Discuss
What's wrong with my Ice Maker?
 in
Refrigerator & Freezer Repair
Help, Here's the sequence of events. 1. My Ice Maker stopped making Ice. It's only job as far as I
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » What's wrong with my Ice Maker?
  #1 (permalink)
Old 04-28-2012, 09:02 PM
Junior Member
Totallytalm is on a distinguished road
Default What's wrong with my Ice Maker?
Model Number: FRT18PRH   Brand: Frigidaire   Age: 5 - 10 years
Help,
1. My Ice Maker stopped making Ice. It's only job as far as I am concerned.
2. I discovered the copper hose from the back Inlet pump to the supply line was crimped. So I had no water flowing through the copper pipe to the pump.
3. I closed the valve on the "Self Tapping" insert valve thingy on the supply line and cut the copper hose at the spot of the crimp. I planned to put a 1/4" x 1/4" union in place to repair the crimp.
4. While waiting to get the parts, I could hear the little blue pump/valve sucking air through the cut off copper pipe, while trying to fill the Ice Maker. The Ice Maker arm would also go through it's motions but with no water to freeze.
5. Instead of putting in a union, I replaced the copper, end to end with Plastic Tube. No problems noticed with that process. No Leaks.
6. I opened the valve on the self tapping thingy in my supply line and saw water " Noticably slowly" flowing through the plastic tube.
7. No leaks, not obvious issues, but it still doesn't work. What I do see, right where the plastic tube enters the connection to the pump on the back of the fridge are some air bubbles. The hose is vertical at this point, and the air bubble slowy rises from the compression fitting at the bottom, to the point where the plastic tube curves and goes down. Then it drops back to the compression fitting, then up again and so on. What's up with that?
I took the hose off of the "output" of the inlet pump, and there is no water at all. But remember, the same day I replaced this hose, I heard the little pump sucking air. So the pump has been working, but since I put on the new hose, it hasn't sucked any water through it.
So what do you think is my problem and why?
What if any additional info do you need?
I am thinking a pressure problem, but I'm an electronics guy, so it's just a guess.
Thanks for the help
Ads By Google
Related Models
Frigidaire FRT18PRHD0 Frg(v3) / Refrigerator
Frigidaire FRT18PRHD1 Frg(v1) / Refrigerator
Frigidaire FRT18PRHW0 Frg(v4) / Refrigerator
Frigidaire FRT18PRHW1 Frg(v2) / Refrigerator
Frigidaire FRT18PZBD1 Frg(v3) / Top Mount Refrigerator
Frigidaire FRT18PZBW0 Frg(v3) / Top Mount Refrigerator
Frigidaire FRT18PZBW1 Frg(v4) / Top Mount Refrigerator
Frigidaire FRT18QBGW0 Frg(v1) / Refrigerator
Frigidaire FRT18QBGW1 Frg(v2) / Refrigerator
Frigidaire FRT18QGFD0 Frg(v1) / Top Mount Refrigerator
Frigidaire FRT18QGFD1 Frg(v1) / Refrigerator
Frigidaire FRT18QGFD2 Frg(v1) / Refrigerator
Frigidaire FRT18QGFW0 Frg(v2) / Top Mount Refrigerator
Frigidaire FRT18QGFW1 Frg(v2) / Refrigerator
Frigidaire FRT18QGFW2 Frg(v2) / Refrigerator
Frigidaire FRT18QGHD0 Frg(v3) / Refrigerator
Frigidaire FRT18QGHW0 Frg(v4) / Refrigerator
Frigidaire FRT18QGJD0 Frg(v3) / Refrigerator
Frigidaire FRT18QGJD1 Frg(v3) / Refrigerator
Frigidaire FRT18QGJW0 Frg(v4) / Refrigerator
Frigidaire FRT18QGJW1 Frg(v4) / Refrigerator
Frigidaire FRT18QRBD0 Frg(v1) / Top Mount Refrigerator
Frigidaire FRT18QRBD1 Frg(v1) / Top Mount Refrigerator
Frigidaire FRT18QRBD2 Frg(v1) / Top Mount Refrigerator
Frigidaire FRT18QRBW0 Frg(v2) / Top Mount Refrigerator
Frigidaire FRT18QRBW1 Frg(v2) / Top Mount Refrigerator
Frigidaire FRT18QRBW2 Frg(v2) / Top Mount Refrigerator
Frigidaire FRT18QRCD0 Frg(v3) / Refrigerator
Frigidaire FRT18QRCD1 Frg(v1) / Top Mount Refrigerator
Frigidaire FRT18QRCD2 Frg(v2) / Top Mount Refrigerator
Frigidaire FRT18QRCD3 Frg(v1) / Top Mount Refrigerator
Frigidaire FRT18QRCD4 Frg(v1) / Refrigerator
Frigidaire FRT18QRCD5 Frg(v1) / Refrigerator
Frigidaire FRT18QRCW0 Frg(v4) / Refrigerator
Frigidaire FRT18QRCW1 Frg(v3) / Top Mount Refrigerator
Frigidaire FRT18QRCW2 Frg(v4) / Top Mount Refrigerator
Frigidaire FRT18QRCW3 Frg(v2) / Top Mount Refrigerator
Frigidaire FRT18QRCW4 Frg(v2) / Refrigerator
Frigidaire FRT18QRCW5 Frg(v2) / Refrigerator
Frigidaire FRT18QRCW6 Frg(v0) / Refrigerator
Frigidaire FRT18QRHW0 Frg/refrigerator
Frigidaire FRT18QRHW1 Frg(v0) / Refrigerator
Frigidaire FRT18QRHW2 Frg(v0) / Refrigerator
Frigidaire FRT18QRHW3 Frg(v0) / Refrigerator
Frigidaire FRT18QSFW0 Frg(v0) / Refrigerator
Frigidaire FRT18R6AQ0 Frigidaire/refrigerator
Frigidaire FRT18R6AQ2 Frigidaire/refrigerator
Frigidaire FRT18R6AW0 Frigidaire/refrigerator
Frigidaire FRT18R6AW2 Frigidaire/refrigerator
Frigidaire FRT18R7CK0 Frigidaire/refrigerator
Frigidaire FRT18R7CQ0 Frigidaire/refrigerator
Frigidaire FRT18R7CS0 Frigidaire/refrigerator
Frigidaire FRT18R7CW0 Frigidaire/refrigerator
Frigidaire FRT18RRCD0 Frg(v3) / Refrigerator
Frigidaire FRT18RRCD1 Frg(v1) / Top Mount Refrigerator
Frigidaire FRT18RRCD2 Frg(v2) / Top Mount Refrigerator
Frigidaire FRT18RRCD3 Frg(v1) / Top Mount Refrigerator
Frigidaire FRT18RRCW0 Frg(v4) / Refrigerator
Frigidaire FRT18RRCW1 Frg(v3) / Top Mount Refrigerator
Frigidaire FRT18RRCW2 Frg(v4) / Top Mount Refrigerator
Frigidaire FRT18RRCW3 Frg(v2) / Top Mount Refrigerator
Frigidaire FRT18RRJD0 Frg(v1) / Refrigerator
Frigidaire FRT18RRJD1 Frg/refrigerator
Frigidaire FRT18RRJW0 Frg(v2) / Refrigerator
Frigidaire FRT18RRJW1 Frg/refrigerator
Frigidaire FRT18S6AB1 Frigidaire/refrigerator
Frigidaire FRT18S6AB3 Frigidaire/refrigerator
Frigidaire FRT18S6AB7 Frigidaire/refrigerator
Frigidaire FRT18S6ABH Frigidaire/refrigerator
Frigidaire FRT18S6ABJ Frigidaire/refrigerator
Frigidaire FRT18S6ABK Frigidaire/refrigerator
Frigidaire FRT18S6ABL Frigidaire/refrigerator
Frigidaire FRT18S6ABM Frigidaire/refrigerator
Frigidaire FRT18S6ABP Frigidaire/refrigerator
Frigidaire FRT18S6ABS Frigidaire/refrigerator
Frigidaire FRT18S6ABT Frigidaire/refrigerator
Frigidaire FRT18S6ABV Frigidaire/refrigerator
Frigidaire FRT18S6ABW Frigidaire/refrigerator
Frigidaire FRT18S6ABX Frigidaire/refrigerator
Frigidaire FRT18S6AQ0 Frigidaire/refrigerator
Frigidaire FRT18S6AQ1 Frigidaire/refrigerator
Frigidaire FRT18S6AQ2 Frigidaire/refrigerator
Frigidaire FRT18S6AQ3 Frigidaire/refrigerator
Frigidaire FRT18S6AQ4 Frigidaire/refrigerator
Frigidaire FRT18S6AQ6 Frigidaire/refrigerator
Frigidaire FRT18S6AQ7 Frigidaire/refrigerator
Frigidaire FRT18S6AQ8 Frigidaire/refrigerator
Frigidaire FRT18S6AQA Frigidaire/refrigerator
Frigidaire FRT18S6AQF Frigidaire/refrigerator
Frigidaire FRT18S6AQG Frigidaire/refrigerator
Frigidaire FRT18S6AQH Frigidaire/refrigerator
Frigidaire FRT18S6AQJ Frigidaire/refrigerator
Frigidaire FRT18S6AQK Frigidaire/refrigerator
Frigidaire FRT18S6AQL Frigidaire/refrigerator
Frigidaire FRT18S6AQM Frigidaire/refrigerator
Frigidaire FRT18S6AQP Frigidaire/refrigerator
Frigidaire FRT18S6AQS Frigidaire/refrigerator
Frigidaire FRT18S6AQT Frigidaire/refrigerator
Frigidaire FRT18S6AQV Frigidaire/refrigerator
Frigidaire FRT18S6AQW Frigidaire/refrigerator
Frigidaire FRT18S6AQX Frigidaire/refrigerator
Frigidaire FRT18S6AW0 Frigidaire/refrigerator
Frigidaire FRT18S6AW1 Frigidaire/refrigerator
Frigidaire FRT18S6AW2 Frigidaire/refrigerator
Frigidaire FRT18S6AW3 Frigidaire/refrigerator
Frigidaire FRT18S6AW4 Frigidaire/refrigerator
Frigidaire FRT18S6AW6 Frigidaire/refrigerator
Frigidaire FRT18S6AW7 Frigidaire/refrigerator
Frigidaire FRT18S6AW8 Frigidaire/refrigerator
Frigidaire FRT18S6AWA Frigidaire/refrigerator
Frigidaire FRT18S6AWE Frigidaire/refrigerator
Frigidaire FRT18S6AWF Frigidaire/refrigerator
Frigidaire FRT18S6AWG Frigidaire/refrigerator
Frigidaire FRT18S6AWH Frigidaire/refrigerator
Frigidaire FRT18S6AWJ Frigidaire/refrigerator
Frigidaire FRT18S6AWK Frigidaire/refrigerator
Frigidaire FRT18S6AWL Frigidaire/refrigerator
Frigidaire FRT18S6AWM Frigidaire/refrigerator
Frigidaire FRT18S6AWP Frigidaire/refrigerator
Frigidaire FRT18S6AWR Frigidaire/refrigerator
  #2 (permalink)
Old 04-29-2012, 03:44 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
You lost me here.
I do not know if you had the unit unplugged when you worked on it.
If you did then you will have to wait till the ice maker gets down to a set point temperature. It should then call for water.
The parts does not give a good view of the ice maker but some of them have an off/on switch, If you hold the switch on it starts a cycle. You have to let the ejector arms move about 10 degrees and then you can let go of the switch.
There is not a pump.
Are you referring to the inlet solenoid Item 55 in Section 4.
There will not be water there till the ice maker calls for water activating (opening) the solenoid valve.
Here is a manual which may help though it covers lots of units.
http://appliancejunk.com/forums/inde...=view;down=290
__________________
  #3 (permalink)
Old 05-01-2012, 07:13 PM
Junior Member
Default
Thanks for the reply.
Forget about the Air Bubble issue. It's too hard to explain in text and based on what I know now, it's probably irrelevant.
Sorry, for some reason I thought it was a pump that when the maker wanted more water, it would pump up the correct amount. So you are saying it's just a solenoid that the Ice Maker opens when it needs more water and the pressure "Should" be enough to get the water up there????
Anyway, as I was saying, I could hear the solenoid making noise periodically before I replaced the hose. But since there was no supply, it just sucked air. But since I replaced the hose, I can't be sure if it's opening or not, or if it's opening and there isn't enough pressure to get the water all the way up through the Solenoid and to the top. This is why I checked the "output" of the solenoid. I figured, even if it wasn't full of water there would be some water present on the outline line of the solenoid. But it seemed bone dry.
BTW - I poured water directly into the Ice Maker Tray and it worked perfectly. So it's just not getting water.
So I would guess right now that either the Solenoid coincidently stopped working the same day I replaced the hose (I hate coincidental troubleshooting solutions), or for some reason I don't have enough water pressure to make it all the way up to the top of the fridge and into the ice maker. Maybe it's the Auto Tapping Valve thingy that clamps to the supply line and punches a hole in it?
Any thoughts?
Thanks again for the help
Talm
  #4 (permalink)
Old 05-02-2012, 03:43 AM
Senior Expert
APP Volunteer
Default
Yes. It is house pressure so should have lots.
Perhaps loosen the supply fitting at the valve. If it starts to squirt out water then you know you have pressure there. Would be a good idea to have another person at the shut off just in case it pops off.
Also unplug the unit when doing this, water and electrical just don't mix well.
Since you no longer hear the solenoid opening I doubt this is your problem but is worth checking.
OK so it should have filled with water as part of it's cycle.
I am not sure what the ice bucket full mechanism shuts off on this unit but I would check that it is in the down position.
Could be that the solenoid is toast.
Could be that it had a poor internal connection and went open when you replaced the line.
I would check it with a meter for continuity.
Unplug the fridge and at least one wire from the solenoid when doing this.
This prevents you from reading an alternate/parallel circuit path.
If it is open then you know it is toast.
If it has continuity then it does not eliminate it as the problem as it may have mechanical problems.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
tell me I am wrong robiemac Refrigerator & Freezer Repair 2 09-16-2011 07:48 PM
What is wrong lloydo Microwave Repair 0 07-10-2011 12:08 PM
Ice maker ejector arm in wrong position-freezes maytagman Refrigerator & Freezer Repair 6 12-08-2010 11:27 AM
What is wrong? kctso Washer Repair 0 09-18-2009 03:17 PM
what's wrong? fairull Oven Repair (including Ranges and Cooktops) 1 12-16-2007 04:31 PM
