Discuss
Manual defrost..then ran great for a couple of hours..now wont run at all
 in
Refrigerator & Freezer Repair
Have a GE side by side model GSS20IEPJWW..have replaced water valve that was dripping...now replaced main board that was clearly
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Manual defrost..then ran great for a couple of hours..now wont run at all
  #1 (permalink)
Old 04-21-2012, 06:29 PM
Junior Member
fadams is on a distinguished road
Default Manual defrost..then ran great for a couple of hours..now wont run at all
Brand: GE   Age: 1 - 5 years
Have a GE side by side model GSS20IEPJWW..have replaced water valve that was dripping...now replaced main board that was clearly blown..I think it needed defrosting before I started back up from main board replacement but didnt realize at the time.Yesterday it just would not pull down and I took evap cover off and found it a solid block of ice.I defrosted slowly with a fan and plugged back in.It ran great for a couple of hours more or less and froze ice in icemaker as well as getting down to about 35 degrees in fridge part then shut off.Now about 3 hrs later the unit(compressor) just started back up.Do you think I have a freezer side thermistor not sensing properly that kept the compressor off for such an excessive period?Do you have any idea what I should check given these symptoms?What could cause such an excessive delay in restart.Freezer is now dropping well and back to 29 and still going.I dont trust it tho and wonder if theres a thermistor or other compnent that controls the compressor cut in/cut out temperature?The compressor never seemed excessivly hot by the way so dont think it thermal overload.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
freezer wont defrost anymore, freezes over every couple weeks... Jill68 Refrigerator & Freezer Repair 2 07-11-2011 01:29 PM
GE Mini Fridge stops working after only a couple hours johnthanander Refrigerator & Freezer Repair 0 01-20-2011 10:50 AM
maytag dryer worked fine then a few hours later wont turn on snooki Dryer Repair 2 12-02-2010 05:44 AM
stops cooling after a couple hours??? brygervais Refrigerator & Freezer Repair 4 04-05-2010 08:09 PM
Great Deal, A Couple Of Issues CJR Refrigerator & Freezer Repair 0 09-12-2007 09:35 PM
