| » Whirlpool stopped no fan running |
Model Number: GD5YHAXNL00 Brand: Whirlpool Age: 5 - 10 years
My Ref has stopped working all of a sudden, no fan noise but all the lights are lit and no noise at all. i cleaned it up but still no luck, any ideas.
Hi.
Here are the breakdown diagrams and Replacement parts for Whirlpool GD5YHAXNL00 Refrigerator | AppliancePartsPros.com Unplug the unit. Pry off the control box cover #25 on the diagram #3. Remove 4 screws, open the control box. Install the jumper wire between two leads of the cold control #9. Restore power. If the refrigerator works - replace the cold control. If not - replace the adaptive defrost control #6. The cold control Part number: 2198202 The defrost control Part number: 4388932 You can use the plastic sleeve from the old cold control. Thank you. Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Hi.
INSTALL THE JUMPER BETWEEN TWO WIRES OF THE COLD CONTROL (#9 on the diagram #3). If you don't feel comfortable doing any electrical tests then may be you can run a continuity test, but you'll need a multimeter. If you don't - then get both parts I've listed and replace them one at the time. You can return any unused parts even if they been installed. Thank you. Post the results. Simon.
__________________
| Display Modes | |
| old whirlpool stopped running | widewally | Washer Repair | 1 | 06-17-2011 08:31 AM |
| Whirlpool DW Stopped running | WHGJR | Dishwasher Repair | 0 | 08-02-2010 05:07 AM |
| Whirlpool stopped running connected to a power inverter | cherijon | Refrigerator & Freezer Repair | 3 | 03-04-2010 07:54 PM |
| IDI Motor stopped running on Whirlpool Gold | Flyabus | Refrigerator & Freezer Repair | 0 | 09-29-2009 12:35 PM |
| Whirlpool Dryer - Stopped Running | BCB | Dryer Repair | 3 | 09-11-2009 04:49 AM |
