| » Frigidaire freezing food after repair |
Model Number: mrs20wrgw1 Brand: Frigidaire Age: 5 - 10 years
my parents frigidaire fridge was not cooling properly,figured out it was the defrost timer.I replaced that and it worked fine for a few weeks,no more coil freezing up.But now a few weeks later the oposite,it is now freezing fresh food and liquids.Help!
Model # mrs20wrgw1 Ads By Google Related Models |
Replacement parts for Frigidaire MRS20WRGW1 Frg(v2) / Refrigerator | AppliancePartsPros.com First is the evaporator/freezer fan running? What is the freezer temperature? It should be between 0 and 5 degrees F. There should be a vent lower down on the wall between the fresh food and freezer sections. Is it clear of food items on both sides. If you look at the damper (Item 15 in Section 3) you will see that it has a thermostat mounted on it. This controls the damper door which regulates the amount of cold air entering the fresh food side. Check if it is open. Adjust the fresh food temperature setting to see if the damper will close.
__________________
| Display Modes | |
| frigidaire....freezing fresh food | sabaker | Refrigerator & Freezer Repair | 2 | 04-28-2012 02:01 AM |
| Ge Fridge Freezing Food In Fresh Food Section, Veg And Fuit Drawers | CGIM5804 | Refrigerator & Freezer Repair | 0 | 01-12-2010 10:29 AM |
| Frigidaire Side by Side Refrig freezing food | debdobson3781 | Refrigerator & Freezer Repair | 1 | 10-10-2009 11:38 AM |
