i have a ge mini fridge it doesnt seem like it runs there are no noises i have a test light and a voltage meter how do i check to see if it works and i need help to get it working again soo please helpme
Here are your parts Replacement parts for WMR04BAPBBB models | AppliancePartsPros.comIt is a GE so getting a wiring diagram is near impossible as they like to keep all tech data a secret. Check that the thermostat contacts are closed with your meter. If it is a 2 wire thermostat you could unplug the fridge. Short the two thermostat wires together. You may have to tape them to be sure they do not short to anything else. Then plug it in and give it a try. If it fires up you need a new thermostat (Item 22 in Section 1. If nothing happens then odds are there is a problem at the compressor. Check for 120 volts at the relay. Here are a couple good site about basic fridge repair and how to check things. http://www.applianceaid.com/refrigerator.htmlHow To Fix a Refrigerator - Appliance Repair Guide - ACME HOW TO.comIf the start device (PTC) (Item 7 in Section 3) is shot then you may be out of luck as it looks obsolete. |
THIS FORUM IS DEAD!!!!!!! |
