Discuss
bad thermal overload?
 in
Refrigerator & Freezer Repair
(I'm not sure of the age of this refrigerator - we got it used 5 - 10 years ago). (Refrigerator
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » bad thermal overload?
  #1 (permalink)
Old 04-26-2012, 08:33 PM
Junior Member
benj is on a distinguished road
Default bad thermal overload?
Model Number: RT14F3WLCD   Brand: Gibson   Age: 5 - 10 years
(Refrigerator serial number: 1048712339)
The frig was cycling on and off every few minutes and the freezer wasn't freezing food. When I removed the thermal overload it stopped cycling on and off but now it doesn't seem to be able to turn off by itself.
I tested the relay with an ohm meter between terminals 1 & "L" and 2 & "L". I get 0 ohms on one that changes to infinite when turned upside down and 0 on the other both right side up and upside down. When I shake the relay it rattles, but shouldn't it do that since it is supposed to move when you turn it upside down?
I was thinking of replacing the overload (and the relay also).
Should the thermostat turn the compressor off when it reaches the right temp even though there's no overload?
Thanks for your help.
Ads By Google
Related Models
Whirlpool RT14FCLWL00
Whirlpool RT14FCLWW00
Whirlpool RT14FCRWL00
Whirlpool RT14FCRWW00
Whirlpool RT14GDXAL00
Whirlpool RT14GDXAW00
Whirlpool RT14GDXBL00
Whirlpool RT14GDXBL10
Whirlpool RT14GDXBW00
Whirlpool RT14GDXBW10
Whirlpool RT14GDXDN00
Whirlpool RT14GDXDW00
Whirlpool RT14GDYAL00
Whirlpool RT14GDYAW00
Whirlpool RT14GDYBL00
Whirlpool RT14GDYBL10
Whirlpool RT14GDYBW00
Whirlpool RT14GDYBW10
Whirlpool RT14HBXFW00
Whirlpool RT14HBXFW01
Whirlpool RT14HDXBL00
Whirlpool RT14HDXBL01
Whirlpool RT14HDXBW00
Whirlpool RT14HDXBW01
Whirlpool RT14HDXDN00
Whirlpool RT14HDXDN01
Whirlpool RT14HDXDN02
Whirlpool RT14HDXDN03
Whirlpool RT14HDXDW00
Whirlpool RT14HDXDW01
Whirlpool RT14HDXDW02
Whirlpool RT14HDXDW03
Whirlpool RT14HDXDW05
Whirlpool RT14HDXEN00
Whirlpool RT14HDXEW00
Whirlpool RT14HDXGW00
Whirlpool RT14HDXGW01
Whirlpool RT14HDXGW02
Whirlpool RT14HDXJW00
Whirlpool RT14HDXKQ00
Whirlpool RT14HDXKQ01 Refrigerator
Whirlpool RT14HDXPQ00 Refrigerator
Whirlpool RT14HDXPQ01 Refrigerator
Whirlpool RT14HDXPQ02 Refrigerator
Whirlpool RT14HDYBL00
Whirlpool RT14HDYBL01
Whirlpool RT14HDYBW00
Whirlpool RT14HDYBW01
Whirlpool RT14HDYDN00
Whirlpool RT14HDYDN01
Whirlpool RT14HDYDN03
Whirlpool RT14HDYDW00
Whirlpool RT14HDYDW01
Whirlpool RT14HDYDW03
Whirlpool RT14HDYDW05
Whirlpool RT14HDYGW00
Whirlpool RT14HDYGW01
Whirlpool RT14HDYGW02
Whirlpool RT14HDYJW00
Whirlpool RT14HDYKQ00
Whirlpool RT14HDYKQ01 Refrigerator
Whirlpool RT14HDYPQ00 Refrigerator
Whirlpool RT14HDYPQ01 Refrigerator
Whirlpool RT14HDYPQ02 Refrigerator
Whirlpool RT14HKXAL00
Whirlpool RT14HKXAW00
Whirlpool RT14HKYAL00
Whirlpool RT14HKYAW00
Whirlpool RT14VKXBL00
Whirlpool RT14VKXBW00
Whirlpool RT14VKXDL00
Whirlpool RT14VKXDL02
Whirlpool RT14VKXDW00
Whirlpool RT14VKXDW02
Whirlpool RT14VKXEN00
Whirlpool RT14VKXEW00
Whirlpool RT14VKYBL00
Whirlpool RT14VKYBW00
Whirlpool RT14VKYDL00
Whirlpool RT14VKYDL02
Whirlpool RT14VKYDW00
Whirlpool RT14VKYDW02
Whirlpool RT14VKYEN00
Whirlpool RT14VKYEW00
Whirlpool RT14WKXFW00
Whirlpool RT14WKXFW01
Whirlpool RT14WKXFW02
Whirlpool RT14WKXGW00
Whirlpool RT14WKXGW01
Whirlpool RT14WKXGW02
Whirlpool RT14WKYFW00
Whirlpool RT14WKYFW01
Whirlpool RT14WKYFW02
Whirlpool RT14WKYGW00
Whirlpool RT14WKYGW01
Whirlpool RT14WKYGW02
Whirlpool RT14ZKXDN00
Whirlpool RT14ZKXDN02
Whirlpool RT14ZKXDW00
Whirlpool RT14ZKXDW02
Whirlpool RT14ZKXEN00
Whirlpool RT14ZKXEW00
Whirlpool RT14ZKXFN00
Whirlpool RT14ZKXFN01
Whirlpool RT14ZKXFN02
Whirlpool RT14ZKXFW00
Whirlpool RT14ZKXFW01
Whirlpool RT14ZKXFW02
Whirlpool RT14ZKXGN00
Whirlpool RT14ZKXGN01
Whirlpool RT14ZKXGW00
Whirlpool RT14ZKXGW01
Whirlpool RT14ZKXKQ00
Whirlpool RT14ZKXKQ01
Whirlpool RT14ZKXKQ02 Refrigerator
Whirlpool RT14ZKXKQ03 Refrigerator
Whirlpool RT14ZKXKQ04 Refrigerator
Whirlpool RT14ZKXKZ00
Whirlpool RT14ZKXKZ01
Whirlpool RT14ZKXKZ02 Refrigerator
  #2 (permalink)
Old 04-27-2012, 01:08 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
When the fridg is running, is the compressor vibrating and warm?
__________________
  #3 (permalink)
Old 04-27-2012, 02:58 AM
Junior Member
Default
Quote:
The compressor is vibrating and too hot to touch for long. I left it running for about 2 hrs. and the temperature in the frig got to 45F before I turned it off (I had to go out and didn't want to leave it unattended. Now that I've turned it back on, I'm waiting to check the freezer temperature.
  #4 (permalink)
Old 04-27-2012, 03:11 AM
Senior Expert
APP Volunteer
Default
You might have a clogged capillary tube in this. Check the nameplate for refrigerant type, if R12, you have a compressor that normally draws over about 3 amps. Put a amprobe one of the compressor leads, if well under 2 amp, that would confirm it. Still would cost over $100 to fix it, fridg may not be worth it.
__________________
  #5 (permalink)
Old 04-27-2012, 03:19 AM
Junior Member
Default
It is R12. I was thinking of converting it over to R134a but I don't have a pump to put it into the canister (I got one of those recycle canisters a long time ago.) I was thinking to maybe rent a pump or even buy one if I can find one not too expensive. I've got a pretty good vacuum pump that goes down to about 10 mm and a nitrogen tank to flush out the oil. I don't have a meter that can test that many amps although I've been wanting to get one.
Shouldn't the thermostat turn the compressor off if the frig reaches the right temperature?
  #6 (permalink)
Old 04-28-2012, 12:50 AM
Senior Expert
APP Volunteer
Default
I would check the compressor current to verify clogged capillary, then cut the cap line and blow out the clog with high pressure gas, then vacumm the system, then replace the dryer. Now measure the low side pressure, should be less than 22 mm vacumm, if not, I would junk it. If ok, then re-charge with R134A.
Remember, this is still an energy sucker. A new fridg would pay for itself in 3 or 4 years due to the energy savings.
__________________
  #7 (permalink)
Old 04-28-2012, 05:17 AM
Junior Member
Default
Thanks for the info. Unfortunately, the compressor blew out. I ran it for maybe 1 1/2 hours and the frig temp got down to 40F. The freezer was down below 20F. I turned it off but then decided to turn it on again before the compressor had cooled down. It made some scraping sounds and then seized and blew the fuse.
Would there be a place to get a used refrigerant recovery pump inexpensively?
  #8 (permalink)
Old 04-28-2012, 08:43 AM
Senior Expert
APP Volunteer
Default
They are hard to get and if you get a cheap one it may be bad. These pumps must be well protected with a good micro filter and a bypass to collect any oil sucked in, otherwise the compressor will seize.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thermal Overload Safety Thermostat jfolk Oven Repair (including Ranges and Cooktops) 2 03-03-2012 04:29 PM
Thermal overload switch problem bjames36 Oven Repair (including Ranges and Cooktops) 0 09-29-2011 01:03 PM
installing thermal overload and components on new compressor Craig Golembiewski Refrigerator & Freezer Repair 0 03-01-2011 09:11 AM
Thermal Overload Device erogers Oven Repair (including Ranges and Cooktops) 0 01-07-2011 08:49 AM
Thermal Overload Device Problem? lwild Oven Repair (including Ranges and Cooktops) 2 03-13-2009 11:30 AM
