Appliance Repair Forum
-   Refrigerator & Freezer Repair (http://forum.appliancepartspros.com/refrigerator-freezer-repair/)
-   -   No Crushed Ice (http://forum.appliancepartspros.com/refrigerator-freezer-repair/470403-no-crushed-ice.html)
Laurence C Riley 04-22-2012 01:53 PM
No Crushed Ice
The icemaker wont make crushed Ice only cubes will dispence. I replaced the housing around the cutter blades as the plastic flap had broken. But after replaceing it still didn't make crushed ice only cubes. The door switch works properly. I tested the switchs voltage continuity; it was OK also. I then replaced the solinoid assembly that moves the acuator rod and it still doesnt make crushed Ice? I tried plugging & unplugging the multi pin connector in the back of the freezer to see if this would corrcet the problem;it didn't! Are there any other suggestions to repair this??? Thanks Larry
