Discuss
Kitchen Aid Superba not making ice
 in
Refrigerator & Freezer Repair
Greetings, My Kitchen Aid ice maker bucket was overflowing, so I flipped the wire arm to the off position for
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Kitchen Aid Superba not making ice
  #1 (permalink)
Old 04-26-2012, 07:50 AM
Junior Member
RocLobster is on a distinguished road
Default Kitchen Aid Superba not making ice
Brand: Kitchen Aid   Age: 5 - 10 years
Greetings,
My Kitchen Aid ice maker bucket was overflowing, so I flipped the wire arm to the off position for a few days until we used up most of the ice. When I switched it back to the on position, no ice was made. I noticed the fill tube looked clogged with ice so I did the hair dryer trick, and after a few minutes put my hand to feel the tray been filled with water. Later I felt the tray and it had ice but the "ice fingers" didn't move the ice from the tray to the bucket.
Ads By Google
  #2 (permalink)
Old 04-26-2012, 08:33 AM
Junior Member
asa2000 is on a distinguished road
Default Possible solution
Quote:
Originally Posted by RocLobster View Post
Greetings,
Have you attempted to remove the icemaker and reset the fingers to their preset position (which is 2:00 o'colck)? If not I would reccomend trying that. Many times the fingers will get stuck in the 8 o'clock position due to a bad or slow motor. If it continues to happen after resetting the fingers to their proper position, I would suggest replacing the complete icemaker assembly.
  #3 (permalink)
Old 04-26-2012, 01:40 PM
Junior Member
Default
I removed the unit as suggested and positioned the fingers to 2 o'clock, but I tipped the unit to the side in the process and the front cover fell of along with the big gear. I re-installed the gear but I'm not sure it's in the right setting. What position should the gear be in if the fingers are at 2o'clock?
BTW Thanks for the help.
Rocco
  #4 (permalink)
Old 04-26-2012, 03:25 PM
Junior Member
Default Gear position
Roc,
What options are there for the lineup on the gear. If it is the one I'm thinking there is a line where it can be installed on either the 10 o'clock or the 5 o'clock position. I believe that with the fingers in the 2 o'clock the gear should set at the 5 o'oclock position. I will try and doublecheck it, but that is what I recall. I hope this helps you out.
  #5 (permalink)
Old 04-27-2012, 01:05 PM
Junior Member
Default
Got the gear in the unit cycled once, made a few cubes then stopped. Tray did not re-fill with water. Do I need a new control and motor assembly or could it be something else?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kitchen Aid Superba Gas Oven eyendall Oven Repair (including Ranges and Cooktops) 1 07-12-2011 01:44 PM
Kitchen Aid Superba Lower arm ArmyWife Dishwasher Repair 0 05-14-2011 11:03 AM
kitchen aid superba mrcletus Dishwasher Repair 0 08-24-2009 12:56 PM
Kitchen Aid Superba sandbarsun Oven Repair (including Ranges and Cooktops) 1 08-11-2009 01:59 PM
Kitchen Aid Superba Casey9 Washer Repair 0 08-04-2008 09:28 AM
