Discuss
Evaporator Fan not turning on: AMANA SPD25QA3L MFG# P1181321W L
 in
Refrigerator & Freezer Repair
I am unsure how old the Fridge is. Condenser works. Will not get cold. I did not feel any air
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Evaporator Fan not turning on: AMANA SPD25QA3L MFG# P1181321W L
  #1 (permalink)
Old 04-23-2012, 12:58 PM
Junior Member
lifesjester is on a distinguished road
Default Evaporator Fan not turning on: AMANA SPD25QA3L MFG# P1181321W L
Model Number: SPD25QA3L   Brand: -other-   Age: More than 10 years
I am unsure how old the Fridge is. Condenser works. Will not get cold. I did not feel any air coming out of vents in the freezer or fridge so I checked the Evaporator Fan. Not turning, but spins freely.
I tested by hooking up old plug to wires and fan turns on. I checked the voltage coming to the fan and Hot to common is 77v.
Per forums, thermostat could be the problem as it is pigged in. I tested the resistance by putting in ice water and checking, but not showing value. I bought a new one and getting the same reading of nothing and plugged it in anyway, but the fan is still not working. I guess the way I was testing was wrong as what are the chances of a brand new thermostat being bad? I put on 200 ohms and touched the test contacts (1 brown & 1 orange wire) and multimeter read 1, the same as when not touching anything. When I touch the leads together I get reading.
I am not sure what to check. It is for a friend who is strapped and I am staying with them (jobless) trying to help them out, I'm not an electrician either. I don't want to waste more of their money to buy parts they don't need.
I was going to try to trace all the wires to look for burnt out/disconnected/broken signs but it is in a tight spot to work on (have to keep pushing all the way back to go into the front and jumping over counters and vice-versa) and am not too proud to ask for help. So.... please help.
I read about the main board but it is no longer made. Very difficult to find another.
Maybe I am overlooking something obvious.
Ads By Google
Related Models
Amana SPD25QA3L Ref - SXS/I&W
Amana SPD25QA3W Ref - SXS/I&W
Amana SPD25TE Ref - SXS/I&W
Amana SPD25TL Ref - SXS/I&W
Amana SPD25TW Ref - SXS/I&W
Amana SPD26VL Ref - SXS/I&W
Amana SPD26VW Ref - SXS/I&W
Amana SPD27Q2E Ref - SXS/I&W
Amana SPD27Q2L Ref - SXS/I&W
Amana SPD27Q2W Ref - SXS/I&W
Hardwick SPG8441RTA719DZ Walloven - Std Dbl Oven Gas
Hardwick SPG8441RTW719DZ Walloven - Std Dbl Oven Gas
Amana SPN22G Ref - SXS/I&W
Amana SPN22G-A Ref - SXS/I&W
Amana SPN22G-AG Ref - SXS/I&W
Amana SPN22G-C Ref - SXS/I&W
Amana SPN22N Ref - SXS/I&W
Amana SPN22N-A Ref - SXS/I&W
Amana SPN22N-AG Ref - SXS/I&W
Amana SPN22N-C Ref - SXS/I&W
Amana SQ22NBL Ref - SXS/I&W
Amana SQ22NBW Ref - SXS/I&W
Amana SQD20NL Ref - SXS/I&W
Amana SQD20NW Ref - SXS/I&W
Amana SQD22NBL Ref - SXS/I&W
Amana SQD22NBW Ref - SXS/I&W
Amana SQD22NL Ref - SXS/I&W
Amana SQD22NW Ref - SXS/I&W
Amana SQD23VL Ref - SXS/I&W
Amana SQD23VW Ref - SXS/I&W
Amana SQD25MB2L Ref - SXS/I&W
Amana SQD25MB2W Ref - SXS/I&W
Amana SQD25MB3E Ref - SXS/I&W
Amana SQD25MB3L Ref - SXS/I&W
Amana SQD25MB3W Ref - SXS/I&W
Amana SQD25MB4E Ref - SXS/I&W
Amana SQD25MB4L Ref - SXS/I&W
Amana SQD25MB4W Ref - SXS/I&W
Amana SQD25MBG Ref - SXS/I&W
Amana SQD25MBL Ref - SXS/I&W
Amana SQD25MBW Ref - SXS/I&W
Amana SQD25N2L Ref - SXS/I&W
Amana SQD25N2W Ref - SXS/I&W
Amana SQD25NB2L Ref - SXS/I&W
Amana SQD25NB2W Ref - SXS/I&W
Amana SQD25NBE Ref - SXS/I&W
Amana SQD25NBL Ref - SXS/I&W
Amana SQD25NBW Ref - SXS/I&W
Amana SQD25NL Ref - SXS/I&W
Amana SQD25NW Ref - SXS/I&W
Amana SQD25TL Ref - SXS/I&W
Amana SQD25TW Ref - SXS/I&W
Amana SQD25VL Ref - SXS/I&W
Amana SQD25VW Ref - SXS/I&W
Amana SQD26VE Ref - SXS/I&W
Amana SQD26VL Ref - SXS/I&W
Amana SQD26VW Ref - SXS/I&W
Amana SR-19 Ref - SXS/I&W
Amana SR-522E Ref - SXS/I&W
Amana SR-522E-A Ref - SXS/I&W
Amana SR-522E-C Ref - SXS/I&W
Amana SR-522E-G Ref - SXS/I&W
Amana SR-522E-L Ref - SXS/I&W
Amana SR17A Ref - SXS/I&W
Amana SR17A-A Ref - SXS/I&W
Amana SR17A-AG Ref - SXS/I&W
Amana SR17A-C Ref - SXS/I&W
Amana SR17F Ref - SXS/I&W
Amana SR17G Ref - SXS/I&W
Amana SR17G-1 Ref - SXS/I&W
Amana SR17G-1-A Ref - SXS/I&W
Amana SR17G-1-AG Ref - SXS/I&W
Amana SR17G-1-C Ref - SXS/I&W
  #2 (permalink)
Old 04-23-2012, 02:23 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
It's very old refrigerator, can't find the wiring diagram.
Try to bypass the defrost thermostat.
If that not going to help, see if you can find a pair of wires (including the one of the motor's) which will give you 120v, and hook up the evaporator motor to them.
If you take off the vertical cover at the back you may be able to find the bad connection or wire.
Good luck.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 04-24-2012, 04:15 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for SPD25QA3L models | AppliancePartsPros.com
See the attachment for a tech sheet. It is the closest I could find and is for SRD25T but with luck yours will be close.
If I then click on the picture of the defrost control another page opens with info on what units this part is also used on a SRD25TPS so it may be the closest match.
Note That there are other units in this series that use it.
Condenser works.
By condenser I am assuming you mean the compressor. You can usually hear it but it should be warm and you should be able to eel it vibrating.
It is not a good idea to immerse these in water. If water gets into it the thermostat will be toast.
Looks like the thermostat closes at 25 degrees F so the water would not be cold enough. Hold the face of it on an ice cube.
Getting a bad replacement part is always a possibility.
When you removed the evaporator /freezer cover to check the fan what did the evaporator coils look like?
If the compressor is running and there is no frost or just frost in one area on the evaporator coils then you have a sealed system problem.
Note that the compressor has to have run for an hour or so because if you do this shortly after a defrost cycle you will end up with the wrong diagnosis.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Evaporator Fan won't stop turning on and off lhofmann Refrigerator & Freezer Repair 8 04-27-2013 02:30 PM
Refrigerator evaporator fan not turning on jsteely Refrigerator & Freezer Repair 4 12-12-2012 09:03 PM
Evaporator Fan Blade not turning WendyLew Refrigerator & Freezer Repair 13 07-14-2010 11:57 AM
New motherboard not turning on compressor or evaporator fan jamievbva Refrigerator & Freezer Repair 0 11-27-2009 02:55 PM
Amana Refrig Evaporator Fan mrhogan Refrigerator & Freezer Repair 3 04-26-2009 02:07 PM
