Discuss
control box?
 in
Refrigerator & Freezer Repair
When opening refrigerator door, fridge side lights and control lights went out. Technician tested door switch, power to control box,
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » control box?
  #1 (permalink)
Old 04-30-2012, 09:43 AM
Junior Member
rsharp9149 is on a distinguished road
Default control box?
Model Number: GS5SHAXNQ01   Brand: Whirlpool   Age: 5 - 10 years
When opening refrigerator door, fridge side lights and control lights went out. Technician tested door switch, power to control box, stating all were good. He also check the control box next to compressor. His opinion was the 2255233 control box was bad although no burned out evidence existed on the boards. replaced the control box and no change. lights in freezer work fine, both sides cool appropriately. connection of wire junction appears tight and inserted completely. What's next?
Ads By Google
Related Models
Whirlpool GS5SHAXNQ01 Refrigerator
Whirlpool GS5SHAXNS00 Refrigerator
Whirlpool GS5SHAXNS01 Refrigerator
Whirlpool GS5SHAXNT00 Refrigerator
Whirlpool GS5SHAXNT01 Refrigerator
Whirlpool GS5SHAXSA00 Refrigerator
Whirlpool GS5SHAXSA01 Refrigerator
Whirlpool GS5SHAXSB00 Refrigerator
Whirlpool GS5SHAXSB01 Refrigerator
Whirlpool GS5SHAXSL00 Refrigerator
Whirlpool GS5SHAXSL01 Refrigerator
Whirlpool GS5SHAXSQ00 Refrigerator
Whirlpool GS5SHAXSQ01 Refrigerator
Whirlpool GS5SHAXTB00 Refrigerator
Whirlpool GS5SHAXTB01 Refrigerator
Whirlpool GS5SHAXTL00 Refrigerator
Whirlpool GS5SHAXTL01 Refrigerator
Whirlpool GS5SHAXTQ00 Refrigerator
Whirlpool GS5SHAXTQ01 Refrigerator
Whirlpool GS5SHAXTS00 Refrigerator
Whirlpool GS5SHAXTS01 Refrigerator
Whirlpool GS5SHGXKB00
Whirlpool GS5SHGXKQ00
Whirlpool GS5SHGXKS00
Whirlpool GS5SHGXKT00
Whirlpool GS5SHGXLB00
Whirlpool GS5SHGXLB01
Whirlpool GS5SHGXLL00
Whirlpool GS5SHGXLL01
Whirlpool GS5SHGXLQ00
Whirlpool GS5SHGXLQ01
Whirlpool GS5SHGXLS00
Whirlpool GS5SHGXLS01
Whirlpool GS5SHGXLT00
Whirlpool GS5SHGXLT01
Whirlpool GS6NBEXRA00 Refrigerator
Whirlpool GS6NBEXRA01 Refrigerator
Whirlpool GS6NBEXRA02 Refrigerator
Whirlpool GS6NBEXRB00 Refrigerator
Whirlpool GS6NBEXRB01 Refrigerator
Whirlpool GS6NBEXRB02 Refrigerator
Whirlpool GS6NBEXRL00 Refrigerator
Whirlpool GS6NBEXRL01 Refrigerator
Whirlpool GS6NBEXRL02 Refrigerator
Whirlpool GS6NBEXRQ00 Refrigerator
Whirlpool GS6NBEXRQ01 Refrigerator
Whirlpool GS6NBEXRQ02 Refrigerator
Whirlpool GS6NBEXRS00 Refrigerator
Whirlpool GS6NBEXRS01 Refrigerator
Whirlpool GS6NBEXRS02 Refrigerator
Whirlpool GS6NBEXRT00 Refrigerator
Whirlpool GS6NBEXRT01 Refrigerator
Whirlpool GS6NBEXRT02 Refrigerator
Whirlpool GS6NBEXRY00 Refrigerator
Whirlpool GS6NBEXRY01 Refrigerator
Whirlpool GS6NBEXRY02 Refrigerator
Whirlpool GS6NVEXSA00 Refrigerator
Whirlpool GS6NVEXSA01 Refrigerator
Whirlpool GS6NVEXSB00 Refrigerator
Whirlpool GS6NVEXSB01 Refrigerator
Whirlpool GS6NVEXSL00 Refrigerator
Whirlpool GS6NVEXSL01 Refrigerator
Whirlpool GS6NVEXSQ00 Refrigerator
Whirlpool GS6NVEXSQ01 Refrigerator
Whirlpool GS6NVEXSS00 Refrigerator
Whirlpool GS6NVEXSS01 Refrigerator
Whirlpool GS6NVEXST00 Refrigerator
Whirlpool GS6NVEXST01 Refrigerator
Whirlpool GS6NVEXSY00 Refrigerator
Whirlpool GS6NVEXSY01 Refrigerator
Whirlpool GS6NVEXVB00 Refrigerator
Whirlpool GS6NVEXVL00 Refrigerator
Whirlpool GS6NVEXVQ00 Refrigerator
Whirlpool GS6NVEXVS00 Refrigerator
Whirlpool GS6SHANLB10
Whirlpool GS6SHANLQ10
Whirlpool GS6SHAXKB01
Whirlpool GS6SHAXKB02
Whirlpool GS6SHAXKQ01
Whirlpool GS6SHAXKQ02
Whirlpool GS6SHAXKS01
Whirlpool GS6SHAXKS02
Whirlpool GS6SHAXKT01
Whirlpool GS6SHAXKT02
Whirlpool GS6SHAXLB01
Whirlpool GS6SHAXLB02
Whirlpool GS6SHAXLB03 Refrigerator
Whirlpool GS6SHAXLL01
Whirlpool GS6SHAXLL02
Whirlpool GS6SHAXLL03 Refrigerator
Whirlpool GS6SHAXLQ01
Whirlpool GS6SHAXLQ02
Whirlpool GS6SHAXLQ03 Refrigerator
Whirlpool GS6SHAXLS01
Whirlpool GS6SHAXLS02
Whirlpool GS6SHAXLS03 Refrigerator
Whirlpool GS6SHAXLT01
Whirlpool GS6SHAXLT02
Whirlpool GS6SHAXLT03 Refrigerator
Whirlpool GS6SHAXMB00 Refrigerator
Whirlpool GS6SHAXML00 Refrigerator
Whirlpool GS6SHAXMQ00 Refrigerator
Whirlpool GS6SHAXMS00 Refrigerator
Whirlpool GS6SHAXMT00 Refrigerator
Whirlpool GS6SHEXMB00 Refrigerator
Whirlpool GS6SHEXMB01 Refrigerator
Whirlpool GS6SHEXML00 Refrigerator
Whirlpool GS6SHEXML01 Refrigerator
Whirlpool GS6SHEXMQ00 Refrigerator
Whirlpool GS6SHEXMQ01 Refrigerator
Whirlpool GS6SHEXMS00 Refrigerator
Whirlpool GS6SHEXMS01 Refrigerator
Whirlpool GS6SHEXMT00 Refrigerator
Whirlpool GS6SHEXMT01 Refrigerator
Whirlpool GS6SHEXNB00 Refrigerator
Whirlpool GS6SHEXNB01 Refrigerator
Whirlpool GS6SHEXNB02 Refrigerator
Whirlpool GS6SHEXNB03 Refrigerator
Whirlpool GS6SHEXNB04 Refrigerator
Whirlpool GS6SHEXNL00 Refrigerator
  #2 (permalink)
Old 05-15-2012, 07:33 AM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
Rsharp,
You'll need to conduct " live" voltage tests at the main control board and refrigerator light switch.
Here are the checks to make :
The main control board:
Connector P1 across pin 1 Blk and pin 2 Wht, should have 120 VAC, this is voltage into the main control board, make sure there is a good neutral circuit to the control board.
Connector P2 pin 9 ylw/rd to conn P1 pin 2 wht should have 120 VAC, This circuit is power to the ref. light switch.
With the refriigerator door closed, check connector P2 pin 3 Ylw to connector P1 pin 2 wht for 120 VAC, There should be no voltage, Open the refrigerator door and 120 VAC should be present on the same wires.
You will also want to conduct the same voltage checks at the refrigerator light switch and light bulb sockets.
If all's OK and the neutral line to the control checks proper, the best guess would be an issue with the ylw/rd wire from the control board to the ref. door light switch, or the light switch itself, since the interior light and the display wont illuminate.
Thanks and Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
light on But won't start washing. Control panel vs. electronic control sakape Dishwasher Repair 3 03-26-2012 04:27 PM
How to remove the control panel to replace the control membrane Eldooberman Microwave Repair 0 06-30-2011 10:12 AM
Electronic Control Panel or Touch Pad Control Issue? maxtout4u@aol.com Dishwasher Repair 0 10-08-2010 11:33 AM
No Display Troubleshooting: Control Panel Assy or Electronic Clock Control Board hddman Oven Repair (including Ranges and Cooktops) 0 04-26-2010 12:09 PM
GE Built-In Oven Control Panel - replace entire assembly or just control kit boschuser Oven Repair (including Ranges and Cooktops) 1 01-05-2010 03:11 AM
