAS
Norge N3472SRW RANGE- S/C F/S GAS
Norge N3478VRV RANGE- S/C F/S GAS
Norge N3478VVV RANGE- S/C F/S GAS
Norge N3478XRA RANGE- S/C F/S GAS
Norge N3478XRW RANGE- S/C F/S GAS
Norge N3478XVA RANGE- S/C F/S GAS
Norge N3478XVW RANGE- S/C F/S GAS
Norge N3510KRA RANGE- F/S STD ELE
Norge N3510KRW RANGE- F/S STD ELE
Norge N3510PPA RANGE- F/S STD ELE
Norge N3510PPW RANGE- F/S STD ELE
Norge N3510PRA RANGE- F/S STD ELE
Norge N3510PRW RANGE- F/S STD ELE
Norge N3520SPA RANGE- F/S STD ELE
Norge N3520SPN RANGE- F/S STD ELE
Norge N3520SPW RANGE- F/S STD ELE
Norge N3520SRA RANGE- F/S STD ELE
Norge N3520SRW RANGE- F/S STD ELE
Norge N3521XPA RANGE- F/S STD ELE
Norge N3521XPW RANGE- F/S STD ELE
Norge N3521XRA RANGE- F/S STD ELE
Norge N3521XRW RANGE- F/S STD ELE
Norge N3832XRA RANGE- S/C F/S ELE
Norge N3832XRW RANGE- S/C F/S ELE
Norge N3875XRA RANGE- S/C F/S ELE
Norge N3875XRW RANGE- S/C F/S ELE
Norge N3878VRV RANGE- S/C F/S ELE
Norge N3878VVD RANGE- S/C F/S ELE
Norge N3878VVV RANGE- S/C F/S ELE
Norge N3878XRA RANGE- S/C F/S ELE
Norge N3878XRW RANGE- S/C F/S ELE
Norge N3878XVA RANGE- S/C F/S ELE
Norge N3878XVW RANGE- S/C F/S ELE
Magic Chef N40C-3-X9 MWAVE- CNTRTP / STAND ALONE
Norge N4231WRA RANGE-F/S CONT CLEAN GAS
Norge N4231WRW RANGE-F/S CONT CLEAN GAS
Norge N4251WTA RANGE- F/S STD GAS
  #2 (permalink)
Old 05-04-2012, 02:07 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
Check across the blue and white wires to the compressor, if no voltage, the adaptive defrost board AP4010220 may be blown due to a compressor short.
If ok, Unplug unit and measure resistance across the blue and white wires to the compressor, should be around 3-4 0hms.
__________________
  #3 (permalink)
Old 05-14-2012, 03:14 PM
Junior Member
Default
richappy,
Thank you for the response. I tested as you stated and there is 122 volts going from the blue and white wires. The resistance test came out way off though. I was reading 84 ohms. I am a multimeter newbie so I hope I tested correctly but all the rest of the tests I did came out fine. Does this mean a likely issue with the adaptive defrost board or is that tied to some other problem?
-Matt
  #4 (permalink)
Old 05-14-2012, 03:46 PM
Senior Expert
APP Volunteer
Default
You need to test the voltage to the compressor with the plug in the start device. If still 115 volts, unplug fridg, unplug the connector to the start device and measure ohms between the spade terminals of the start device, should be about 2 to 3 ohms
__________________
  #5 (permalink)
Old 05-14-2012, 04:06 PM
Junior Member
Default
Alright, start device is plugged into the compressor with the capacitor. With the blue and white wires unplugged I tested across the spade terminals and got 2.7 ohms. I am not sure about checking voltage with everything plugged in since there is nothing exposed? What is the best way to check the voltage?
Thanks for the quick response.
-Matt
  #6 (permalink)
Old 05-15-2012, 01:42 AM
Senior Expert
APP Volunteer
Default
As I said, you plug the fridg plug into the start device, monitor the voltage to the plug. If no voltage, probably a blown adaptive defrost board.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Cause of a starter device Veronica Perez Refrigerator & Freezer Repair 2 03-27-2012 02:39 AM
Roper Starter tombat Refrigerator & Freezer Repair 10 01-18-2012 03:26 PM
Starter/capacitor Andy Sr Refrigerator & Freezer Repair 0 09-26-2011 08:10 AM
Starter - TSD beckbean Refrigerator & Freezer Repair 0 05-27-2009 07:24 PM
Starter relay tv guy Refrigerator & Freezer Repair 0 08-10-2007 01:08 PM
