Whirlpool ice maker - stopped making ice
Model Number: 20Rud4 Brand: Whirlpool Age: 1 - 5 years
Hi, looking for help.
The in-door ice maker has just stopped working - looked at a few guides so far, so here's what's happening and what I've discovered so far: it's a whirlpool in door ice maker and I'm in the uk.
-The ejectors are sat at the home position (1.30 position). If I take the ice maker out, take the cover off, unscrew the motor to move the ejectors to a different position and plug it all back in, it moves all the way around to the home position again. No fill of water however. No further movement.
- if I jumper to test the water fill nothing happens.
- if a jumper to bypas the thermostat, heater comes on, but no movement.
- if I test with a multimeter even between l and n, no voltage....
Can the controller affect the fill valve?
Can't test fill solenoid by swapping connectors as they are different size.
optics seem fine, except that they do flash then go solid then flash when flap is shut.
Help!
Ads By Google
Related ModelsAmana 210-3B ROOM AIR CONDITIONER Hoover 2100 Roper 2101*0E Ranges, Electric* Roper 2101*1E Ranges, Electric* Roper 2101*2E Ranges, Electric* Amana 21011 COMMERCIAL MICROWAVES Amana 21016 COMMERCIAL MICROWAVES Roper 2101W0E Ranges, Electric* Roper 2101W1E Ranges, Electric* Roper 2101W2E Ranges, Electric* Roper 2102*0E Ranges, Electric* Roper 2102*1E Ranges, Electric* Roper 2102*2E Ranges, Electric* Roper 2102W0E Ranges, Electric* Roper 2102W1E Ranges, Electric* Roper 2102W2E Ranges, Electric* Amana 210W-3B ROOM AIR CONDITIONER Amana 210W-3BH ROOM AIR CONDITIONER Amana 210W-3J ROOM AIR CONDITIONER Amana 210W-3JH ROOM AIR CONDITIONER Amana 210W-3SP ROOM AIR CONDITIONER Amana 210W-3SPF ROOM AIR CONDITIONER Amana 210W-3SPFH ROOM AIR CONDITIONER Amana 210W-3SPG ROOM AIR CONDITIONER Amana 210W-3SPG ROOM AIR CONDITIONER Amana 210W-3SPGH ROOM AIR CONDITIONER Amana 210W-3SPGH ROOM AIR CONDITIONER Amana 210W-3SPH ROOM AIR CONDITIONER Hoover 2110 Jenn-Air 21136 WALLOVEN- S/C ELE Jenn-Air 21137 WALLOVEN- S/C ELE Jenn-Air 21138 ELECTRIC WALL OVEN Amana 212-2J ROOM AIR CONDITIONER Amana 212-2J-1 ROOM AIR CONDITIONER Amana 212-2JM ROOM AIR CONDITIONER Amana 212-2JM ROOM AIR CONDITIONER Amana 212-2SP ROOM AIR CONDITIONER Amana 212-2SPF ROOM AIR CONDITIONER Amana 212-2SPG ROOM AIR CONDITIONER Amana 212-2SPG ROOM AIR CONDITIONER Amana 212-3J ROOM AIR CONDITIONER Amana 212-3J-1 ROOM AIR CONDITIONER Amana 212-3SP ROOM AIR CONDITIONER Amana 212-3SPG ROOM AIR CONDITIONER Hoover 2120 Hoover 2120-01 Jenn-Air 21238 WALLOVEN- S/C ELE Jenn-Air 21239 WALLOVEN- S/C ELE Roper 2126*0A Ranges, Electric* Roper 2126X0A Ranges, Electric* Frigidaire 2129A GAS RANGE Frigidaire 2129B GAS RANGE Frigidaire 2129C GAS RANGE Amana 212D-3J ROOM AIR CONDITIONER Amana 212D-3JH ROOM AIR CONDITIONER Amana 212D-3JM ROOM AIR CONDITIONER Amana 213-3B ROOM AIR CONDITIONER Amana 213-3BH ROOM AIR CONDITIONER Amana 213-3E ROOM AIR CONDITIONER Amana 213-3F ROOM AIR CONDITIONER Amana 213-3G ROOM AIR CONDITIONER Amana 213-3G ROOM AIR CONDITIONER Amana 213-5B ROOM AIR CONDITIONER Amana 213-5BH ROOM AIR CONDITIONER Amana 213-5J ROOM AIR CONDITIONER Amana 213-5JH ROOM AIR CONDITIONER Amana 213-5SP ROOM AIR CONDITIONER Amana 213-5SPF ROOM AIR CONDITIONER Amana 213-5SPFH ROOM AIR CONDITIONER Amana 213-5SPG ROOM AIR CONDITIONER Amana 213-5SPG ROOM AIR CONDITIONER Amana 213-5SPGH ROOM AIR CONDITIONER Amana 213-5SPGH ROOM AIR CONDITIONER Amana 213-5SPH ROOM AIR CONDITIONER Jenn-Air 21336 WALLOVEN- S/C MWAVE ELE Roper 2136*0A Ranges, Electric* Roper 2136X0A Ranges, Electric* Amana 213D-3C ROOM AIR CONDITIONER Amana 213D-3CH ROOM AIR CONDITIONER Roper 2141*0E Ranges, Electric* Roper 2141*1E Ranges, Electric* Roper 2141W0E Ranges, Electric* Roper 2141W1E Ranges, Electric* Roper 2142*0E Ranges, Electric* Roper 2142*1E Ranges, Electric* Roper 2142W0E Ranges, Electric* Roper 2142W1E Ranges, Electric* Roper 2143*0F Ranges, Electric* Roper 2143W0F Ranges, Electric* Roper 2144*0F Ranges, Electric* Roper 2144W0E Ranges, Electric* Roper 2144W0F Ranges, Electric* Hoover 215 Amana 215-3D ROOM AIR CONDITIONER Amana 215-3DH ROOM AIR CONDITIONER Amana 215-3EW ROOM AIR CONDITIONER Amana 215-3F ROOM AIR CONDITIONER Amana 215-3G ROOM AIR CONDITIONER Amana 215-3G ROOM AIR CONDITIONER Amana 215-3J ROOM AIR CONDITIONER Amana 215-3J-1 ROOM AIR CONDITIONER Amana 215-3J-1 ROOM AIR CONDITIONER Amana 215-3JH ROOM AIR CONDITIONER Amana 215-3JM ROOM AIR CONDITIONER Amana 215-3JM ROOM AIR CONDITIONER Amana 215-3K ROOM AIR CONDITIONER Amana 215-3N ROOM AIR CONDITIONER Amana 215-3N ROOM AIR CONDITIONER Amana 215-3NE ROOM AIR CONDITIONER Amana 215-3NE ROOM AIR CONDITIONER Amana 215-3NH ROOM AIR CONDITIONER Amana 215-3SP ROOM AIR CONDITIONER Amana 215-3SPF ROOM AIR CONDITIONER Amana 215-3SPFH ROOM AIR CONDITIONER Amana 215-3SPG ROOM AIR CONDITIONER Amana 215-3SPG ROOM AIR CONDITIONER Amana 215-3SPGH ROOM AIR CONDITIONER Amana 215-3SPGH ROOM AIR CONDITIONER Amana 215-3W ROOM AIR CONDITIONER Amana 215-5J ROOM AIR CONDITIONER
