| » jenn air refer blows breaker |
Hi.
Was it always plugged in the same outlet? Also, please provide the model and serial number. Thank you. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Hi.
Unplug the refrigerator, open rear panel, remove cover from compressors contacts. Remove relay and using the multimeter check the 3 pins to the ground (one test lid to the copper tubing, another one to the pin.) If it'll show continuity - you have bad compressor. Thank you. Post the results. Simon.
__________________
Hi.
It's a complicated job, requires professional skills and special equipment. Check with local appliance companies for the estimate. Good luck. Post the results. Simon.
__________________
I pulled the leads off of the compressor and checked each for continuity to ground. All three pins have continuity to ground. Also, when the compressor leads are disconnected and the refer is plugged in, the breaker remains untripped ( and all other features of the refer ( lights, fan etc ) work fine ). Is it safe to assume that the compressor has failed?
Hi.
Bad news - it's the compressor. Simon.
__________________
| Display Modes | |
| Ge gas oven blows house circuit breaker | Sharky3 | Oven Repair (including Ranges and Cooktops) | 0 | 02-26-2011 09:13 PM |
| Cook Top Works but blows breaker after use | Steve Gloeckner | Oven Repair (including Ranges and Cooktops) | 0 | 11-07-2010 09:16 AM |
| Oven blows circuit breaker | sufax | Oven Repair (including Ranges and Cooktops) | 0 | 03-28-2010 10:14 AM |
| Broiler blows circuit breaker | Sarafixit | Oven Repair (including Ranges and Cooktops) | 3 | 02-10-2009 05:24 AM |
| Blows the breaker | DennisDW | Washer Repair | 0 | 04-05-2008 11:01 AM |
