Discuss
Water not chilling in fridge
 in
Refrigerator & Freezer Repair
Two weeks ago I ordered a new valve from you and the installation was easy. However, water still does not
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Water not chilling in fridge
  #1 (permalink)
Old 05-01-2012, 11:31 AM
Junior Member
sandikniday is on a distinguished road
Unhappy Water not chilling in fridge
Brand: Whirlpool   Age: 5 - 10 years
Two weeks ago I ordered a new valve from you and the installation was easy. However, water still does not go into the icemaker. The water-in-the door works great BUT it does not come out chilled. It is warmer than room temp I think. What could prevent the water from chilling and why won't the icemaker pull in water?
Ads By Google
  #2 (permalink)
Old 05-01-2012, 11:46 AM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
Provide the model number, please.
And also, did you check the water valve before replacing it?
Thank you.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 05-01-2012, 12:14 PM
Junior Member
Default
Model ED5FHEXN s00
First the icemaker quit , then the water dispenser stopped. I contacted appliancepartspro and it was determined I needed the new valve (AP5263471 (W10408179)
We got water as soon as the new valve was installed but not in icemaker....so maybe the icemaker itself is also broken?
The water dispenser giving WARM water is strange and I don't understand how that is possible.
  #4 (permalink)
Old 05-01-2012, 02:25 PM
Expert
Default
Hi.
Make sure that the icemaker water inlet tube is not frozen.
Then switch around plugs at the water valve and press water lever.
If the water fills - replace the icemaker.
The icemaker Part number: W10190965
Regarding the warm water from the dispenser. Check the temperature in the refrigerator bottom rear area.That's where the water reservoir is located. Try to drain first half of the glass and than taste it.
Thank you. Post the results.
Simon.
__________________
  #5 (permalink)
Old 05-01-2012, 06:38 PM
Junior Member
Default
Do you mean to pull out the 2 drawers in the bottom of refrigerator and then feel the back wall?
I can tell you that the water comes out quite warm as if heated a bit for about the first 2-3 ozs then slowly comes out more room temp. Definitely not chilled. What could be warming it?
  #6 (permalink)
Old 05-02-2012, 12:16 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Pull the refrigerator out of the wall. Remove the rear bottom cover and the front bottom grille. Clean the condenser coils (#3 at the diagram) using a special condenser cleaning brush and a vacuum cleaner. Make sure the fan next to the compressor works fine.
It would not hurt to measure the temperature in the fresh food compartment, using a refrigerator thermometer.
- The condenser cleaning brush Part number: AP4320046
- The refrigerator thermometer Part number: AP3549145
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
water dripping from freezer through fridge and pooling in fridge bottom sportinredwood Refrigerator & Freezer Repair 0 07-19-2011 11:38 PM
Kenmore Coldspot not chilling canadawest Refrigerator & Freezer Repair 0 09-11-2010 11:15 AM
Water Dispener on Whirlpool Fridge Makes Noise and Vibrates Water Line But No Water ugagrad04 Refrigerator & Freezer Repair 0 07-20-2010 06:43 PM
Amana not chilling lenrosenberg Refrigerator & Freezer Repair 0 08-26-2009 04:27 PM
Kenmore fridge leaks water into fridge instead the drain tube skg Refrigerator & Freezer Repair 5 08-14-2009 04:57 AM
