Discuss
fridge very cold at the bottom
 in
Refrigerator & Freezer Repair
Hello My fan is not running I removed fan put 120 volts to it and it ran I then took
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » fridge very cold at the bottom
  #1 (permalink)
Old 04-26-2012, 05:44 AM
Junior Member
adolph is on a distinguished road
Default fridge very cold at the bottom
Model Number: SZD25NL   Brand: Amana   Age: More than 10 years
Hello My fan is not running I removed fan put 120 volts to it and it ran I then took out the defrost thermostat and I checked it with Ohm meter nothing then I put ice around it and it snapped open checked with Ohm meter and it showed it was ok I checked heater and it read resistant When I check for voltage to the two wires that go to the fan it reads 120 volts ?? I wired all the item back up plugged fridge back in waited a while I saw that the fan motor was running but if I would just touch it it would stop no strength I had a new c frame motor plugged into the wires same thing no run what could be the problem when I plug the fridge in the evap coil does get cold and it starts to frost a bit HELP Thank you
Ads By Google
Related Models
Amana SZD25NL Ref - SXS/I&W
Amana SZD25NW Ref - SXS/I&W
Amana SZD25S5E Ref - SXS/I&W
Amana SZD25S5L Ref - SXS/I&W
Amana SZD25S5W Ref - SXS/I&W
Amana SZD26VE Ref - SXS/I&W
Amana SZD26VL Ref - SXS/I&W
Amana SZD26VW Ref - SXS/I&W
Amana SZD27KBL Ref - SXS/I&W
Amana SZD27KBW Ref - SXS/I&W
Amana SZD27KL Ref - SXS/I&W
Amana SZD27KPL Ref - SXS/I&W
Amana SZD27KPW Ref - SXS/I&W
Amana SZD27KW Ref - SXS/I&W
Amana SZD27MBL Ref - SXS/I&W
Amana SZD27MBW Ref - SXS/I&W
Amana SZD27ML Ref - SXS/I&W
Amana SZD27MPB Ref - SXS/I&W
Amana SZD27MPL Ref - SXS/I&W
Amana SZD27MPW Ref - SXS/I&W
Amana SZD27MW Ref - SXS/I&W
Amana SZD27NE Ref - SXS/I&W
Amana SZD27NL Ref - SXS/I&W
Amana SZD27NW Ref - SXS/I&W
Amana SZDE20K Ref - SXS/I&W
Amana SZDE20KB Ref - SXS/I&W
Amana SZDE20KP Ref - SXS/I&W
Amana SZDE20MBL Ref - SXS/I&W
Amana SZDE20MBW Ref - SXS/I&W
Amana SZDE20ML Ref - SXS/I&W
Amana SZDE20MPE Ref - SXS/I&W
Amana SZDE20MPL Ref - SXS/I&W
Amana SZDE20MPW Ref - SXS/I&W
Amana SZDE20MW Ref - SXS/I&W
Amana SZDE25K Ref - SXS/I&W
Amana SZDE25KB Ref - SXS/I&W
Amana SZDE25KP Ref - SXS/I&W
Amana SZDE25MBL Ref - SXS/I&W
Amana SZDE25MBW Ref - SXS/I&W
Amana SZDE25ML Ref - SXS/I&W
Amana SZDE25MPE Ref - SXS/I&W
Amana SZDE25MPL Ref - SXS/I&W
Amana SZDE25MPW Ref - SXS/I&W
Amana SZDE25MW Ref - SXS/I&W
Amana SZDE27KBL Ref - SXS/I&W
Amana SZDE27KBW Ref - SXS/I&W
Amana SZDE27KL Ref - SXS/I&W
Amana SZDE27KPL Ref - SXS/I&W
Amana SZDE27KPW Ref - SXS/I&W
Amana SZDE27KW Ref - SXS/I&W
Amana SZDE27MBL Ref - SXS/I&W
Amana SZDE27MBW Ref - SXS/I&W
Amana SZDE27ML Ref - SXS/I&W
Amana SZDE27MPE Ref - SXS/I&W
Amana SZDE27MPL Ref - SXS/I&W
Amana SZDE27MPW Ref - SXS/I&W
Amana SZDE27MW Ref - SXS/I&W
Amana SZDE27NE Ref - SXS/I&W
Amana SZDE27NL Ref - SXS/I&W
Amana SZDE27NW Ref - SXS/I&W
Amana SZI20K Ref - SXS/I&W
Amana SZI20ML Ref - SXS/I&W
Amana SZI20MW Ref - SXS/I&W
Amana SZI20NE Ref - SXS/I&W
Amana SZI20NL Ref - SXS/I&W
Amana SZI20NW Ref - SXS/I&W
Amana T-110 Mwave - Cntrtp / Stand Alone
Amana T-110B Mwave - Cntrtp / Stand Alone
Amana T-17D Misc / Accessory
Amana T-17D-1 Misc / Accessory
Amana T-17E Misc / Accessory
Amana T-17LD Misc / Accessory
Amana T-17LD-1 Misc / Accessory
Amana T-17LE Misc / Accessory
Hoover T1001-1
Hoover T1003
Hoover T1003-1
Hoover T1003-2
Hoover T1003-4
Hoover T1003-5
Hoover T1003-6
Hoover T1009-1
Hoover T1009-2
Hoover T1009-5
Hoover T1011
Hoover T1011-1
Hoover T1011-161
Hoover T1011-6
Hoover T1011-664
Hoover T1023
Hoover T1023-1
Hoover T1023-2
  #2 (permalink)
Old 04-26-2012, 07:15 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for SZD25NL models | AppliancePartsPros.com
I cannot find any tech info on this unit so do not know how the fan is wired in.
Neither of these should effect the fan.
Did you check the 120 volts with the fan running or was it disconnected.
My guess is that both motors ran without much turning power that the 120 volts is dropping once a load is on it.
Check it with the fan connected.
If it drops then there is probably a bad connection/wire somewhere in the unit.
On most older units the compressor, the condenser and the evaporator fan are wired in parallel since the compressor and it's fan seem to run OK I am guessing that only the evaporator fan has the bad connection.
With luck you have the wiring diagram and can trace it.
__________________
  #3 (permalink)
Old 04-26-2012, 11:04 AM
Junior Member
Default
I went home at noon I took a needle nose pliers and I took apart the connections it the fan now has power to run the fan and is 120 volts to the fan when it's running Thank you Adolph
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
top of fridge cold bottom freezer not freezing jmpbkjack Refrigerator & Freezer Repair 1 06-11-2011 05:00 AM
Bottom of fridge will not get cold mikecmc Refrigerator & Freezer Repair 6 05-14-2011 12:41 PM
Bottom Freezer, too cold Fridge fine stripesjr Refrigerator & Freezer Repair 2 03-26-2011 11:45 AM
Freezer And Fridge Is Only Cold At The Bottom glonich Refrigerator & Freezer Repair 0 02-01-2010 03:50 PM
Whirlpool fridge (bottom freezer style) top fridge shelf getting very cold dieselgg Refrigerator & Freezer Repair 5 06-19-2009 04:51 AM
